Water Filter for Home Car Wash | FerrariChat
Discussion in 'Other Off Topic Forum' started by Lloyd, Nov 2, 2005.
  1. Lloyd
    Lloyd F1 Rookie
    Aug 25, 2001
    2,714
    Austin
    In the micro fiber vs towel thread at http://www.ferrarichat.com/forum/showthread.php?t=78840 Gabe posted a link to a water filter that attaches to your hose and can be found at http://www.pwgazette.com/gardenhosefilters.htm I bought one, tried it and was pleased with the results. I have a black 512TR which is a pain to wash and live in a hot climate with lots of minerals in the water.
    I tried it on a warm day, but not a hot one, so I was not faced with the short drying time I usually run into where spots develop sooner than you can wipe them off. Because of the minerals in my water, it normally spots if you don't get the water off quickly. When I used the filter device the small water drops that I allowed to dry on the car did not appear to leave a spot. I did not do an extended test and it was not in the burning heat, but for now it seems that this device will allow me to do a more relaxed car wash instead of having to do a speed wash and blow the water off with a blower as soon as possible. The device appears to be well made and comes with a bracket so that you can mount it on a wall if you have the space to do so. I would recommend the device based on the results that I experienced as well as the fact that the filter device didn't cost too much. Although your mileage may vary, it is something to think about if you wash your car using mineral rich water. (you should note that they may have similar filters at Lowes, but I don't know what type of filter you would use with them. )
  2. kpl
    kpl Karting
    Jun 9, 2005
    195
    The Mr. Clean Car Wash system also has a similar filter. I've used it, and it works well.
  3. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Lloyd: Do you experience a drop in water pressure? Everyone should own a black car once. I've owned two...it took me longer to figure out how hard it is to make them look so good:)
    I have a reverse osmosis system under my kitchen sink. Even though my water quality is excellent, I'm not thrilled with the amount of chlorine that the water district injects. The sediment filter that you would use for the garden hose system is cheap...under $10 and even less if you shop wisely. Lowe's, Home Depot, etc. can fix you up. Great idea for folks with really hard water.
  4. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    I have this as well and am very pleased with it. Makes washing the car much less of a pain in the *ss. I almost want to go wash it every weekend knowing it wont be so much of a pain and it'll look good with less than half the effort.
    Mark
  5. Lloyd
    Lloyd F1 Rookie
    Aug 25, 2001
    2,714
    Austin
    I have pretty good water pressure so it was difficult to notice, but my impression is that it does slightly reduce water pressure.
    I don't know which is worse the black TR or the early black Viper I owned that I would try to wash with the top off because putting on the top and side curtains was as big a pain as washing the car iteself. Unfortunately, there are certain cars that I love in black and therefore must suffer the curse of the black car.
  6. F1 MONZA
    F1 MONZA Formula Junior
    Sep 6, 2004
    483
    California
    Hi F-chatters glad someone is speaking about water concerns.. may I suggest a water Softners .. Would help safe money on soap and helps reduce water spots for your cars paint finish... we also do reverse osmosis water systems too.
    contact me..
    john at 714 670-9325
    thanks
  7. Sh4rkAttk
    Sh4rkAttk Rookie
    Jul 6, 2005
    37
    So. Cal
    I have the water softner installed in my home and it works wonders, save alot of soap washing a car and the dishes, and leaves your skin nice and smooth after a shower.
  8. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    I bought the Mr Clean kit but have not tried it yet on my black Ferrari. Let you know soon. Mostly I try to eradicate every drop of H2O on the surface w/ synthetic towels from Griot's.
  9. Llenroc
    Llenroc F1 Veteran
    5,498
    Colorado
    Vern
    Just a comment on what I did when we built a new house a few years back. I plumbed in a warm water, soft water using potasium instead of salt, facet to the garage side of the house. Seems to work fine on my black BMW. Have not found a reason to add a filter. Regards, Vern
  10. idoc
    idoc Karting
    Apr 30, 2005
    145
    Westchester,New York
    Steve
    Griot's Garage sells an inline water filter that attaches between the hose bib and your hose. Have not tried it but you may want to check it out
  11. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,756
    Oregon
    Gabe V.
    Hey Lloyd I'm very pleased that worked for you! That is good to hear!
    Did that black BMW ever end up being the 'test mule' :D
    -Gabe
  12. Lloyd
    Lloyd F1 Rookie
    Aug 25, 2001
    2,714
    Austin
    No, I spared my partner's car. He just got it back from the paint shop after someone tried to break into it. The timing just wasn't right.
  13. Dr Tommy Cosgrove
    36,442
    Birmingham, AL
    Tommy
    I have one and two black cars. It works GREAT. I cannot live without it now.
