Want to check spark plugs - how? | FerrariChat
Discussion in 'Technical Q&A' started by Perfusion, Feb 21, 2006.
  1. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I'd like to remove and check the spark plugs on my '79 308GT4. I think a few may be fouled based on symptoms my car has and suggestions from members on this board. The problem is, I've never done it - Ferrari or not. It seems like, at least for the rear bank, it shouldn't be too hard. The front bank may be another story... I was hoping someone could chime in and point me towards a proper step-by-step "How To" on removing these plugs!
    Thanks so much in advance... I'm tempted to just pop the engine lid and just go for it sans instruction, but on a 26-year-old car, I'm not so sure... I could probably do more harm than good without realizing it.
    Thanks,
    Aaron
  2. 4Webers
    4Webers Formula Junior
    Nov 12, 2003
    276
    Texas
    Darrell
    The spark plug wrench in the factory tool kit makes changing the forward bank relatively easy. If you are going to the trouble of pulling the plugs, you might as well just replace them if they have many miles on them - fouled plugs are notoriously hard to un-foul, and fresh plugs will give you a clean sheet to see what is going on in the engine.
    You may want to practice pulling and replacing a plug on the family truckster or lawn mower first, just to get a feel for it. About the only bad thing you could do is to cross-thread the plug (not very likely), or strip the threads by using gorilla-force on the wrench (possible).
  3. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Using the spark plug wrench in the tool kit is by far the easiest way to go . I agree--if you suspect any fouling at all, replace the plugs. In some cases unburnt fuel will glaze the plug over and it will not fire at all after this happens.
  4. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    You can't tell anything from just looking at a plug. You need to do what we used to call a plug chop. Take the car out on a striaght road, get it in 3rd or 4th, get the rpm up, full throttle. Then turn the ignition off, push in the clutch, coast to the side, then pull the plug.
    You want to see a light brown color on the plugs. When you look into the plug, you should see a slightly darker color at the base of the electrode. If you see dark small spots that sort of shine, you've got detonation, and you've got to adjust your timing. If the plug is oily, then you've got bad rings, or bad valve stem seals. There are books on reading your plugs.
    Hope this helps.
    Art
  5. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Thanks very much, all... Here's a quick run-down on why I want to check my plugs:
    I purchased a '79 308GT4 about 3 weeks ago. Before I took delivery, the car had 2 new cats installed to pass CA Smog, 8 new plugs, and the carbs were properly set. The car ran great. After about a week, I decided to change the oil. That went fine. The next day (a Sat.), I went for a ~160mile drive, and on Sunday, ~210miles. Really wanted to get the car up to temp, etc.
    On the way home from the Sat. drive, I got caught in a traffic jam (on an uphill incline, no less!), and spent a good 5-10 minutes idling, then moving forward 5 ft., idling, then moving forward 5 ft. I began to notice that the car wasn't happy - it would bog down a little, didn't want to idle smoothly, etc.
    On Sunday, an FChat cruise, the car got good 'n hot after a 100-mile cruise. I parked it for about a half-hour, and then started 'er back up. She did NOT want to turn over. I persisted, and the car cranked, and I backed up out of my spot only to leave the parking lot and pull to the side of the road while the group "assembled." Not wanting to shut the car off after the hard time I'd just had, I chose to idle. Coolant temps were fine, so my sweat production was only minimal... I could tell, again, that the car was beginning not to like just sitting there - it wasn't idling as well as it had during the week pre-oil change. A short jaunt down the freeway, and another stop-off on the side of the road for more idling. Now we were on city streets, so very little room to get "up to speed" (or, in this case, up to RPM for an extended time). Traffic lights, low speeds, several more pull-offs, a *real* low-speed drive through a country club-type neighborhood, and to top it all off, we parked on a hill.
    After an hour or so, I go to restart the car, and she just wouldn't go...I mean *really* wouldn't start. The good news was that I had a highly-respected Ferrari mechanic behind me in his TR if anything was REALLY wrong, but I was determined to get this thing started. Try and try again, it just wouldn't go. "Have I flooded it?" (To be honest, I don't even know what the hell that means - this is the oldest car I've ever owned, and my first carb'd car). Somehow, it FINALLY kicked over and I was able to pull away.
