Voltage drop | FerrariChat
Voltage drop
Discussion in '365 GT4 2+2/400/412' started by Jaredsalinsky, Sep 10, 2024.
  1. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    I recently installed a New York AC compressor and clutch (for my AC resotration / conversion) and as we filled the system everything worked well, except the clutch was exhibiting a weird ‘slip and catch’ thing. My mechanic discerned we were not getting a good 12 volts at the wire to the clutch; rather we had between 10.5 and 11.5V. At that time with the car running we had roughly 13.7 at the alternator B+, and high 12’s / low 13’s at the battery. Similarly we only had 10.5-11.5V at the snowflake switch and blower control knob.
    I initially thought it might be the alternator…but now I’m not sure….I’ve read a few things on the forum including ‘beefing up’ the alternators, and I know voltage drops on our cars is not entirely rare. This weekend I was able to check the alternator / diodes and suspected voltage drop, and got some confusing results:
    - with the alternator disconnected and using 2 different multimeters (and with red lead on the alternator casing and black lead on the B+ post) I got 1380 and 911 respectively. Too high. Not sure why 2 different readings, and the second one is with a ‘newer’ (and probably more trustworthy) multimeter.
    - then I cleaned the connection and reattached the wire to the B+ post, and rechecked the diode test. Now I get a reading (with the better multimeter) of 690, and I checked it twice - once with the black lead on the B+ post, and then with the black lead on the battery, and got the same reading. BUT I read the test is only valid when the alternator is disconnected. Is there any truth to that?
    - then I turned the car on and checked the alternator (although not a full ‘load test’)- it was putting out 14.1V at the B+ post, and 13.6 at the battery. I also checked to make sure it wasn’t putting out and AC volts and it was not.
    - I did recheck the AC clutch wire and found 11.85V with the car running and the battery at 13.5V.
    - Lastly I checked voltage drop on the negative from alternator case to negative battery terminal and it was only 120mV, and then on the positive side from alternator to positive battery terminal and it was 0.46V, which seems like ‘borderline’ a lot. NOW, I know I need to do the voltage drop test on the positive side further and check at which connection most of the drop is getting lost; the ammeter shunt, relays, fuse boards etc….Although, I did check one relay (to the right radiator fan motor) and it was only 10.72V (car off, but ignition on)
    I may try the diode test again with a ‘really good expensive’ multimeter. I’m also going the change the voltage regulator with brushes just to see if it makes a difference in voltage output. And I may call Centerline Alfa in Colorado that ‘improves’ our alternators - maybe a better alternator does the trick?
    I suspect, and as I’ve read, that this is all fairly common with our cars and actually not so bad - although I’m not sure how to rectify the voltage issue at the AC clutch. Maybe install a separate AC clutch relay? It’s not like we can rewire the entire car, and honestly I feel my car’s wiring is…fairly pristine. Super clean and not much dirt, grime or cobwebs anywhere…
    Thank you and any opinions are welcomed..
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,416
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Jarrod,
    I think the first thing you need to do is to have a meter that you can trust, as the readings it presents will be critical to understanding the issues you are experiencing. Having a flakey meter can waste a lot of your time and lead you to an incorrect diagnoses of the issue.
    Assuming your voltage readings you presented are accurate (Battery 13.7V, Compressor around 11V), then this would not be an alternator/Battery issue... as the Alternator is doing its job given its the voltage output and having a battery present. The voltage drop (13.7 - 11.x) you are seeing is occurring across the compressor wiring, the associated fuse, and the connection to the battery. Each of these components have resistance which causes a voltage drop which is proportional to the current being supplied through this circuit (the relationship between these items is called Ohm's law). Ferrari's selection of wiring, etc is so-so at best and so its size and effective resistance is higher than it really should be for the high current loads. Consequently, as the current draw is increased, so will the voltage drop along with the wire self heating. The associated fuse is also part of this circuit, and it has its own resistance which increases if the fuse connecting surfaces, fuse clips, etc are oxidized... and so a voltage drop will occur across the fuse as well.. which also causes self heating. Now, if your new compressor draws more current than the original unit, then the resulting voltage drop may be higher... which may explain what you are seeing. That said, do not ignore this issue. As I said, Ferrari wiring is crap and uses extremely poor insulating material for its sheath that can melt or ignite if it gets hot enough (remember more current = more heat)... which can lead to catastrophic results. So... I would first check all of the existing wiring, its connections, and the fuse to ensure they are in excellent condition with no loose connections, etc. Clean the fuse(s), fuse clips, etc to ensure they maintain excellent contact. if all looks well here, then check the current being drawn by the compressor to see if it is within spec, but also to ensure that it is not more than say 75-80% of the rated fuse size. All of these items need to be thoroughly checked and if anything is amiss, then you need to dig deeper to understand why.
    Cheers,
    Sam
    Jaredsalinsky and Rahtok like this.
  3. Steve Magnusson
    26,606
    +1 -- Also, as an easy first check, measure the voltage drop across the high/low switch(es). The switch contacts inside may no be making the best connection anymore.
  4. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    guys - thanks for the input.
