is there a way to remove viewpoint from my lap top? i have gone on line and looked but the remedy suggested does not work. can anyone walk me through this removal process or suggest an other way or company to do so? pcb
Boot in Safe Mode (F8) 1. Close all Internet Explorer windows. If you also have AOL and or AIM installed on your computer, you must close those applications. 2. From the lower left corner of the desktop, click the Start menu. 3. Click the Settings menu and select Control Panel (switch to the Classic View if using XP). Your selection opens a separate window. 4. From the Control Panel window, click Add or Remove Programs. Your selection opens a separate window. 5. From the Add or Remove Programs window, find the Viewpoint Toolbar entry and click the Change/Remove button. All associated files and folders will be removed from your computer.
thank you but what if i am unable to find any viewpoint related items in the add or delete field? or, will they only appear when oppening in safe mode? thanks. pcb
Sometimes, things appear in safe mode that don't in regular mode. If that doesn't work, download ccleaner and run it.
