view and edit motronic maps! | Page 5 | FerrariChat
Discussion in 'Technical Q&A' started by f1karting, Jan 6, 2010.
  1. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
    Can you post the bin you read off of this chip? I would really like to compare the full reads.
    I will post a full read I have by obd later when I get home.
    If you are not sure about sharing your file here maybe you can use the file I post and compare it to your read and see if they contain data in the same addresses ?
    Is this a 474 DME or a Ferrari one?
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Sorry was so long ago I have nothing left, sold it all off
  3. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
  4. brogenville
    brogenville Formula 3
    2,329
    Robin
  5. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
    This is a bmw 4.4l v8 from an e38.
    Does anyone have internal pictures of the Ferrari M5.2?
    brogenville likes this.
  6. Qavion
    Qavion F1 World Champ
    14,639
    Ian Riddell
    By “pictures”, do you mean photos or something more technical?
  7. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
  8. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
    Lol any datasheet to anything related to this DME would be great
  9. Qavion
    14,639
    Ian Riddell
  10. Jmateo762
    Jmateo762 Rookie
    Jan 9, 2024
    13
    Santo Domingo
    Jorge Mateo
    Thanks, at least thats something.
    That is no performance chip and that is not the immobilizer chip.
    The only thing that confirms is that the ferrari DME uses the older style components. (Resistors) and the 30117 Knock Sensor IC is the older stock on this DME just like the V12 BMW DME.
    The BMW V8 DME uses the 30301 Knock Sensor IC.
    The K-Line ic on the BMW v8 is 30309
    The DME pictured uses the 30310 K-Line IC
  11. Qavion
    14,639
    Ian Riddell
    Ok. Thanks. I was just relying on what someone else had said or what I had seen online.
    e.g. https://www.ferrarichat.com/forum/posts/143360389/ (I found the source of the photo)
    I guess @gobble would know for sure.
    Jmateo762 likes this.
  12. brogenville
    2,329
    Robin
    Bumping this in case anyone has an update on reading and writing the 355 (5.2) ecu?
    It's been said above that galetto only gives a partial read... is this a problem? i.e. when tuning, you're only really editing a few bits normally, so maybe the part that it can read contains all the important stuff you might want to tweak? In my case I want to switch it from F1 to manual.