    Yes - I absolutely need a trustworthy multimeter. I may have fallen prey to the Amazon allure of the 'most often bought' item. I will correct this and buy a very good one. YGWYPF (you get what you pay for.....)
    I will indeed check the fuses and relays. All my wiring looks great, but I will double check as I certainly do not want this known issue get worse...
    When redoing the AC removed both the high and low pressure switches, and change them out to a single high/low pressure switch. I can easily check voltage drop across that. Since the power to the clutch comes from the snowflake switch I was secretly thinking I may have a bad (or going bad) snowflake switch. again I can check the voltage drop across that switch alone to check its status.
    visually my ammeter shunt and all associated wiring in and around the relay panel looks pristine. But again I will double check and take some picture documentation.
    thanks again.
  5. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,674
    Romulus, NY (Finger Lakes)
    Ken Battle
    Jared
    Please let us know model and year. If 400i what series. Wiring changed significantly Series I to II. Do you have a useable (large) wiring diagram?
    One thing I have done in troubleshooting low voltage is to use a jumper wire, to bypass each link in the circuit and measure the volts at the clutch for each item bypassed.
    I agree with Sam your alternator does not appear to be the issue. I upgraded one of my alternators because twice I had a flat battery on a long drive in the rain with lights, AC, wipers and all the normal stuff. I upgraded to 80 Amp; it's possible to go to 140 but unlikely with the little belts. The change to 80 A, raised the minimum RPM (about 1200 for mine) required to get it generating.
    Ken
  6. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    This is a '78 carb'd manual series 1.
    Yes I agree that changing the Alt likely will not remedy the issue.
    I absolutely need a better Multimeter, and I absolutely must do a better voltage drop test to isolate the circuit causing the drop. Using the jumper is a great idea, (although one of the first things we did the day we were changing the AC system and realized the low voltage was jumper battery to AC clutch and voila - worked fine)
    I do have a useable wiring diagram from my car! the original book! In fact, I went to Staples and had it enlarged and laminated! So now I can draw on it - then erase it!
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    The cables of the 400 do not look so bad to me (not sure about the 365). On mine I replaced the fuseblock, and replaced almost all fastin-faston connectors. This plus better grounding, and a more beefy positive harness between the ammeter and the fuseblock. No more issues (and still on the original cables)
    What I' seen though were ugly hacks made by the dealer in order to apply the non-italian high beam setup. The factory guidelines were loosely applied (with tons of insulation tape and twisted wires...), which played havoc with the rest.
    You should test voltage on the ammeter. Then from ammeter to fuseblock, and finaly from fuseblock to snowflake (cable is "accessible" somehow).
  8. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Yes exactly my plan to first test alternator to ammeter- then ammeter to fuse block- and the fuse block to snowflake.
    Changing all the connectors would be ambitious…but time prohibitive. Mine look ok with no ‘burnt’ connectors. Maybe a future project.
    Improving the grounds is always a good idea. Fortunately my alternator to negative battery was only 120mV. But I’ll check them all once I get the car in the air…
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    Alternator to battery passes through ammeter, which is a resistor. A voltage drop here is acceptable.
    For the connectors, just clean them and add a bit of silver conductive grease. Same job on the fuse terminals. Finally a generous amount of contact cleaner in the switches.
    You can try to bypass the snowflake: the defrost button is fed with a beefy power supply, you can use this power to directly feed the harness that triggers the clutch.
    As a last resort, you can use a relay for the clutch.
  10. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Is a half volt drop acceptable? Or too much?
    Yes good idea. Man! I can not believe how expensive some of the silver elec greases are!
    I guess I’ll make sure the snowflake switch is good/bad, but I’ll bypass it as I troubleshoot the system
    Relay would be an easy thing to do…but I’d rather figure out why the drop in the first place…
    Thanks!
  11. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    Real silver conductive grease is a true silver bullet, worth its weight in, guess what... silver!
    The chineese knock offs are using graphite: this does work somehow, but graphite is not as conductive as silver (obviously).
  12. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    So I didn’t use the silver conductive grease (yet) mainly because the one I ordered, despite being advertised as conductive, specifically says on the side of the jar ‘non-electrical conductive’. BUT I did clean all connections in the alternator/ammeter shunt/ battery axis; I used a dremel with wire wheel and shined all the connections and associated washers, including on the alternator B+, both ammeter shunt connections and of course the battery terminals.
    At best readings with the car running and roughly 200 rpms I still got:
    - alternator B+ and ground - 14.1
    - shunt in and ground - 13.64 (drop of 0.46)
    - shunt out and ground - 13.59 (drop of 0.05 within the shunt)
    - battery - 13.46 (drop 0.13 from shunt out / 0.64 total from alternator)
    - AC clutch - 11.9
    I didn’t check ammeter shunt to fuse block, or fuse block to snowflake switch mostly because I forgot - but I was also running short on time.
    Frankly I think my results show that most of the drop is in the cable from the alternator to the ammeter shunt; but both ends are definitely clean, and I just can’t imagine the mid-section of the cable ‘just went bad’… so it’s still a little confusing. And I’m certainly not going to replace/change the cable in question; that seems like a pretty monumental task considering how tight that engine bay is especially where the wires enter the passenger foot well where the relay board is.
