Vertical play in steering column | FerrariChat
Discussion in '308/328' started by dflett, Jun 6, 2014.
  1. dflett
    dflett Formula 3
    1,632
    NY
    David
    #1 dflett, Jun 6, 2014
    Since I bought the car in 2010 I have approx 5 mm of vertical play in the steering column that I'd like to eliminate if possible. I have to put quite a lot of force to move it up and down so it's not a huge issue but I'd rather it was more solid. I changed the steering rack in 2012 and it did not affect this behavior.
    I see no movement down at the bulkhead. It almost feels like metal under the dash flexing rather than something loose. I have checked the bolts highlighted in green below and all are very tight.
    Any ideas or opinions on this?
    Regards
    David
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,922
    The Cold North
    Tom
    That entire bracket moves. Silly as it seems. It's a completely under engineered part.
  3. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    You may want to check it again as that is the part that locks the movement. Maybe something else like the bracket is loose or broken?
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I've assumed that the bracket's lack of robustness was a safety feature to make sure it gave way in an accident. It sure does seem like it could be quite a bit more stout.
  5. dflett
    dflett Formula 3
    1,632
    NY
    David
    Thank you for the suggestions guys. I'll take another look today.
    David
  6. Skippr1999
    Skippr1999 F1 Rookie
    4,497
    Mine does this also. Really annoying. Any known solutions out there ?
  7. dflett
    dflett Formula 3
    1,632
    NY
    David
    I checked the bolts and welds and everything looks fine. It's just the bracket flexing a little. A beefier bracket is needed perhaps
  8. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,028
    Coolum Beach AUSTRALIA
    Karen H.
    Mine's the same - might be worth asking is there anyone who DOESN'T have this play?
  9. Skippr1999
    4,497
    Ok, does anyone Not have steering column play ?
  10. mcfarlin
    mcfarlin Karting
    Jun 9, 2008
    137
    Colorado
    Mike McFarlin
    I have some, but is tightened everythink up a bit when I re upholstered the dash last winter. It's much better now.
  11. robertgarven
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    #11 robertgarven, Jun 13, 2014
  12. dflett
    dflett Formula 3
    1,632
    NY
    David
    #12 dflett, Jun 13, 2014
    But does the GT4 have the same bracket arrangement as the GTB/S?
    I think we do have the same steering rack bushings tho :)
  13. robertgarven
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    #13 robertgarven, Jun 13, 2014
  14. dflett
    dflett Formula 3
    1,632
    NY
    David
    Does that bolt go into the chassis or another bracket? On the GTB it attaches to another bracket made from thin folded steel and it is that that is flexing.
  15. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    My GTB has a tiny bit of flex (with exertion) but not really any vertical movement. Can anyone explain how to remove the lower dash panel to get at the nuts that might need tightening? Thanks.
  16. dflett
    dflett Formula 3
    1,632
    NY
    David
    Yes, flex with exertion is a better description.
    The lower panel just covers the steering column. Mine was held on with four screws. There is a bolt hole in the middle though on my car there was no bolt in it. Here is a pic if it makes it any clearer.
  17. ScuderiaRossa
    2,230
    Thanks for the photo but my lower cover doesn't look like that at all. It has side wings that capture the column part of the cover. There are four linear holes bit no screws (sorry, not at home to take a pic). I'm wondering if this is an early 328 carry over from a 308? I'm thinking there are clips in there holder the upper and lower covers together?
  18. dflett
    dflett Formula 3
    1,632
    NY
    David
    Sorry. Did not see you have a 328. Mines from a 308.
    David
  19. Ffinally
    Ffinally Formula Junior
    Jun 12, 2010
    658
    DFW
    Charles
    My 87 328 GTS has the same cover that you describe but with 2 screws in to the bottom of the dash structure. They were a bit tricky to find but not horrible.
    And no, it has never flexed vertically, even after I adjusted the steering wheel angle.
  20. ScuderiaRossa
    2,230
  21. robertgarven
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    The GT4 just has one large middle screw. The bracket looks exactly the same as the one pictured above.
