Vignale spyder #504 restoration | Page 19 | FerrariChat
Discussion in 'Maserati' started by thecarnut, Jul 13, 2009.
  1. veloce49
    veloce49 Karting
    Jun 20, 2010
    173
    Chevy Chase MD
    That car is stunning!
    Ivan - your garage looks cleaner than my bachelor kitchen.
  2. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Bernhard,
    I currently do not know of any 3500 or A6 project cars. The pre-molded Vignale spyder windscreen seal would have not worked on this car. Fortunately the profile of the rubber was very similar and MIE had the rubber. Making the gasket was not too difficult. It was a good thing I kept the old seal as it provided us with the correct angles.
    Ivan
  3. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #453 thecarnut, Nov 12, 2011
    Originally the floors had foam that was covered with a black vinyl. Over time the foam had turn into dust.
    In order to avoid rust I did not want to put foam over metal. Instead the floors were covered with a heat shield material that goes by the name of Koolmat.
    http://www.koolmat.com/
    The front floors then received a layer of dense foam. It is the same material that was used on vinyl tops years ago and it does not soak in water. Black vinyl was the last layer to make it look like the original.
    Ivan
  4. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #454 thecarnut, Nov 16, 2011
    This is one very funky soft top frame. It took me some time to figure out how it works, especially since I had installed the spring supports incorrectly. It is unlike anything I have seen on a Maserati before. The soft top tucks away behind the seats similar to an Alfa Giulietta spider. Unlike the Alfa, this frame expands sideways as it is being erected. It is hard to describe how it works but one has to be extremely careful to do things in the proper sequence or risk damaging some of the chrome pieces on top of the door pillar. The webbing, padding and top bow materials are the original. Still need to have the soft top made and fitted.
    Ivan
  5. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #455 thecarnut, Nov 16, 2011
  6. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #456 thecarnut, Nov 17, 2011
    The foam inside the sun visors has disintegrated and the visors look flat and skinny. These visors probably were used on some other car as they do not look hand made. Any suggestions as to where to get replacements?
    An alternative is to restore the originals. Only thing I can think of doing is to use a razor blade to cut along the molded seam that faces the windshield. Once the visor is re-stuffed then glue the seam back together. I am not really crazy about this idea. Any better ideas?
    Ivan
  7. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,478
    Gentleman Racer
    #457 3500 GT, Nov 17, 2011
    Ivan, I'm sure this has crossed your mind, but wouldn't it make sense this visor to be fabricated by hand. i.e. hand stiched? As we all know, "never say never" about "Maserati" building practices, but the visor doesn't look right. Maybe it's from a Lancia Appia Vignale, ALFA Sprint?
    How about early 3500 GT visors?
    I know SMS in Portland, OR. will fabricate new visors for you, but I know you want to keep it original. They may be able to re-foam your original and reseal them with their tooling.
    ...just my 2 cents.
    ~Trev
  8. mfletch
    mfletch Formula Junior
    Nov 3, 2008
    480
    Ivan it looks fantastic. I love how you are using as many of the original components as possible. Did you use additional screws to hold the door panel on? My door panels are only held on by three or four screws. I considered adding additional screws to attach them better.
  9. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    No additional holes were drilled. I used exactly the same number of screws and in their original holes. I am surprised your panels only have a few screws. Perhaps your panels originally had some internal clips in addition to the screws.
    Ivan
  10. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    I know the visors are correct since I have an identical set, in the same bad condition, from a 1961 Vignale spyder I restored years ago. On that car I had new visors stitched since I could not figure out how to fix the originals. Now almost 20 years later I am faced with the same dilemma.
    I was not familiar with SMS. I will call them tomorrow and see if they can help me. Thanks for the tip.
    Ivan
  11. lussoman
    lussoman Karting
    Sep 7, 2008
    132
    Ivan,
    These guys are really the best at reproducing the heated seam vinyl visors. I have used them for my Lusso and several Maseratis and they get it right every time.
    http://autosunvisors.com/restoration.htm
    Chris
  12. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Chris,
    This is great information! I called SMS earlier today and they are not really set up to do heated seams. It looks like thee guys do it all the time. I'll call them on Monday.
    Ivan
  13. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #463 thecarnut, Nov 19, 2011
  14. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    A great moment and it looks fantastic!
  15. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    stunning. congrats to you
  16. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    #466 thecarnut, Nov 20, 2011
    Thank you for the nice comments. I appreciate the help and encouragement I have received from the folks on this forum.
    With the hood now in place you can see how the bulge visually works with the windshield glass and instrument pod. Notice how the bottom of the glass gets hidden under the hood, fender and front of the door. Interesting concept but a design nightmare for the folks in the production line and most likely the reason it was never adopted.
    Ivan
  17. mairesse
    mairesse Karting
    Nov 20, 2009
    145
    London and Cotswolds
    Gordon
    Absolutely exquisite. Many congratulations.
  18. Mang
    Mang F1 Veteran
    Jul 11, 2007
    5,976
    ta HO
    Mike S.
    +1
  19. gopp
    gopp Karting
    Nov 2, 2009
    202
    Oslo, Norway
    Marius Sorteberg
    Congratulations on the first drive with the Spider, even if it was very short.
    Thanks for sharing the pictures!
    Ciao Marius
  20. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    8,987
    Ivan,
    geee - don`t know that the exhaust system is that massive!
    Ciao!
    Walter
  21. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    #471 gcmerak, Nov 20, 2011
    Way 2 Go!!!!!
    I know that garage. ;)
    Ciao,
    George
  22. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Walter,
    The exhaust system is hanging very low since it is only being held by plastic ties. Once it is tucked in its proper place it will not look that massive.
    I need to first fix the brakes then I take the car to a muffler shop and have the exhaust properly fitted. I live on top of a very steep hill therefore having working brakes is a very good thing. The price to pay for great mountain views are clutch unfriendly driveways.
    Ivan
  23. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Thanks George !
    Ivan
  24. wbaeumer
    wbaeumer F1 Veteran
    Mar 4, 2005
    8,987
    Ivan,
    also the A-pillars look higher than with the standart version. Am I wrong?
    Ciao!
    Walter
  25. thecarnut
    thecarnut F1 Rookie
    3,229
    Atlanta
    The Car Nut
    Interesting question ... time to take out the measuring tape.
    I doubt there is a single piece of sheet metal that is common between the early (504, 505, 673, 678) and standard spyders.
    This is what I measured using 2779 and 504: From the floor to the top of the door. standard = 92mm, early = 86 mm. From the top of the door to the top of the windshield: standard = 34mm, early = 38mm.
    The early car overall looks much lower to the ground even though the total height is only 2 mm less than the standard version. I think part of it is the visual effect of the early car sloping lower towards the rear.
    Ivan