    More to follow as I figure stuff out….
    Right now I’m leaning towards adding a new relay for the AC clutch…HOWEVER 11.9V seems like it should run the clutch, doesn’t it?…..
    Thanks - any help or constructive criticism always welcomed…
  13. samsaprunoff
    4,416
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Jared,
    What is the current being drawn by the AC Clutch? Knowing the current will help you verify if the cable is inadequate. Also, where was your meter's ground connected? As a quick double check of the voltage measured, I will connect the meter's ground right at the battery's negative post. Lastly, did you end up obtaining a quality multimeter?
    Cheers,
    Sam
  14. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Good question on current being drawn by the AC clutch. I did not because I did not refill the system with Freon since I was troubleshooting the voltage drop. And I did not want to run the compressor without Freon. In the end, I may have to fill it with Freon just to check the amperage and the worst case scenario is, we may have to suck the Freon back out to change the clutch if needed. If the clutch ends up being the problem
    I did not get a new multimeter, but I’m confident in my better one as I tested it in a few different scenarios and it seem to give me pretty accurate results.
    does it seem reasonable that 11.9 V at the AC clutch wire is enough to activate the clutch without any issues?
  15. Steve Magnusson
    26,606
    I would generally say "yes". The typical AC compressor clutch coil current is about 4A. (Even though its resistance would be higher in use) You could do a quicky cold resistance measurement of the AC clutch coil to see if it's in the right ballpark -- i.e., should be just a few~5 Ohms; if it's 10-20 Ohms or more = not so good.
    Rahtok likes this.
  16. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Gotcha..i may try that… ty!
  17. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    342
    Scottsdale, AZ
    Jim
    Be sure you are not low on freon as that will cause the clutch to drop out at times. Had the same problem on our 330GT2+2, and decided to hide a small Bosch relay and fuse to power the clutch from the battery and it helped a lot. If you still need more voltage power it directly from the alternator B+ via the relay. Your voltage drops are typical for these older cars. When A/C was ordered they did not do any changes to the original vehicle wiring sizes (AWG).
  18. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Yes, when we tested the clutch, it was full of Freon. And I would never run the AC without any Freon in the system.
    It’s good to hear that you did exactly what I was thinking. Yes it dawned on me. These old cars have old wiring and I’d love to snap my fingers and have all new wiring but that’s just not something I’m gonna do right now. I’ll do a few more tests, but I’m, not opposed to doing the relay thing.
    The B+ post is not a bad idea. But why do you suggest to do that? just to make sure you have full power going to the clutch? Can the clutch handle 14 V? (as opposed to 12.5 -13)
  19. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    The b post on the left fender is easy to tap. You will find here a proper voltage supply and you can hide a fuse and relay together with the rest of the harness (from memory it passes between the two headlights under the Fereari emblem).
    Do you jave a single alternator?
  20. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    Yes single alternator..
    For clarity the only B+ post is on the back of the alternator (i’m fairly certain)
    But still..could run a new cable with the existing one (yes correct the cable goes up front between the headlights and then emerging in the right front corner to follow the right fender up to the battery and passenger footwell/fuse/relay area) and put a new fuse/relay somewhere up front right
  21. jimmyr
    Oct 10, 2004
    342
    Scottsdale, AZ
    Jim
    These AC clutches are for 12V systems which are 14V when the engine is running, but with typical Ferrari wiring as you found out full voltage may not be present.
  22. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    The dual alternator has an obvious advantage here: aside from the post on the fender, each of the alternator has its own wire going to the ammeter shunt, so the load is distributed on two cables.
    While you are there, you should replace this cable by a bigger one (or duplicate it). Same remedy for the positive that goes from batterypost to starter and then relay panel.
    I know that's some work, but electric ancilaries will spoil your pleasure, and compared to messing with the dashboard harness, reaching the relay panel from the engine bay is not such a big deal. From memory I removed the battery/starter cables brought them to my mechanic who made some beefy substitues (crimping these does require some specific tools). As for routing, the cables are "clipped" on the frame with metalic tabs, installation is "easy".
  23. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    I’ll remove the battery again and take a look. I was under the car on Sunday to try and see from the bottom where the cables entered the passenger foot well to go to the fuse panel and relay board. It certainly didn’t seem easy, but I’ll take another look. I have the tools to make my own cables so I’m not concerned about that.
    A mechanic friend of mine had an idea to just run an additional cable from the alternator directly to the battery. Leave the existing one in place but just put a second one. It’s an interesting idea and I’ve never done that before. Does anyone have any opinions about that?
  24. jimmyr
    Oct 10, 2004
    342
    Scottsdale, AZ
    Jim
    Running a heavy cable directly from the alternator will sure help some of the voltage drop problems, but will render the ammeter not so responsive.
  25. raemin
    raemin Formula 3
    Jan 16, 2007
    2,299
    Lyon (FR)
    R. Emin
    From the alternator to the relay panel (i.e the ammeter). Access to relay panel is just under the battery, so if the OP jas managed to route the cable through the engine bay next to the battery, completing the job properly is not so much more work.
