Wankel engine in Racing? | FerrariChat
Discussion in 'Other Racing' started by BlueBiturbo, Jul 23, 2005.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    Mazda 787B was the last that I know of a racecar competing with Wankel engine in Le Mans Prototype (or Group C) cars. Why aren't there any other rotary engines in Races? Is it because of the regulations stating piston engines? I know that in F1 it is banned.
    IMHO it would be interesting to see a 4-rotor Wankel engine competing in F1. It would also be beneficial to the development of future rotary engine technology if it is given an equal treatment in high-end auto races such as F1 and prototypes.
    Too bad only Mazda that is still producing wankel engines.
    Here are some links of the 787B (56k warning on the second link)
    http://en.wikipedia.org/wiki/Mazda_787
    http://www.scuderiaciriani.com/rx7/787B/index.html#SPE
    Any thoughts on this?
  2. Chris Taylor
    Chris Taylor Karting
    Aug 11, 2004
    122
    Elroy, TX
    There's a new ALMS car with a Renesis-based 20B (3 rotor).
  3. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    One of the reasons, from what i understand a while back, was that an uncorked rotary is one of the loudest machines known to man. Most racks have those sound sensor deals, at least in sportscars anyway.
  4. fluque
    fluque Formula 3
    Jul 30, 2004
    1,759
    Above 2240m
    Fernando
    #4 fluque, Jul 23, 2005
    I do recall this car having a particular sound but it was not that much louder than the Porsches, Mercedes or Jaguars on the track. Accoriding to Mazda this is what happended:
    "After Mazda’s resounding win in 1991, the Le Mans sanctioning body banned rotary engines due to difficulties in classifying and grouping the unique powerplants against standard piston engines".
    Anyway it was bad to see a winning car go due to regulations.
  5. Chris Taylor
    Aug 11, 2004
    122
    Elroy, TX
    The noise comes from modifying the porting, or changing it alltogether. Street porting, bridge porting, and peripheral porting (moving the intake ports directly above the exhaust) is where the real noise comes from.
    That and straight pipes. :D
  6. Wouter Melissen
    Wouter Melissen Formula Junior
    Nov 12, 2003
    283
    The Netherlands
    Wouter Melissen
    New for this year is a Mazda engined Courage C65 LMP2 racer, which is campaigned in the ALMS. In recent years the Kudzu prototypes used the rotary engine, and IIRC a Welter was also equipped with the rotary.
    They have been used in prototypes for longer than many think; in the early 1970s a Chevron B16 was already rotary powered. That car is still around, and a couple of years ago I have seen it race at Spa.
  7. racerx3317
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    Yes that particular motor was designed to run in racing conditions. A regular rotary sounds horrible with a open exhaust. Loud isn't noramally bad but a rotary sounds unbearable. Conincidently I heard a honda crx many years ago in one of the support races for the Cart Series and it sounds so bad i covered my ears everytime it went by. Now you got these tards putting those mufflers on thier honda street cars. I hate those damned buzzbombs.
  8. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,960
    Southlake, TX
    Rob Lay
    #8 rob lay, Jul 23, 2005
  9. Chris Taylor
    Aug 11, 2004
    122
    Elroy, TX
    You know, for those of us that sleep at the track, one of those sheets of white letters could bring countless hours of entertainment. :D
  10. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Nice one Rob. I didn't know you race RX8.
    Any personal thought on rotary engines? Weaknesses, reliability, etc?
    Too bad rotary engine is banned is some race categories. Given the same R&D budget as piston engines I think the wankel could rule automotive tech.
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Spot on.
  12. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Great shot Rob!
  13. Turb0flat4
    Turb0flat4 Formula 3
    Mar 7, 2004
    1,244
    Singapore
    RND
    That's a cool pic ! :D
  14. Mr Payne
    Mr Payne F1 Rookie
    Jan 8, 2004
    2,878
    Bakersfield, CA
    Payne
    As far as revving ability is concerned.....it just seems natural that it could *own* piston engines...
