video card questions : help ! | FerrariChat
Discussion in 'Other Off Topic Forum' started by thecarreaper, Nov 24, 2006.
  1. thecarreaper
    thecarreaper F1 World Champ
    18,094
    Savannah
    i am running a Gigabyte GA-7N400-L board with 1.5 g of RAM with an AMD 2800 +. also running a 450 watt power supply.
    my old GeForce 128mb FX5900XT is not cutting it anymore.
    since i am limited to AGP cards, and my motherboard seems to have nVidia / GeForce stuff on it from the manufacturer, do i have to use nVidia / GeForce cards only?
    can i use a quality 256mb ATI card?
    seems a GeForce 7600 GS series is a good card for the price.
    while a ATI 1300 series is its competion. (?)
    i barely understand how to compare cards and what features do what.
    i do seem to understand a card with a cooling fan is better than one without.
    there is a EVGA 7600 256MB card on Newegg ( not in stock of course) that has a fan. does the fan make that big a difference in performance , when comparing a 7600 to a 7600 ? ( with versus without fan)
    any helpful pointers would be very much appriciated. cost is not as much an issue as is simplicity. i dont want to have to mess with a bunch of stuff to get a new card to work.
    the 512 cards dont seem to be "that" much better than the 256 cards, and are much more expensive. but i will gladly take any advice with regards to 512mb cards as well!
    i am only a casual gamer, and stability/reliabilty is more important than "top speed".
  2. tjacoby
    tjacoby F1 Rookie
    Nov 1, 2003
    2,857
    Vancouver Canada
    tj
    AMD owns ATI now - so in theory their drivers might work together a bit better. But in practice I think nVidia has a bit of an advantage for stability. Any AGP video card should do the trick.
    More money = more detail and smoothness in the 3d games.
  3. Whisky
    Whisky Three Time F1 World Champ
    32,087
    In the flight path to Offutt
    The original Fernando
  4. Martin H
    Martin H Formula Junior
    Sep 29, 2006
    588
    Yorkshire, UK
    Martin H
    No, you do not have to use an nVidia graphics card because the motherboard has an nVidia chip set. ATI will work perfectly well and it’s doubtful there’d be any performance or stability advantage to an nVidia graphics cards based on motherboard compatibility. I’ve built many systems over the years using both nVidia and ATI graphics and, once established software drivers are available, have never found one brand to be more stable than the other.
    Bare in mind when choosing graphics cards, the cooling fans can create a fair noise, and while the fanless designs are silent, they tend to increase the temperature inside the case a bit, you need good case fans and air flow to make the most of these.
    Also with MS Vista on the horizon and the possibility of direct X 10 games and graphics cards becoming the norm in the future, I’d want to limit my investment in a graphics card right now.
    This is all probably more info than you want. So, assuming you’re running games at say a resolution of 1280 x 1024 and not some 24” monitor set up, then 256MB should be sufficient. I’d go for a nVidia GT (7600 or 7800) series, they have faster memory than the GS series. In the UK market right now I’m not aware of ATI having AGP cards that can compete with these.
    Hope this helps
  5. thecarreaper
    18,094
    Savannah
    thank you so much for that link, and for all the replys!
    i now have a good direction to go in!
    i know AGP is on its way out. i just want my decktop pc to be viable for about one more year before i upgrade the motherboard. i will look at the upper 256mb cards and see what i can get.
  6. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    Speaking of graphics cards...
    I got a PC that has a built in graphics card (ATI Radeon Express 200). It is a Celeron D 3.2Ghz so its not the fastest, but I want to be able to play battlefield and americas army at a reasonable resolution and framerate.
    What video card for around the $200-250 range would be good? Its got a PCI express x16 slot thats available. Its hooked up to a 19" LCD monitor that has a native resolution of 1280x1024 so *ideally* I could run maybe 30-40fps at that resolution, but if not, then as long as I could do maybe 800x600 or 1024x768 at 30-40fps I would be happy.
    Is there such a card? What do you recommend?
  7. WJHMH
    WJHMH Two Time F1 World Champ
    26,509
    Panther City, Texas
    WJHMH
    I have a ATI Radeon X1600 256 MB that came with my MacBook Pro, I haven't tested it out yet with any games. From what I understand it's about as fast as the Nvidia 7200 card. My main problem is I'm limited to what types of games for my Mac.
    My old Windows machine has a 5200FX with 256 MB video card, runs Battlefield II ok but very slow with Quake 4.
    I spoke with someone at Quakecon this year about the Nvidia 7600 cards, nice card but you got to have strong power supply to run it & an excellent cooling system. You should be fine with that choice.
  8. Whisky
    32,087
    You are a lot better off asking this on some tech sites or gaming sites.
    I gave up trying to keep up with hardware 8 years ago, everything I have is absolutely ancient - and works great for what I need (I don't 'game').
  9. SRT Mike
    Oct 31, 2003
    23,343
    Taxachusetts
    Yeah, I am sure you are right.
    I gave up too - I used to be so into it but it seems to be changing so quickly. I dont know the difference between terms like dual core, core duo, core duo extreme, extreme edition, hyperthreading, xeon, celeron, and things like XP, XP2, 64, Opteron, Sempron and all that on the AMD side. I was at Staples a couple weeks back and saw a PCI version of an ATI Radeon X1300. I thought the PCI bus was a tad slow for a fast GFX card, but I know that around a year or so ago, an ATI Radeon X850 Pro was the baddest of the bad, so X1300 sounded superior. Well, after poring over specs, it seems its not. Its *extremely* confusing for someone who doesn't read the trade pubs to make an on-the-spot decision regarding what hardware to get. They are likely to go into Circuit City and get an ill-fitting recommendation by a 16-year old kid who doesn't know jack, and then have a bad experience (or not as fulfilling as they wanted) with the hardware, leaving a bad taste on that brand of product. IMO the hardware OEMs are doing themselves a disservice by making it so convoluted.
    I remember when a Celeron was a Pentium with the cache disabled and a slower bus... now there are a TON of different celeron types with varying features. Oy vey!
  10. thecarreaper
    18,094
    Savannah
    hit the nail on the head, i have been wading through a morass of data, just trying to figure out if a card will work. :)
    comparing one to the other seems to be a trade secret. the link the the site above really helps dummies like me compare 2 cards.
