VHS to CD question | FerrariChat
VHS to CD question
Discussion in 'Other Off Topic Forum' started by 308geo, Apr 13, 2006.
  1. 308geo
    308geo F1 Rookie
    Nov 13, 2002
    2,751
    Houston, TX
    George Benton LaFleur
    Does anyone know what is involved (equipment & expense) of converting VHS tapes to CD format? Just call a service in the phone book or ??? Looking to copy some VHS tapes to CD format for preseervation sake (OLD tapes of shows & movies).
  2. icantdrv55
    icantdrv55 Karting
    Aug 13, 2005
    189
    Hartfordish, CT
    Chris
    There are a number of ways to go about this type of thing. But first I have to ask, do you really mean CD? Or are you actually talking about DVD (i.e. similar to the type of disc you rent at Blockbuster & playable in a set-top DVD player)?
  3. Pranucci
    Pranucci Formula 3 Silver Subscribed
    Mar 17, 2005
    1,134
    Carpinteria, CA
    You need to covert the VHS to a digital signal, store it on your hard drive and then burn a DVD. If you have a newer Mac it is already on there with iMovie and iDVD. Getting into the computer is the hard part. Easiest way that I've found is to use a Sony camcorder that passes through the signal to the computer. Otherwise you have to copy the VHS to Hi8 and then play the Hi8 into the computer. Using passthrough saves time.Video takes lots of space, too.
  4. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    Actually, you won't be converting to CD, more correctly, you will be converting to DVD. CD (compact disc) is the common terminology for a music (audio only) disc. DVD (digital video disc) is the common terminology for a disc that contains audio AND video.
    You will need a recordable DVD deck and recordable DVDs.
    The recordable DVDs come in 4 formats:
    DVD-R is an older RECORD only disc. Record one time and that's it.
    DVD-RW is an older RECORD and reWriteable disc. You can record and reWrite multiple times like recording on a tape.
    DVD+R is the newer RECORD only disc. Record one time and that's it.
    DVD+RW is the newer RECORD and reWriteable disc. You can record and reWrite multiple times like recording on a tape. But the DVD+RW and the DVD-RW formats may have problems playing back on the older decks.
    All boiled down in a nutshell, buy yourself a DVD recorder that records on the DVD+RW discs and you can copy your movies. (provided that they are not commercially recorded VHS tapes that will probably include a copy protection signal called Macrovision). You will have to run 3 patch cords from your VHS playback deck to your DVD recorder. One cable for VIDEO, one for LEFT channel audio and one for RIGHT channel audio.
  5. ylshih
    ylshih Shogun Assassin Honorary Owner
    Mar 21, 2004
    20,508
    Northern CA
    Yin
    1) You can run the VHS output to a DVD recorder, but those are still a bit expensive.
    2) You can use this device, which can hook-up between a VHS player and a PC that is DV camcorder enabled (has Firewire port and software). Sony has discontinued the example here, but you might find one for cheap on ebay or some other companies still make similar ones (Canopus) but are expensive.
    http://www.insanely-great.com/reviews/da1.html
    3) If you have a DV camcorder, you can play the VHS output to a DV camcorder input to record to DV tape, then connect the DV camcorder to a PC that is DV camcorder enabled (has Firewire port and software) and replay the tape and have the PC capture it.
    4) You can buy a hardware card (<$100?) to add to your PC that takes analog video/audio in and converts to MPEG, then play the VHS output directly to your PC and have the card capture it.
    E.g. http://www.shopping.com/xPF-Sigma_Design_REALmagic_Xcard
    Once the media content is on a PC, then you can encode as a VCD or DVD depending on if you have a CD or DVD writer or both. Most DVD players and PC's will play VCD's if you only have a CD writer. As far as resolution (video quality) is concerned, a signal sourced from VHS will only have VCD resolution anyway.
  6. mrdigital
    mrdigital Formula Junior
    Nov 1, 2003
    515
    Nashville
  7. MrScarface
    MrScarface Formula 3 BANNED
    Aug 8, 2005
    1,093
    Austin
    Adam