  15. Kram
    Kram Formula Junior
    Jul 3, 2004
    867
    Park bench, Canada
    Mark
    It’s interesting that the rotary makes so much noise. In ‘85 Mazda were racing a two rotor design for the last time - it was horribly loud, in fact it was so loud that an aluminum plate that shielded the carburetor was eaten away by the sound waves during the span of that year’s Le Mans. In ‘86 they changed to a three rotor design (and injection) and the engine was quieter. The nodes and anti-nodes of the first rotor’s sound waves were canceled out in part by the anti-nodes and nodes of the third’s rotor’s noise. If the engine had a racing weakness it was that there was very little flywheel effect on a rotor set up, a condition that made it difficult to select and hold a particular RPM. All well and good, but in the 757/787 cars the motor was married to a gearbox filled with Porsche syncros and they demand a slow gear change. A clumsy driver could break the clutch or input shaft after several hours of failing to match and hold the correct RPM when changing gear. In that respect they were harder to keep together than anything with a crash gearbox.
  16. robert_c
    robert_c F1 Rookie
    May 12, 2005
    3,417
    SoCal
    Robert C
    I saw the LeMans winner run a few yars ago at Laguna Seca, and it sounded great. Not to loud at all.
    Too bad it was banned the year after it won. Sour grapes.
  17. Wouter Melissen
    Nov 12, 2003
    283
    The Netherlands
    Wouter Melissen
    First of all, the win was somewhat of a fluke, comparable to the 250 LM victory in 1965. Secondly I highly doubt the rules were changed just to shed the world of racing of that bloody fast Mazda. They changed the rules just like they did in 1968 to interest Formula 1 manufacturers to enter or at least supply engines.
  18. LMPDesigner
    LMPDesigner F1 Rookie
    3,208
    Atlanta Georgia
    Current rules allow Rotaries at LeMans. No problems--But with LeMans (ACO), all engines are controlled by varying the size of the air inlet via restrictors, whether they are rotary, recips, turbo or NA. The issue is whether the rotary restrictors have place those engines at a disadvantage to non rotaries. Right now the rules are slightly bised towards turbo engines and/or large displacement 2 valve motors.
    Remember that all engines are basically air pumps, the more air you pump, the more power you make. By restricting the airflow you restrict power. Very simple really. At LeMans the reistrictors hurt high rpm low displacement motors because the restrictors choke the maximum flow at levels below that at which these engines can produce peak power. (More complicated than that-but basiclly correct.)
    Whether rotaries are hurt as much is something that I have actually been contracted to look at by a Japanese mfg. Can't give away names or results but based on analysis, you may be seeing a rotary turbo car at LeMans in a couple of years.
  19. rob lay
    Dec 1, 2000
    63,960
    Southlake, TX
    Rob Lay
    Chris will know more than me, he has actually rebuilt several rotaries. I think the disadvantages for racing are you have to keep them cool and poor gas mileage. It is hard or impossible to over-rev them though. Rotary engines are very small and lightweight too. The RX8 Renesis rotary looks about the size of a medicine ball out of the car.
    We have no muffler on the RX8, but have to run cats, 3" single pipe straight back. Puts out 99 Db at the SCCA sound check distance. Sound is really cool, pops and deep grumble like a Ferrari carbed 12 at low RPM and then screeching whine of angry bees at full buzz.
    I love the rotaries because they are reliable for racing. More so, I just love racing Mazdas because they Zoom Zoom Zoom off the dealer floor! Great racing support for amateur drivers like myself. Purchased car at cost and all parts available at cost too. Contingency programs are healthy for amateur racing. Between Mazda and Hoosier I can end up with over $1,200 value for one day of racing. My day costs don't exceed that unless I break something or want new tires.
  20. senna21
    senna21 F1 Rookie
    Jul 2, 2004
    3,334
    Los Angeles, CA
    Charles W
    I had a friend who saw that car win LeMans. He said it was SO LOUD you could hear it circulate the entire track no matter where you were sitting. Doppler effect x 100. "How loud was it?" :) We asked. "It was so loud that when I was asleep and the car headed into the pits and the engine was shut off I woke up. The drone became such a constant background noise that when it went away... it seemed that something was amiss. It was awesome."
    HUGE Pics on this page below, but well worth it:
    (if you scroll 3/4 of the way down you can see the variable length trumpets on the engine)
  21. WCH
    WCH F1 Veteran
    5,186
    Has no one mentioned Formula Mazda?
