VP Racing fuel ...! | FerrariChat
VP Racing fuel ...!
Discussion in '360/430' started by bmw550i, Sep 24, 2010.
  1. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
  2. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    SPECIFICATION SHEET FOR C-12
    (Typical Values) Specific Gravity: .717 @ 60F
    Lead: Yes
    Color: Green
    Motor Octane: 108
    Reid Vapor Pressure: 7.3
    Oxidation Stability (min.) 1440+
    Distillation:
    10% evap @131.0°F
    50% evap @194.0°F
    90% evap @228.0°F
    E.P. @233.3°F
    Production: Elmendorf, Texas USA
    Availability: Sealed Drums
    Rev: 07/00
    Distillation:
    10% evap @131.0°F
    50% evap @194.0°F
    90% evap @228.0°F
    E.P. @233.3°F
    Simple answer? Nope. Not if you have converters on it. Also, the O2 sensors are adversely affected. Shortens their life substantially.
    C10 is your best choice.
  3. s14roller
    s14roller Karting
    May 3, 2008
    73
    Why bother using race gas if your car isn't tuned for it? Unless your car is turboed, I don't really see the point outside of pouring money down the drain and if you like to change o2 sensors.
  4. rberg32
    rberg32 Karting
    Mar 14, 2007
    245
    Because his car WILL be tuned for it..
  5. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    I dont have cats ...they were removed along with headers ....and o2 sensors where reprogrammed so light doesnt come on , as well as my ecu being tuned ! ...so still wondering which I should be mixing in with pump gas for optimum performance !!
  6. rberg32
    rberg32 Karting
    Mar 14, 2007
    245
    Go with the MS109 ;)
  7. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    can all these formulas be mixed with pump gas ?
  8. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    Not sure how much more you can really squeeze out of the engine with a leaded fuel, I think your best bet would be MS109.
  9. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    An engine only needs as much octane to prevent it from detonating. Any higher than that is a waste of money.
    In fact, on street engines, too high of octane can lead to horsepower loss.
    I don't know the magic octane number for these cars, but the ECU will retard timing if knock is sensed, but when there is no knock and full ECU timing is allowed there is no horsepower to be gained from more octane.
  10. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    can the ms109 be mixed with pump 93 ??? like if i add a little at time to always have some percentage in tank ....my car crackels a lil sometimes when I use inexpensive fuel ...like from exhaust sounds like unburnt fuel air or somthing ....
  11. reuland
    reuland Karting
    Jan 15, 2010
    95
    tyler,texas
    kurt
    MS 109 can be mixed with pump gas! I ran that combo in a turbo 911 for four years!
  12. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    k thanks .... ya know after doing some research the leaded fuels do much well for an engine coating all valves rings and soft engine componants ....only isuue is fouling of cats , and sensors which I do not have on my car ....im thinking of a little lead action here whatcha think ???
  13. rberg32
    rberg32 Karting
    Mar 14, 2007
    245
    You still have sensors on the pipes, just connected to those extenders.. and the ECU is set so it's not so sensitive to not throw a CEL.. if you run leaded, you can have problems with the sensors, so if you run leaded, run a tank of leaded then a tank of unleaded. I didn't think it was worth the extra hassle, so I just run straight ms109 and the car runs great!
  14. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,456
    what did you do to reprogram the 02s to not have ck eng light on?
  15. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    fab speed reprogrammed my ecu to desensatize my sensors after have cats bypassed ..
