water from exspansion tank | FerrariChat
Discussion in 'Technical Q&A' started by stuffa1, Sep 24, 2004.
  1. stuffa1
    stuffa1 Rookie
    Dec 17, 2003
    7
    i dont think this is a problem i just wanted to make sure.i just topped the water in my 348 ts up with a cold engine.i started the car on the drive and as it warmed up i noticed a stream of water running down my drive.i quickly turned the engine of and checked where it was coming from and it was pouring out of the exspansion tank overflow pipe.could this be that i just put to much water in the car when it was cold? i havnt noticed any temperature problems while driving.
    thank you
    simon
  2. bob348
    bob348 Formula 3
    Apr 13, 2004
    1,553
    Liege, Belgium
    Geoffrey
    Hi had the same problem with my 348...
    You just have to fill the water until 6 cm to the top of tehe expension tank.
    I had also to replace the expension tank cap because of a leaking seal.
    Be sure than the seal is in good shape, it's important, othewise, you tank couldn't keep the pressure...
