Vignale spyder #504 restoration | Page 12 | FerrariChat
Discussion in 'Maserati' started by thecarnut, Jul 13, 2009.
  1. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    I prefer to drive the car to events. The judges are a lot more lenient with dead bugs on the bumper when the car was driven :)
    Also there are the bragging rights of saying "I drove the car here" and you can tell your experiences of driving the car to people at the event. Lastly, part of the fun is constantly worrying if the car will self destruct and you will miss the whole thing!
    Ivan
  2. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #277 thecarnut, May 16, 2011
    The two ignition coils were painted and decals attached.
    Parker Hall, Kilimanjaro Designs, 601-638-7856 sells Ferrari restoration parts, some which were also used on early Maseratis. He provided the correct paint color in a rattle can, plus the decals. He also provided the two metal plates which attach to the air cleaner.
    Ivan
  3. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #278 thecarnut, May 16, 2011
    Heat insulation around the interior firewall area was originally provided by a layer of insulation material (similar to what you would find in your home) sandwiched between the car's body and aluminum panels. The original insulation material is prone to collect moister, plus it may have asbestos, so I opted for a better insulator.
    I am using a material made by Koolmat, which they claim is used by 80% of NASCAR cars. For originality, I sandwiched the Koolmat material using the aluminum panels and original screw holes. I even re -used the original washers.
    Ivan
  4. mfletch
    mfletch Formula Junior
    Nov 3, 2008
    480
    #279 mfletch, May 16, 2011
    Hi Ivan, your project is looking great. It looks like we are working on many of the same parts. I just bought similar heat insulation material two days ago, to line the tunnel and exhaust passage areas. My inside firewall insulation looks like new, so I am going to leave it alone. The heat insulation in the exhaust passage was a mess. It is the reason that I decided to spend several months cleaning the underside of my car.
    Do you know where I can purchase the air intake hoses (100mm etc.)? I am also in need of a single Cheney hose clamp for the upper radiator hose, if you have any idea where I can find one. I did need three, but I found two on an old XKE engine that is sitting in my dad's shed. Thanks for posting your progress.
    I bought my coil decals & paint from Parker Hall. I searched numerous 3500 GT pictures on the internet before deciding to reinstall my coils where they were mounted when I took the car apart. I found them mounted where mine are (rarely) and on the passenger firewall. I am trying to decide how I will finish my air cleaner. Do you have any pictures of what your's looks like and what they looked like from the factory? Mine is satin black with no decals or metal ID plates. Thanks again.
  5. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    #280 Portenos, May 16, 2011
    For reference here are the original untouched coils and air cleaner housing as fitted to the Mitchell 3500 101.708.
    Note: the air cleaner had a very fine nickel plating which as you can see is/has been flaking off over the years. I would NOT paint it as some have done.
    Ciao,
    FGM
  6. mfletch
    Nov 3, 2008
    480
    Thanks for the pictures Frank. Do you have any advice on what finishes to have the air cleaner done in, to look closest to original? Mine were painted by the previous owner. I will order the metal ID plates and sticker from Parker Hall. I agonized over the coil location. Mine do not ever appear to have been mounted on the firewall. My original radiator (which I am not installing, since the custom one is twice the size of the original) has the top hose one the other side. It is interesting how much variation there was between two cars that were made so close together. Your windshield washer reservoir is the correct one for my car...I have the mounting bracket, but no bottle. If you ever see one for sale, please let me know. Do you mind telling me again where you got the air hoses that you are replacing in the picture? Thanks.
  7. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #282 thecarnut, May 16, 2011
    I should be able to help you with the Cheney clamp. Please measure the diameter of your hose. If I have the clamp, you can have it. I am not to the point of having to worry about the intake hoses. Wasn't Frank recently hunting for these hoses?
    My car has the coils in the same location as Frank's. Also the air filter housing is the same with the metal plates and decal.
    Ivan
  8. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    Mfletch,
    There are two or three options here.
    The most cost effective would be http://www.newcoproducts.com/
    They are in LA and have the nearly correct 100mm hose in 22" lengths you will need to buy two pieces. They have good prices for the following sizes.
    100mm x 550mm 4" x 22"
    34mm x 260mm 1 1/4" x 10"
    80mm x 775mm 3-1/4 x 31"
    Second would be RE Originals (Matt Jones) they have the exact factory replacement.
    It is a little spendy but the correct stuff. I purchased both.
    I have the one from Matt tucked away and will use it later, when/if the judges discover the Newco one is not the exact one. Opps I let the cat out of the bag.
    The last option is Strada e Corsa (Att:Lennart) phone 31 for the Netherlands 023 542 0009 <hIp://www.stradaecorsa.com>
    They also have the original 100mm paper tube at 50 Euros per meter + shipping.
    Good luck.
    Ciao,
    FGM
  9. mfletch
    Nov 3, 2008
    480
    #284 mfletch, May 16, 2011
    Ivan, thanks for the kind offer. My hose is 1 3/4 inches outside diameter.
    Frank, thanks for the info. I will contact Reoriginals.
    Two last questions....can either of you tell me where to connect the wires on the back of the generator..one blue, one black. Also, I bought a heat shield from Larry for my starter. Can I install the mounting bracket by just removing the solenoid, or do I have to remove the entire starter? Thanks.
  10. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    #285 alberto, May 16, 2011
    Is it an image thing, or are the coil colors between what Kilimanjaro gave you and the original ones on Porteno's pictures different?
