Water in 355 front boot? | FerrariChat
Discussion in 'Technical Q&A' started by barefoot, Feb 27, 2007.
  1. barefoot
    barefoot Karting
    Apr 27, 2004
    62
    Not been in the front boot for ages (96 355 berlinetta) but found it holding water the seal looks ok anyone any ideas please ?
    Kev
  2. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Don't drive it in the rain :)
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well it could be that the water is getting in through the vent duct in the hood. I would pull out the trunk liner and make sure that you don't have water damage in the electrics.
  4. Ricambi America
    Sponsor Owner
    Actually... there are two rubber plugs (about 3" x 5") on the metal floor of the 355 boot. Either crawl under the car and ensure they're still there, or remove the carpeting and look for two gaping holes to the earth below.
    348's have them too. I had lost of the plugs and experienced the same problem in my car.
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Infact there are also two long gromets near the bottom side that one has access to the steering rack as well. But i cant see missing gromets causing the problem due to there being an undertray/Ground Fx on the 355.
    Could you have left anything wet like a cloth in ya boot at all that would cause condensation?? I do know some 360 suffer from damp boots.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Check your heater hoses. Do you see water trails/stains going down your carpet beneath your central air unit?
  7. fasthound
    fasthound Formula Junior
    677
    Maryland
    Kevin
    Even though your HVAC airbox gasket looks OK, it's probably leaking (assuming to wash the car and/or drive it or park it in the rain). Mine was leaking enough to put a pint or two of water in the bonnet area after washing the car or driving in the rain, or even parked in the rain. The way to tell for sure is to pull off the metal frame around the gasket, install a plastic bag at the lower edge, and put the frame back on. If that's your leak, the plastic bag will fill with water.
    Only solution is a new gasket. Not that expensive and can be do it yourself. Had mine replaced and problem disappeared.
    That's if the water is clear. If it has any antifreeze smell to it, then it's proably your heater valve.
    There are drain holes for the bonnet. Make sure they are clear so water can run out if necessary.
