want to buy intake manifold and webers for 328 | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by mark/w/328, May 23, 2006.
  1. Nick
    Nick Formula Junior
    Sponsor Professional Ferrari Technician
    Oct 31, 2003
    506
    Nick Scianna
    Yes they lost the molds; good news is we will have new ones avail very soon. I suggest anyone interested to give me a call, there will be a limited number of them built & there will probably not be another production run until we have enough people again. I do not have a price as of yet, but the cost should not be more than the ones that Frank Capo made. I also have the DCNF idividual throttle fuel injection set ups avail.
  2. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    will they work for a 308QV?
    JD
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    all qv manifolds, 3.0 and 3.2, cross fit -- at least my Capo manifolds do
  4. J-rod
    J-rod Rookie
    Apr 28, 2005
    2
    Canton, OH
    Jared Lewis
    I too am interested in the weber conversion for my 328. If there continues to be a problem obtaining manifolds, I may be able to help. If I could get my hands on one for a few days, i could model it with my 3D cad software and proceed to get quotes for molds. (I could also design one from scratch if someone could get me some dimensions to work with.) If the price looks good, I will have them cast and machined. I'm a mechanical engineer specializing in machine design and i have several good machine shop sources locally.
    Jared
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #30 snj5, Sep 28, 2006
  6. mark/w/328
    mark/w/328 Karting
    Nov 1, 2003
    56
    Mark W
    Well an update,maufolds are being cast at the moment.carbs came from bill at GT, weber carb links are not easy to find, the rest of the parts air cleaner cables, fuel fittings from maranello UK, hope to have it back on the road end of Oct. in aus there is a bit of interest converting 4 valve cars to webers, so have sold seven sets of maufolds.
  7. Bronco Jr
    Bronco Jr Guest
    Reading this thread I would suggest the way to go is Taper throttle bodies :)
    Still need manifolds though :)
  8. dbcooper
    dbcooper Formula Junior
    Feb 7, 2005
    281
    Costa Mesa,Ca.
    Tim Romero
    WHY?
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    personality
    instant response
    +30 hp added, over 200 ft-lbs rear wheel torque
    sound
    reliability
    ease of diy maintenance
  10. DGS
    DGS Seven Time F1 World Champ
    73,069
    MidTN
    DGS
    Reliability? Carbs? Personality, yes, but reliability? ;)
    A modern EFI system could achieve most of the same things (except for a different sound, and needing a laptop for DIY maintenance). (Okay, the personality of an EFI might be that of an accountant ... But remember the curse: "may you live in interesting times"? Carbs are "interesting". :p)
    But in either case, you need reworked cams to get maximum benefit out of the mods.
    The biggest gain is getting that barn door (AFM plate) out of the air intake.
    But, granted, carbs are more of a plug-n-play conversion than working up an EFI map. (Unless you're already a computer nerd. :D)
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Yeppers, that's my experience of Webers vs K-jet.
    On the dyno with stock cams - 30 hp increase plug and play carbs only
    And when something goes out of kilter, Weber induction can be diagnosed and fixed with a screwdriver, 8mm wrench, a rubber hose and a funnel.
    My motto:
    Youth and enthusiasm are always overcome by old age and treachery.
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #37 snj5, Sep 29, 2006
    Here's what we did with pieces from Pierce Manifolds on the 40DCNFs on a 3.2...
  13. mark/w/328
    mark/w/328 Karting
    Nov 1, 2003
    56
    Mark W
    Yes that looks good, but im trying to pull from middle like 308,
    and use 308 throttal cable.
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think center pull is a bit better also, but we could not find a place for a bell crank.
    We were able to easily modify the existing cable without going through a heinous re-install of a 308 cable.
    Good luck!
  15. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just heard from mark/w/328 that his manifolds are in and his 328 is now running with Webers in Oz - pictures later. Terrific work, and I think you will find the transformation amazing, especially the low end.
    In addition, he also relayed he has seven sets of 3.0QV/3,2 liter manifolds available, which can be used with Webers or the TWM throttle bodies, so now's the time 308 QV, 328 and Mondial guys!
    Great work and looking forward to the results!
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
  17. bartmandial 8
    bartmandial 8 Rookie
    Sep 3, 2006
    44
    Olympia WA
    Bret
    Hello everybody
    I have a set of 40 DCNF-12 carbs (4). They have been sitting forever but are in good shape overall. They need to have rebuild kits installed. I want 1100. for all four. A customer of mine has a used set of manifolds. I can get you in touch with him if interested. Let me know.
    [email protected]
    [email protected]
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    mark/w/328,
    Do you still have at least 1 set of the Weber manifolds for 4V engines?
    I got a query from someone looking for them.
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Blast from the past.
  20. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    #45 jeffdavison, May 14, 2013
  21. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    And a pretty good price to boot. Certainly cheaper than the Capo DCNF manifolds I used.
    Of course, the rub is that they are IDFs. One cannot use the 308 DCNF induction parts, and I think the bonnet lid will need to be modified. Pros and cons like any conversion.
    Still, I'd do it (again).
  22. guido ferrari
    guido ferrari Karting
    Jul 21, 2011
    99
    Somewhat intrigued by this idea, I followed the link and found this price today:
    1.309,00 €
    Wondering how much that is in dollars, and what the worldwide demand for these conversion manifolds is.
    Thanks,
    GF
  23. wilkrod
    wilkrod Formula Junior
    253
    Ocala, Fl
    #48 wilkrod, Apr 30, 2015
