Washer part number | FerrariChat
Washer part number
Discussion in '360/430' started by NAH, Jan 19, 2019.
  1. NAH
    NAH Rookie
    May 11, 2007
    38
    Albany WA
    Neil Harrison
    Hi all, I am looking for the part number please for the small washer (split I think) which goes on the bolts that hold the front and rear floor pans on a F430. See photo.
    I have the bolts (ref 13) and the large washer (ref 14) of the exploded view but can not see any reference to these small washers.
    Any help appreciated, regards Neil
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    They are just stock spring washers from the local hardware store. In ref to the big washers and bolts- i swapped mine for stainless ones from e bay.
    These bolts screw info spire clips which you will find will go rusty, again you can get for pennies from e bay and they are plated, not painted
  3. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    They’re called split ring lock washer. You can eBay or Home Depot them. Just get them in whatever diameter the bolt is in
  4. NAH
    NAH Rookie
    May 11, 2007
    38
    Albany WA
    Neil Harrison
    That's great, thank you both for your advice :)
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Just regular 6mm lock washers. Home Depot or Ace hardware will have them. Originally plated dull silver, but shiny silver works just fine. The bolts are regular 6x20mm hex bolts.
    Red 27 likes this.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If you decide to fit new spire clips, there are 2 types. One is just a type of spring clip and the other has a few threads. Best go for the few threads type. You will see the different offering on e bay
