Vetroresina question | FerrariChat
Discussion in '308/328' started by bigodino, Nov 17, 2009.
  1. bigodino
    bigodino F1 World Champ
    13,127
    The Netherlands
    Peter den Biggelaar
    Does anyone know the answer to the following question:
    exactly which seams on the resina 308's have black sealer over the paint please? I have attempted a search on fchat, but found nothing conclusive. I know the rear buttress seams & tops of the front wings should be sealed over, but should the top of the windscreen pillar, upper sill seams (where they sit below the rear quarter & lower front wing panels) and the sill seam in the door shut (at the bottom of the B post) be sealed also?
    Many thanks in advance.
    Best regards, Peter
  2. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,575
    Avvocato
    all i see on my car is on the bottom of the front windshield both sides to where the hood (fenders) are the black ....on top where the roof line is i dont see any black...might be underneath the paint, but it does not expose. I can only presume this is correct as my car still has the original paint.
  3. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    What's "vetroresina"? Does that mean you have a fiberglass body?
    I guess that means everyone else has a "Acciaio" 308. Or, we could just use English and say "steel" body, but maybe that doesn't sound fancy enough....
  4. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    My half assed Latin etymology fuzzy logic tells me that probably translates into glass resin, or as we say fiberglass, unless it is Owen Corning Fiberglas(TM). :)
    Doug
  5. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    In Europe, that's how the fiberglass 308's are called.
  6. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    In ITALY actually, to be a bit more precise.
    Marcel Massini
  7. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    I stand corrected ;)
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Vetroresina is a more descriptive technical term which fully explains the material and has a melodic sound. "I met the beautiful Vetroresina on Capri."
    Glass reinforced plastic, as it was initially called, was too long for those outside the industry to say, as was fiberglass reinforced polyester and fiberglass reinforced epoxy.
    The process replaced the cotton reinforced textile-phenolic resin or bakelite process when two part plastics were born.
    Half the world now speaks English and the US is finally getting there.
  9. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Peter,
    I cannot answer your question totally, but maybe there's some information in the following:
    In the early eighties, a friend from Amsterdam, Albert Lauw, bought a argento/red vetroresina from Germany (owner also had a NART spyder). The car was used, but at some 24.000kms and absolutely original.
    We went over the car and he actually pointed out to me 2 points of weakness in the glass body: the point where the front fenders meet the A-pillars (NO gunk) and the lip of the decklid, cracking from shutting it.
    Unfortunately I don't have the chassis number of the car, as we might find that this was a recognised problem early in the production, and later examples may have that joint sealed, but this one didn't.
    Cheers,
    Jack.
  10. vetroresina
    vetroresina Karting
    Dec 20, 2005
    174
    Netherlands & Germany
    Marcel
    Hello Peter,
    all the seams are without paint, just the black sealer as it is. The reason is not chosen from an estetic piont of view but pure practical. Every attached bodypart is prone to move somewhat and paint is not the best way to prevent it and could crack at a certain moment.
    Overpainted seams are obvious repainted because the factory sealed the seams after painting. It would be asking for trouble to do otherwise. (my reference from one who's working at the factory in Maranello)
    By the way, I like the word Vetroresina, as it is Italian, wich is in my modest opinion a perfect way to keep things in perspective as it should be......Italian....like Ferrari.
    Good luck Peter!
    Best regards,
    Marcel
  11. bigodino
    13,127
    The Netherlands
    Peter den Biggelaar
    Thanks all, your answers have been very helpful.
    Best, Peter
  12. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    Except for the Beer drinking guys' response.....:)
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I must be a philistine like Cliff because I say Fiberglass too. :)
