For Sale - Very nice 1991 348 TS | FerrariChat
For Sale Very nice 1991 348 TS
Discussion in 'Ferraris' started by Cauf61, Apr 4, 2019.
  1. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    For Sale Ferrari 348 TS from 1991. Has run 62000 km. The car is in exceptionally good condition. This for bodywork (extra treated against rust), leather interior and engine. Motor runs perfectly without oil consumption.
    Overall condition 8.5/10.
    The large service, incl. clutch! ,was executed in 5/2018 on 59000km. Very extensive history available. Original Tool case + Ferrari map with manual is still present. Air Conditioning and HVAC unit work as it should. The Rest of the electro also works as new.
    Car is in Belgium. Export possible.
    Last services:
    Water Pump Heating 1 2-9-2017
    Switch Mirror L 1 2-9-2017
    Fan Regulator 1 2-9-2017
    Dampers Trunk Lid 2 10-10-2017
    Rust treatment noxudol700 23-12-2017
    Clutch + NEW Plate 1 25-4-2018
    Belt Camshaft 1 25-4-2018
    Set span Rollers HILL eng. 1 25-4-2018
    Belt Alternator 1 25-4-2018
    Crankshaft Phase Sensor 2 25-4-2018
    Lubrication + overhaul Flywheel 1 25-4-2018
    Gasket set "Large " 1 25-4-2018
    Gasoline Filters 2 25-4-2018
    Brake Line 4 25-4-2018
    Drive shaft seals HILL Eng. 3 25-4-2018
    Crankshaft Seal Viton 1 25-4-2018
    Drive shaft BEARING HILL 1 25-4-2018
    Pressure BEARING clutch 1 25-4-2018
    Shim Camshaft 5 25-4-2018
    Oil Shell Helix Ultra 5W40 11L 25-4-2018
    Thermostat 1 25-4-2018
    Oil Filter 1 25-4-2018
    Wear block chain Tensioner 1 25-4-2018
    Replace Kluber Grease 1 20-5-2018
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Fabate87
    Fabate87 Karting
    Feb 16, 2014
    51
    Chicago
  3. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Hello Asking 62500 euro.
    Grts
    Patrick
  4. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  5. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    On youtube :
  6. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Another one.