    After a good 25-35 minutes more of city street driving, I was on the freeway again. All the way home, I heard popping coming from my exhuast. In the 1 mile from the freeway to my house, I really began to think something was wrong - I was having to keep my RPMs up in the 3k range just to keep the car from stalling out, it was backfiring like mad, and would bog down once I got it rolling (vapor lock, maybe?). I have never been so happy to see my garage door as I was that day.
    Ever since then (about a week and half ago), the car just hasn't been "right." It's harder to start when cold. I have to crank it for a decent amount of time before it starts, and when it does finally kick over, it usually stalls. I go through this 2-3 times before it'll finally just sit there and warm up. Once warm, though, it runs beautifully - city streets, highways, you name it - perfect. When it gets what I'd call "hot", though, that's when the problems come back - backfiring, sh*tty idling, bogs down when taking off from a red light, etc. Oh...and it's still damn-near impossible to restart when hot, *AND* it leaks oil from the rear-main seal now...@#*$@#.
    So...after many FChat archive searches, I've come to the conclusion that I need to check plugs first, then move on, as it seems as though my backfiring is coming from unburnt fuel (no spark) in the exhuast. Could that also explain the new difficulty in starting, or is that another problem that's just popped up as a coincedence?
  6. Rifledriver
    37,288
    Your description sounds like you fouled a plug. That means in short it quit firing. When you pull them out I bet you will find most if not all are black with the exception of the fouled one, it will be somewhere from black and wet to washed clean and wet.
    You have new cats so on the smog test they are working so well that it masked the fact that the carbs are not all that in tune or you have a combination of carb and ignition problems.
    In the old days we tolerated and even expected carbed cars to do that. There isn't really a reason for it. Your car should be very happy driving slow a reasonable percentage of the time and idle happily in traffic. If it does not some tuning work needs to be done.
    For the time being get yourself a set of NGK BP6ES plugs, set them to .025 or so and put them in.
    I do not believe in just fiddling with carburators. They are the last of a succession of things that are called a tune up and if all is done right the previous time they should be the last to deteriorate into trouble. You need a good foundation to build upon before fooling with them if for no other reason than just confirm it is a carb only issue.
  7. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    A check of the service records from the pre-smog tuning shows that 8 NGK BP5ES were installed. I'll try to source the BP6ES plugs tomorrow. Think NAPA, et al. will have them?
  8. Rifledriver
    37,288
    5's are hotter than 6's (less prone to fouling) so for the time being you might want to go with them again and start the process straightening out the tune.
    Give NAPA a try. Those used to be some of the most popular import plug numbers but times change and they may not be a stocking item.
  9. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    Autozone and Pep Boys have sporadically stocked BP6ES's in the past, but the last time I went to buy some I could not find them anywhere. I have now stocked up via www.ngk.com aka www.sparkplugs.com .
    I found one of the best articles on reading plugs on wikipedia of all places:
    http://en.wikipedia.org/wiki/Reading_spark_plugs_for_racing
    another good article:
    http://www.strappe.com/plugs.html
    One interesting thing these articles say is that a tan/brown color means nothing, as it comes from the gasoline additives and thus means nothing as far as the combustion. The only 'color' that matters is the black carbon soot.
  10. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Since you've never replaced a spark plug, here's a few tips:
    Label the wires, or only do one at a time!
    Put anti-seize on the threads before installing.
    Get one of those gap disks and make sure it's right. Out of the box may work; most *seem* to be .025 which is what was mentioned. I gap to .032 on my Lotus because I have a new, strong coil and it likes a larger gap; your car may also (but ask someone who knows!)
    Now, when you install the new plug, tighten it down so it's "pretty tight" but not snug. Then loosen it up and then torque to spec. This is a really important step!
    Ken
  11. Ed_Long
    Ed_Long Formula Junior
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    These are all good tips in my experience. I might add one more, I always like to treat the new plug threads with a shot of WD40 which will lube them, and also act as a starting fluid. Just a little squirt. Then, I always thread the plug with my finger tips and make sure that it spins freely in and out a few times before threading them in. You can spin them in the rest of the way with your spark plug tool. Snug them down, then back up a bit and apply your torque wrench. I have cross threaded plugs into blind holes I could not see and it is a pain in the butt to fix a crossed thread, so avoid at all cost of being careful.
    Ed
  12. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    My "torque wrench" is my trusty ol' socket wrench and my right arm... Guess I need to man up and invest in one of those badboys...
  13. Rifledriver
    37,288
    Aaron, I know you are new at this so just remember far more things are screwed up from overtightening than from being left loose.
