Visual | FerrariChat
Visual
Discussion in '348/355' started by 97spiderman, May 20, 2016.
  1. 97spiderman
    97spiderman Karting
    Dec 15, 2008
    107
    Sunny Buffalo, NY
    JohnAG
    Can the timing belts be viewed before any dis assembly? and if so is there any value to a visual inspection? I am being told a complete engine out service with new tensioner bearings was done less than six months, but naturally no paper trail.
  2. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    not sure.. but I think with the car lifted.. you can see the belts partially behind the covers as there are gaps..
  3. janders82
    janders82 Karting
    Nov 26, 2014
    180
    Atlanta, GA
    i don't think you'll be able to see and/or get much info from a visual...
    get the number to the shop where the work was said to be completed and give them a call. They'll have record of it if it actually happened.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    No paper trail = it's not been done.
    What I mean is, it may have been done but without the back up you must assume it's not been. No receipts of the purchase of parts at least? Seems fishy :)
  5. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    When I performed my engine out I documented the process with photos (including a newspaper next to my newly installed belts) of all the parts coming off and going on. Also a shot of the VIN next to that newspaper.
    And Daniel and I both have a record of the service kit I purchased from him.
    Even if he bought the service kit on eBay and did the work himself he should be able to show you something.
  6. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Have you called the shop that did the work? No shop, no receipts->PASS. My client sell their cars and the paperwork gets misplaced. We keep everything electronically for these kind of calls. You should expect the same.
  7. Ricambi America
    Sponsor Owner
    This brings up a good point about records retention.
    I always refuse to release any customer purchase history to the "would-be" buyer. If the original buyer calls and asks for an invoice copy (or several), that's fine and I'm happy to accommodate. But when a buyer calls and says, "hey, I'm about to buy so-and-so's car.... you know, the Fchatter!... can you send me the list of stuff he bought from you?" I pretty much flat out refuse. It probably doesn't win me many friends, but it hopefully honors the privacy between me and the customer.
    How often does this scenario play itself out? Probably several times a month.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I fully agree because your contract is with the purchaser of the parts. Many dealers will no longer provide records. Some do and when they do so, they block the names (address and details) of the ones that had the work done.
    This is the respectful (and perhaps) legal way to do it. We track our refinishing by VIN for warranty purposes. If I get a call inquiring, I will tell the prospect what parts we did but I won't tell them who the purchaser was and the amount charged.
    And, in your situation, how would anyone know the parts went on that particular car?
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,457
    San Carlos, CA
    Mitchell Le
    you won my friendship. Privacy is a right often compromised by many people including our government.
  10. yelcab
    Nov 29, 2001
    13,457
    San Carlos, CA
    Mitchell Le
    To the OP, you either do the service, or don't do the service, but there is no visual.
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    We're in complete agreement here. I just didn't articulate our policy as well as you did yours. Thank you. Expanding further, as these cars (potentially) become more valuable, the importance of records/recordkeeping increases.
  12. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    You did not indicate which model but on a 348 it is possible to remove one or both of the upper timing belt covers so that you can get a good view of the belt. From the other responses it sounds as though that might not be possible on a 355 though?
    I've seen photos of belts that otherwise look good but have teeth stripped off of them, so in most cases a visual inspection only tells you if the belt(s) is/are dry and tight. But you should be able to a good sense of whether the belt(s) was/were done within six months since everything should still look new and clean. If the belt(s) look worn and dirty at least you'd know for certain that the "within six months" claim was not true.
  13. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    Inspecting the belt doesn't tell the whole story except that maybe the belt isn't wearing. They stretch more than wear so how can you see that? Also, you have tensioners and a water pump that is part of the major, so belt inspection is going to miss that. Lastly, the alternator bearing can be inspected independently, but it's just better to do the whole job in an engine out.
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,196
    CT
    John Kreskovsky
    Having measured some well warn belts I'm going to have to disagree with the idea that there is any significant belt stretch. I found that after 27k miles and way more years on a set of belts than anyone would recommend, the length of an old belts was within the length of a new belt to within less than the manufactures tolerance for belt length.
  15. Signor Buona Wrencha
    Jun 21, 2008
    79
    Albuquerque
    Aaron
