Vetroresina 308s | Page 17 | FerrariChat
Vetroresina 308s
Discussion in 'Australia' started by carl888, Dec 3, 2010.
  1. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Melbourne, Australia
    Brett
    As they say, don't stop darling, keep going. :)
  2. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,933
    Carl
    Yes pumpkin :)
  3. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Peter
    I wouldn't want one even if it was a gift.
  4. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    Oh bugger, I'd bought one for your birthday. I guess I'll have to keep it now. :p
  5. Aircon
    100,524
    Peter
    MODIFIED!!
  6. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    Sshhhhh, don't tell Horse. I changed the spark plugs and he wanted to put me in modified. :p
  7. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    35,417
    Brisvegas
    Jon
    It's ok, cheat all you like.
    You're the one who has to live with it.
  8. Ossie
    Ossie Formula Junior
    May 20, 2009
    666
    Owen
    #408 Ossie, Feb 4, 2011
    Going back to my 76 GTB rear indicator lenses, I finally got around to checking both and they were manufactured by SIEM, numbered 9255, SAE I 74 DOT. This suggests to me they are original, including the one I purchased from Cavallino in 2009 (?)
    My brake lenses are however are mismatched which I knew about. One appears to be original and labelled SIEM 9252 SAE ST 74 DOT and has a single globe, the other is a Carello lens with the twin globe form a later 308. If anyone knows where I can get the correct single globe variety please let me know. Thanks
  9. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,933
    Carl
    360c's place after midnight.
  10. Aircon
    100,524
    Peter
    So despite what the specs say, my car actually had 150lb springs in the front and 160lb in the rear.
    No wonder it was like driving marshmallow.
  11. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,324
    Wurundjeri man.
    Arvin Grajau
    that would be aweful like that.
    150ib in the front YUK.
  12. Ossie
    May 20, 2009
    666
    Owen
    So you meant that was what they were actually rated at (i.e. marked?) or did you get them tested to determine that?
  13. Aircon
    100,524
    Peter
    tested...that's the REAL figure.
  14. Ossie
    May 20, 2009
    666
    Owen
    Wow, I suspect I have the same issue. So did you go with the 350's in the end?
  15. Aircon
    100,524
    Peter
    nah...i chickened out. they recommended 30% increase in the springs and revalving front shocks and tightening rear.
    This was determined after checking springs, dynoing shockers, meeting my requests (ride height etc) and measuring suspension angles etc.
  16. Aircon
    100,524
    Peter
    oh...and if your springs are standard, then yes, I suspect they'll be the same....but maybe they got the aussie spec wrong and the euro spec right on that sheet, which claims 200lb springs front and rear.
    I'll compare the rest of the spec of the spring when i get them back.
  17. Arvin Grajau
    Jun 7, 2006
    78,324
    Wurundjeri man.
    Arvin Grajau
    any idea a boxers spring IB?
  18. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    my front springs were running at 160, put them back to factory specs, 200 front 185 rear, which seems strange as the engine is at the rear :confused:
  19. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    Could be why it won't turn corners Morett's. :) If it's too stiff at the front end you'll probably experience understeer, hence front spoiler damage. Only IMO opinion of course. ;)
  20. moretti
    Nov 1, 2003
    59,757
    Australia
    nothing wrong with the car ..... the driver is the problem, he's an idiot :(
  21. Aircon
    100,524
    Peter
    errrrrrrrr
    that makes no sense.
    160 front IS standard, but the rear is meant to be harder. Who's giving you crap advice? You probably.
  22. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,933
    Carl
    Remember there is the spring rate, that's as you simply measure the spring. Then there is the effective spring rate with the spring/damper unit installed. On a 308, the spring/damper unit doesn't have the same pick up points. It's further outboard on the rear from memory.
  23. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,933
    Carl
    what's it to you, you'll never afford one.
  24. Aircon
    100,524
    Peter
    Well here we go...despite the ferrari bulletin rating our spring at 200lb/inch it seems that using any amount of calculators on the net give a front rating of 166lb/inch and a rear of 169lb/inch.
    pretty much exactly what they were measured as.
    http://guzzitech.com/springrate.html
  25. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Brett
    #425 b27, Feb 12, 2011
    That's very interesting. My only question is they are assuming that the springs are made from the same material based on the inputs in that formula. I would have thought there would be many different varaiants on the spring steel used?? So for example you could have 2 springs with the same diameter and same number of coils but different spring steel compound hence giving a different lb/inch result? I don't know the answer, just asking the question. Any comments from someone who knows.
    Perhaps I should ask Horse, no time to look up Google.
