Hi I have two original washer bottles and both have leaky pumps, does anyone know a pump that would fit? I want to retain the original bottle. Sent from my iPhone using Tapatalk
Have a look on e bay in the uk, i found the bottle and the pump kit which is new for about £9 for a 328.
The water pump can be purchased at any auto parts store. I had the same issue and found a thread on the this forum with the part number. The pump looks identical, I just remember it was challenging removing the old pump from the plastic bottle, but maybe it was me just being extra careful. I will try and track the part number down for you and repost it. I think it was in a thread, that had all types of comparison parts which can be purchased after market that are essentially the same product without the Ferrari 3 to 4x tax.
Try this link. http://www.autozone.com/autozone/parts/Taap-Windshield-Washer-Pump/_/N-9cibf?counter=46&itemIdentifier=855576_0_0_ Another manufacturer that makes the same pump, is called trico, not sure the part number, but I purchased the trico pump at O'Rielly's.
Try here depending on year; Replacement washer pump https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fwww%2Eferrarichat%2Ecom%2Fforum%2Fshowthread%2Ephp%3Ft%3D450053&share_tid=450053&share_fid=9080&share_type=t Sent from my iPhone using Tapatalk
That's the one. I found this quite a few years ago and it has been working well ever since then. You can use the original hole, grommet and old metal holder, however, it is tricky to get the old washer off and installing it down the container is even trickier, but doable. Another member just enlarged the hole to accommodate the new grommet, much easier solution. Not a bad idea to check the hoses. They are usually quite hard and discolored. The metal band that holds the bottle will clean up nicely if rusted. I use Evaporust to remove the rust, then used the Eastwood Zinc Plating kit to restore the finish and then top coat it with a satin clear coat. Alternatively, you could spray if with a grey paint.
