Warning to 3200, 4200 and GransSport owners re: rear ball joints! | FerrariChat
Discussion in 'Maserati' started by Scott98, May 3, 2015.
  1. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    The rubber boots on my rear ball joints were all cracked. My GranSport has only 16,500 miles. They are made out of a very cheap material. Imagine my surprise when I learned the rear ball joints are integrated into the control arm. That's right, you can't buy just new ball joints. You have to buy the whole control arm.
    I called the dealer to see how much it would cost to replace all four. Are you ready for this........$7,000!!!!!!!!! Are you mechanically inclined and want to do it yourself? Are you ready for this......the parts alone are over $5,000!!!!!! ($900 each for uppers and $1,800 each for lowers) (Parts are slightly cheaper for a 4200)
    Luckily, I was able to find some custom make dust covers that fit these cars for $120. HOWEVER, this only works if your ball joints aren't worn out. When the covers tear, dirt enters and wears out the joint quickly. That's why it's imperative to check them sooner rather than later and save some big $$$.
    Scott
  2. Merak1974
    Merak1974 Formula 3
    Aug 31, 2009
    1,716
    Oslo, Norway
    Gabriel R.G. Benito
    Thanks for the warning/reminder! This is a well known issue with those cars.
    Could you describe your dust cover solution in more detail?
    Thank you.
  3. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    #3 Scott98, May 4, 2015
  4. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    #4 Scott98, May 4, 2015
  5. staatsof
    95,950
    Fuggetaboutitland
    Bob
    There is a similar issue on some Jaguars of the same vintage but in that case people have sourced new front control arm bushings (a bit different but ...) that can be pressed in. Is that at all possible with these cars? I know Maserati probably won't help out.
  6. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    As far as I know, nobody has developed a way to change them without damaging the control arm.
    Scott
  7. Merak1974
    Merak1974 Formula 3
    Aug 31, 2009
    1,716
    Oslo, Norway
    Gabriel R.G. Benito
    Thanks for pictures. Very instructive. Who supplied you with the new rubber boots?
  8. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    Someone who had them custom made when his went out. He ended up buying multiple sets and sells them to others who need them. There's a YouTube video detailing the whole replacement procedure.
    Scott
  9. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    send old ones to, "Rare Parts', calif. they will save you tons of money
  10. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    That's the problem. They are integrated into the control arm and can't be removed without damaging it.
    Scott
  11. staatsof
    95,950
    Fuggetaboutitland
    Bob
    But have you asked?
  12. Bludiablordstr
    Bludiablordstr Karting
    Sep 15, 2007
    158
    Phoenix
    Kevin
    Ref. my "Which one?" Post is this a big enough concern to go with the '09 GT instead of the '05 Anniversary. Spyder.
  13. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I am 99% sure that David Askew in the UK had a contact who replaced the ball joints of the 3200. David Askew's Maserati Parts Service THAT saves you a ton of money.. This is several years ago though..
  14. Merak1974
    Merak1974 Formula 3
    Aug 31, 2009
    1,716
    Oslo, Norway
    Gabriel R.G. Benito
    In my opinion, no, it shouldn't be. This is an issue that seemingly has a relatively cheap solution.
  15. TBigs
    TBigs Formula Junior
    Mar 23, 2010
    561
    NW Ohio
    Terry
    Doesn't the dealer sell the boots? Seems like this ought to be a common item replaced as part of the regular service inspections done by dealers.
