VOLANT CARBON LED | FerrariChat
VOLANT CARBON LED
Discussion in '360/430' started by BOSSP, Mar 15, 2014.
  1. BOSSP
    BOSSP Rookie
    Feb 16, 2014
    5
    Bonjour j'ai installée un volant carbon led sur ma FERRARI 430 spider mai sa ne fonctionne ^pas correctement les led s'allumes a la mise du contact mai pas en roulant a 6000,7000... quel quint aurais la solution ,merci par avance FDM
  2. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Mange tout Rodney!
  3. F430giallomodena
    F430giallomodena Formula Junior
    Mar 2, 2012
    910
    Lugano, Switzerland
    2 cases: simply proxy software upgrade needed or complete change of your instrument board, depending on your VIN number. Your F-dealer should be able to tell you what you must do.
  4. guidwire
    guidwire Rookie
    Aug 19, 2013
    12
    Granite Bay
    Derek
    Do you happen to know where I can get the software upgrade done? I assume the software is for the controller in the steering wheel itself?
  5. spieler
    spieler Formula Junior
    Oct 13, 2012
    450
    miami florida
    Usuellement il faut upgrader le soft system tout simplement chez le dealer
  6. F430giallomodena
    Mar 2, 2012
    910
    Lugano, Switzerland
    Your
    f-dealer can do i did on my car since there was no connection to my LEDS wheel. But before dooing it ask your dealer if it's worth cause some older cars need complete new instrument board in order to communicate with wheel
  7. BOSSP
    BOSSP Rookie
    Feb 16, 2014
    5
    OK je vais voir demain avec FERRARI pour mise a jour ...
  8. guidwire
    guidwire Rookie
    Aug 19, 2013
    12
    Granite Bay
    Derek
    Thank you
