view and edit motronic maps! | FerrariChat
Discussion in 'Technical Q&A' started by f1karting, Jan 6, 2010.
  1. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
  2. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    I contacted the developer and he is willing to test his application on the 2.7 and 5.2 if we can send him a binery file from the motronic.
    Anyone know to do this?? Jan
  3. fatbillybob
    Aug 10, 2002
    28,634
    socal
    Wow if it works on 5.2 its a gold mind! Keep us posted. NoDoubt is the guru for the motronic 2.7. He says that the 5.2 is another level of complexity.
  4. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    Developer has asked for PN for the chip (apparently Infineon) or for the Motronic ECU.. he has some Ferrari binary filesand can narrow it down if he has PN. J
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    YES!!!
    This is KICKASS! I wonder if you can use it to see and tune live?
  6. ernie
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    As fatbillybob said, hit up NoDoubt, he has that sort of info on the chips.
  7. fatbillybob
    Aug 10, 2002
    28,634
    socal
    Whats that? You mean the number on the prom chip inside the ecu or the ECU number on the motronic box?
  8. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    #8 f1karting, Jan 8, 2010
  9. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    Sure can... Add a chip emulator to your laptop and tune away.
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If he wants to map and send us pictures, I can email him the binary file of the M2.7 chip that I programmed myself, which shouldn't violate any Ferrari copyrights. Post up his email address.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Motronic 2.7 uses the classic M27C256B EPROM chips, 90uS or faster will work fine.
  12. fatbillybob
    Aug 10, 2002
    28,634
    socal
    ND,
    Maybe you can checkout what this guy has and if it is 5.2 useable. I just don't understand the language of motornic.
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    M5.2 is probably protected at the chip level (5.2 software is stored in memory, not on chips, but the chips control access) by Ferrari from outside viewing/editing. Those who do it have probably gotten insider help from someone at Ferrari Spa.
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,718
    Lake Villa IL
    So basically you do not think this- http://www.thedmeeditor.com/ will be usable with the 5.2?
  15. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Not a chance. That's a good looking OBD1 chip editor.
    In contrast, M5.2 is OBD2 and requires a computer interface and probably an encryption/decryption key or at least a password.
    Looks like that editor works for the Fiat Punto's M2.7, though...so it should be comparitively easy to get it to work on the Ferrari 348's and 1995 F355's M2.7 chips.
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,132
    Dumpster Fire #31
    SMG
    ( LNDSHRK ) Jim Conforti is on here somewhere and he may have some ideas. I know that he's done a massive amount of ECU programming on the bosch motronics in the BMW arena. I recall back in '00 that to program the new BMW's we'd have to interface with the DME and make a copy of the code then in order to access it there was a key that had something to do with the VIN.
    in any case a conversation with Jim somewhere in '03~'04 he mentioned trying to 'crack' the 360 code for the aftermarket. I haven't followed up since then, but I imagine that he's got some good ideas or options for the 5.2.
  17. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    [email protected]
    ..the developer also mentioned to me:
    "..actually it is more modern than that. It does not have a removable chip. It is OBD2 with an internal soldered in memory chip.
    Ferrari 355
    0261204186"
    1037355417
    (CC460 chip 68 plcc)
    You would use a GALLETTO 1250 EOBDII ECU FLASHER and a laptop to write to the chip.
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Post 1990 Ferrari 348's, 355 Challenges, and 1995 355's = M2.7 = OBD1 = chip-based fuel maps
    All other Ferrari 355's = M5.2 = OBD2 = Flash memory fuel maps
    Flash memory requires an ECU flasher *and* permission to flash (often a password or decryption key, based on how the manufacturer set it up).
  19. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    Perhaps its a good time for you or Jim to start dialogue with the developer and find out just what his app is capable of.. he seems to believe 5.2 is doable.. perhaps he is mistaken.
    Maybe, between the experts, it can be worked out.
  20. eric355
    eric355 Formula 3
    1,215
    Toulouse (France)
    Eric DECOUX
    The problem with the 5.2 is that, AFAIK, you need to unsolder the EEPROM to read its content. This is a huge risk if you don't have the proper equipment. The Galletto is supposed to be able to write, and only write, in the 5.2 but I never read a confirmation that it has been done successfully by somebody.
    There is an alternative to DMEeditor which is called WINOLS. This programme includes, among others, a feature to recognize, or at least to help to locate, the Bosch maps. A free demo version can be downloaded ... just google "winols"
  21. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    tough game this is.!!
  22. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    If I can find a spare 5.2 ECU as a test bed, Ill take on the task of getting the equipment needed and staff to work on a reliable method of reading the 5.2 eeprom/flash (if its possible).
    In this respect, any help is always welcome.
    As far as desoldering, I understand there are tools available that have fixtures that attached directly to EEPROM terminals on the board w/o desoldering??
  23. lndshrk
    lndshrk Formula Junior
    Nov 7, 2003
    753
    SLC, Utah
    Jim Conforti
    #23 lndshrk, Jan 24, 2010
    M5.2 uses a CC460 Bosch flash Eprom in a PLCC package. It's a custom part, and it's essentially unobtanium.
    You'll find only a handful of tools available to read them, even desoldered. Which, to do properly will require hot-air rework tools and big brass ones. (based on price of ecu and unobtanium chip)
    AFAIK, the Ferrari M5.2 cannot be read out via the OBD port - only written.
    Jim
    PS: I'll be releasing my tools in a short while - and the base level is...
    free.
    PPS: BTW guys, this "DMEEditor" seems to be similar to something I released back in 1997 - I guess imitation is flattery or something lol
  24. ernie
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    #24 ernie, Jan 25, 2010
    LONG time no see Jim.
    Welcome back.
    About your program. Can we actively program the 2.7 on a dyno with yours?
  25. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    Hi Jim.. good to hear from you..
    Isnt the CC460 Bosch the same as BMW and Porsche?
    I wonder what makes it seemingly unhackable??
    What tools do you have? may be interested. The big brass ones Ill have to polish up I guess :)
    As far as the dme editor goes, if its a development on your work then I guess that's a positive growth in technology.. if not, then it needs to be :)