    Great pics guys. Love those details, always sweat the small stuff.
  11. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Look at the original coils on post #279 from mfletch and compare the color to my painted coils on post #277. You will see that both have the same deep red (almost burgundy) color. Digital cameras sometimes do strange things with colors. I noticed the painted coils from mfletch appear to be much brighter, but we both used the same paint color therefore it is most likely the camera.
    Ivan
  12. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    I would suggest it is the 51 years of aging that makes the difference, not the digital camera.
    Ciao,
    FGM
  13. redfred84
    redfred84 Formula Junior
    Dec 24, 2010
    734
    SF Bay Area, USA
    I installed the starter shield on my starter a few years ago. I got them from Larry also. Mine went straight on, with the starter still on the car if I remember correctly, but I already had the bracket intact.
    On my buddies 3500, we had to remove the starter (actually, it was already off the car anyway), and had to rotate the bracket for the best fitment of the shield. It was easy to remove the starter, but we may have had to remove the brake booster, and attack via the wheel well.
    As for the coils, my originals seem a bit more red than maroon.
    RF.
  14. mfletch
    Nov 3, 2008
    480
    RF, thanks for the information on the starter shield. I will go ahead and remove the starter. It is the only accessory that I have not had off the engine....now I will be able to make it look like new under the heat shield.
  15. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #290 thecarnut, May 17, 2011
    My starter shield seems to have been originally a light gray color. I do not think it was paint; it appears to be some sort of light plating. Any ideas of how the shield should look?
    Ivan
  16. mfletch
    Nov 3, 2008
    480
    Ivan, I bought the mounting bracket for my starter shied in an ebay auction. In the picture that I posted, you can see that it appears to be the same finish as your starter shield. It is not painted. If it looks correct, I will have an expert ID the finish. I have my Porsche at a local shop (Brian Moore Restorations). He has been doing Maserati restorations for over 30 years. I will see him next week and I can ask him what the finish is on mine. I am bringing him my air cleaner base (for nickel plating), my trident (to identify the gold finish & restore it), and my trident surround (for chrome plating).
  17. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    No, I don't. But while you have that bad boy out, why not do a thermal ceramic coat on it first, then worry about the color last and save your starter from future grief? :)
    Ciao,
    George
  18. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    I wonder why this shield is even needed. The starter sits below the carbs where it should not be that hot. I would understand it on the V8 engines where the exhaust manifold is close to the starter, but on those engines the starter is not shielded.
    Ivan
  19. redfred84
    Dec 24, 2010
    734
    SF Bay Area, USA
    The shield over the starter is to guard against fuel spilling onto the starter from the carbs above. When ever the starter is employed, it generates a lot of arcing, or sparks. A leaky carb directly overhead could spell disaster.
    On my way to the Pismo Drive in Calif last month, I noticed a strong fuel smell, and rapid depletion of my fuel via the gas guage. Upon pulling off of the high way to investigate, my rear tires broke loose from the start at a green light. Something my little old 3500 never does. Upon opening the hood, a geyser of fuel was spewing out from the center carb! Seems the cap-nut that retains the filter screen on top of the Weber was loose, and dancing around on top of the carb. The fuel had totally covered the bottom of the car, and was drenching the right rear wheel, hence the wheel spin!
    Luckily the plug/nut was still there, so I was able to just re-install it, and tighten the others. I let the car air out for half an hour before attempting the starter, despite it having the shield. It was too flat of an area to bump start.
    Glad the carbs are on one side, and the exhaust on the other! RF.
  20. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,478
    Gentleman Racer
    + 1000......it's a FIRE shield not a heat shield!!!
  21. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #296 PSk, May 18, 2011
    Probably when new they just sprayed it quickly with some grey paint, or maybe even left it unpainted.
    Most definitely no exhaust manifolds were ever painted or coated when new (except Jaguars) but it is all the rage now, and if you turn up to an event with a bare metal exhaust everybody has a fit ... LOL. I will text this with my Alfa Romeo that I am attempting to restore to show condition, by sand blasting it and simply leaving it as Alfa intended. Yes it will start to rust ...
    BTW: I'm not knocking the coating of this particular exhaust I'm just making a point that now everybody asks what the original colour was when in some cases it was just bare metal, left to fend for itself. This has now become unacceptable.
    Pete
  22. flxzcat
    flxzcat Karting
    Sep 16, 2008
    143
    lake forest, ca.
    paul van der linden
    I would guess that it is galvanized plating which turns to a dull gray after many years.
    Cheers,
    Paul
  23. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    mfletch,
    I found a Cheney clamp, please PM me your mailing address.
    Ivan
  24. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Thanks, that makes sense. Just yesterday I had a 1966 Jaguar e-type spray fuel all over the starter when the rearmost carb's float decided it was tired of floating ... and sunk. No starter shield on the Jaguar engine. Weber floats seem to be much more reliable than the brass floats used on SU carbs.
    Ivan
  25. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    I have been debating what to do with the exhaust manifolds. I can beat blast them and leave them bare, which would be 100% original but they would rust before the first drive. I have seen some cars with black or silver "jet coat", but that looks to me as too far removed from original.
    I have a can of Eastwood exhaust manifold paint in cast iron color that should provide the proper protection while maintaining the original look. Does anyone have experience using this product and does it look proper?
    Ivan
