360 - Very little cabin heat | FerrariChat
360 Very little cabin heat
Discussion in '360/430' started by russ white, Apr 6, 2024.
  1. russ white
    russ white Rookie
    18
    Maryville, TN
    I purchased my "new to me" 04 360 Spider last summer and migrated, without the car, to Florida for the winter. Back now and it's cool and I could not get any significant heat into the cabin. Dash temperature seemed low at an estimated 160 degree F. I will attempt to attach dash image. Just looking for some guidance if this is normal or if I have a problem I should address. Thanks Folks - Russ Image Unavailable, Please Login
  2. mb5
    mb5 Karting
    Nov 11, 2017
    132
    Los Angeles
    Matt
    Your concern is with how the climate control is behaving yea? You sure you have it all configured correctly? Maybe send a picture of the dials & buttons.
  3. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    This is on my list but I haven't gotten to it yet. From my research the TGK valve near the brake fluid reservoir is a possible culprit and it can be tested with a 9v battery. Also make sure the stop button isn't lit as it's a bit unintuitive how the HVAC works.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,916
    Central NJ
    Dominick
    Here is a test ...idle for a while and see if gauge goes up to about 180's ..then take it on road and see if it falls to 160's .. if so you need a new thermostat
  5. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    The 360 uses a circulation pump to move hot coolant into the heater core. If that pump isn't working, only a small fraction of the hot coolant will circulate.
    The motor turns on with the car off so if you turn the ignition key to on, then switch the heat on, you should hear the circulation pump kick in. No noise, no pump. Problem located.
    If you do hear a noise from the pump, it's likely the valve isn't opening enough or is stuck partially open.
    The heater in the 360 is remarkably efficient and can put out a lot of heat. It also can help cool the system if your radiator fans aren't coming on properly.
    flash32 likes this.
  6. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    New owners who fail to get a warm cabin often have the climate control button in the wrong position - the book and the switch are very unclear as to which is on and which is off - you need climate ON to get heating or cooling
  7. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    I have a similar issue but I think mine is a stuck mixing valve or something. If I play around with the recirc button and swing the them dial back and forth it tends to kick on.
    KC360 FL likes this.
  8. hessank
    hessank Formula 3
    1,921
    Canada, Florida
    Fred
    +1
    Note: To get heat the AC Compressor must be available to run via PB#9
    Here is an excerpt from my notes
    Qavion, FerrfanFL and EastMemphis like this.
  9. russ white
    russ white Rookie
    18
    Maryville, TN
    Thanks to everyone that commented! I was worried the coolant was not getting hot enough, but I think the real problem was my not completely understanding the climate control system. With the STOP button out I am getting heat.
  10. mfennell70
    mfennell70 Formula Junior
    Nov 3, 2003
    609
    Middletown, NJ
    That's good news. FWIW, when i had a similar problem, it was because I did not bleed the cooling system adequately. I've since added a vacuum coolant filler to my tool collection.
    67bmer, EastMemphis and Qavion like this.