    On a plug a light to medium sinch will do, you ain't launching a space shuttle its just a spark plug.
  14. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Amen to that...
    I appreciate it!
  15. BillyD
    BillyD Formula 3
    1,835
    Pacific Northwest
    Bill
    I always blow out the spark plug wells b4 pulling a plug.
    Ciao
    Bill
  16. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    My 308qv could use a set of plugs too- any suggestions for the best plug for injected 308's (normal driving, NOT track) ?
    Is there a torque spec for plugs ?
  17. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,350
    It does sound like you may have some issues either in the ignition or the carbs but one of things that hasn't been touched on here is what you do (specifically with the gas pedal) when you are trying to start the car. You say this is your first carb'd car - starting a carb'd car requires a different technique from starting an injected car - there's no clever ECU's etc to help you do it.
    So, at the risk of "teaching my grandmother to suck eggs (!)"
    There will be a routine that it "likes" best in order to get it to start.
    For example, it may be that when starting from cold what you need to do is to switch on & wait for the fuel pump to build some pressure & then pump the gas pedal to the floor 2 or 3 or 4 times before you crank it. Once its cranking you then need to "catch it" carefully with the pedal. If it doesn't go, stop cranking, pump the pedal a couple more times & try again.
    When its hot you may well find it'll start easier if you just hold the gas pedal to the floor & crank it - obviously releasing the pedal as it fires (but still working with it to keep the thing running).
    When you pump the gas pedal there are accelerator jets in the carbs that squirt neat gas into the cylinders - this is good for cold starting hence you give the thing two or three pumps before you crank it when cold.
    When its hot, holding the pedal to the floor opens the butterflys right up & helps clear out any vapour locks that may have developed from sitting with a hot engine.
    One thing that generally doesn't help (especially when hot) is to sit there cranking the thing & working the gas pedal up & down - every time you pump the pedal you are squirting gas into the thing & that's when it will "flood". If you can smell gas the likelihood is you've flooded it. Let it sit for 10 minutes & try again.
    Try different methods & see what works best but the above are good general "rules of thumb" for starting carb'd cars
    I.
  18. Ed_Long
    Nov 11, 2003
    686
    Salem, Oregon USA
    Ed Long
    Yup, good point, that has always worked for me, just a light "snick" to seat the plug with one hand on the end of the rachet and the other to cradle it. One more thing I learned the hard way......make sure the neoprene cushion is inside the plug socket, otherwise you can apply side torque and snap the plug off.
  19. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    Forgive me for going slightly off topic, but I did not get a tool kit when I got my car. Most of the tools I allready have (just not the Ferrari brand). I really would like a factory plug wrench though. Anyone have a spare they would be willing to sell me? Or advice where to get one. I suppose an aftermarket one would be fine if it was in some way far superior to the origional. Anyone?
    Cheers
    DT
    ____________________________________________
    There is nothing like a Ferrari, there never has been and never will be!
  20. Rifledriver
    37,288
    The tools in Ferrari tool kits are garbage so I wouldn't bother.
  21. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    True, except for the plug wrench. The length and position of the u-joint are made for the car. What do you use that is better?
  22. Rifledriver
    37,288
    The Snap On I have been using for over 30 years has exactly the same dimensions.
    Seems to work fine.
    Only difference is it is cheaper, easier to get and still works.
    Can't seem to think of any other attributes I really care about.
  23. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    At lunch at FoSV last week, Johannes mentioned something about a SnapOn plug wrench - is that brand available commercially (i.e., Winchester Auto, Sears, et al), or is it an order-direct-from-S.O. kinda deal?
  24. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    If you have never changed plugs before get a small torque wrench especially with an aluminum head, the sure sign that an amateur worked on one is stripped plug threads.
  25. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The way to "properly" check a spark plug takes a little more effort that just taking them out in the garage. If you do not have access to a dyno, you will need to first warm up the engine to the factory specified normal operating temp. Then,drive the car at a moderate rpm for several miles...then turn off the engine while moving and depress the clutch and coast to a stop...note that you do not want the engine to drop to idle speed...then you remove the plug. If the tip is a coffee tan/brown color you're OK...if the tip is a black/sooty color, you're too rich, if the tip is a white/chalky color, you're too lean. If you have a dyno you do the same thing, except on the dyno so you do not have to remove the plugs on the side of the road or have the car flatbedded back home before checking the plugs.
