vibrating gear box | FerrariChat
vibrating gear box
Discussion in '348/355' started by jorhalle, Jan 26, 2009.
  1. jorhalle
    jorhalle Karting
    Jul 6, 2007
    54
    #1 jorhalle, Jan 26, 2009
    I have a vibrating gear SHIFTER between 2nd gear, and 3rd gear , can anyone explain?
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Gearbox or gear shifter ?
  3. f355spider
    f355spider F1 World Champ
    18,045
    Yes, do you mean the shifter is rattling in the gate? Also, what model car? Many times this only requires an adjustment of the shift lever from under the car.
  4. jorhalle
    jorhalle Karting
    Jul 6, 2007
    54
    GEAR SHIFTER
  5. billyfitness
    billyfitness Formula Junior
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    I had that too some time ago. There are a few parts in there that eventually wear, a spring and a couple of plastic 'pucks'. A very inexpensive job BUT I think that you have to pull the box out from underneath meaning you have to take off the undertray too. Cheap job...more labor. Call Ricambi.
    -Billy
  6. Oengus
    Oengus F1 World Champ
    Thats true...my 355 had the same issue
    there are a few plastic bits that eventually wear out.
    the undertray needs to be removed in order to replace them
  7. f355spider
    18,045
    +2, had mine done at Ferrari of Seattle. Adjustment was not enough, bushings were worn and need replacement. Not too bad on parts, but a bit of labor...got expensive fast. :( But no more rattles! :)
  8. F129b
    F129b Formula Junior
    Feb 6, 2004
    523
    oc, calif.
    Robert
    I have a pronounced vibration in 3rd. Seems to be worse when cold, but it's generally always present. I'm curious to hear what you find out about cause, parts and labor. Good luck!
  9. f355spider
    18,045
    #9 f355spider, Jan 27, 2009
    As previously mentioned, you start with making sure the adjustment of the shift lever is correctly centered in the gate. If not, it can be adjusted near the gear box...follow the rod linkage back to the gear box and you will see where there are two sections that meet up, and are held by two or three bolts. There will be yellow paint markings too. The rod adjustment allows for it to be rotated a bit, clockwise or counter clockwise. If adjustment cannot correct the rattle, it may be caused by excessive play in the system, due to wear in the nylon bushings throughout. This will require disassembly and installation of the new parts, then reassembly and adjustment. That is what mine required, after several adjustments were found to not work. I am sure if you search the archives, there are threads on both the adjustment procedure, as well as the rebuild process with part numbers.
  10. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #10 gothspeed, Jan 27, 2009
  11. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    That was the thread ............... I changed that #10 part out and it still buzzes ....... :( .................... I will look deeper into it when I get my exhaust done ............... :cool:
  13. F129b
    Feb 6, 2004
    523
    oc, calif.
    Robert
    Damn, I was getting excited to have a $20 Fix (+labor). Please keep us posted Goth.
  14. billyfitness
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    I got lucky and only had to replace parts 20-23 to solve my problem.
    Damn, I think the car heard that and something else just broke.
    -Billy
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    It was a lot of work to change out #10 :( ............ it was a bit dissapointing to find out it did not solve it .... though it did 'tighten the feel' an inkling :eek: ............ I am gonna try #s 46, 29 and 27 next time.
  16. copterjon
    copterjon Formula 3
    1,541
    Mesa, Az.
    How 'bout them 348's with buzzing-vibrating shifters? Mine has been doing this for about a year now and it drives my wife so crazy she won't get in the car anymore. This occurs with the clutch both engaged and disengaged and seems to be RPM dependant. If I hold the shift lever I can get it to go quiet. I guess the wife just doesn't want to hold my knob the whole time we're driving...lol:D
  17. f355spider
    18,045
    #17 f355spider, Jan 28, 2009
    When Ferrari of Seattle did mine, they replaced all the bushings...between parts and about four hours labor, it was over $800 fix. When I first got it back, it was TIGHT. As if something were not right...but it loosened a bit over time, and feels just right now, 10 months later.
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    That price sounds reasonable if it included parts ......... :) ............ I will certainly get into this again .......... after my exhaust is done ........ :eek:
