Water in the oil? | FerrariChat
Water in the oil?
Discussion in '308/328' started by AndrewE, Mar 10, 2024.
  1. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Hope I’m wrong but Seems like blown head gasket.
  3. classicalfas
    classicalfas Formula Junior
    318
    Gardiner, NY
    Peter D
    Could just be condensation on the sides. What does the coolant in the tank look like? Suck out some with a turkey baster.
    Ferraripilot likes this.
  4. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    211
    CT
    Anthony V Rapuano, Jr.
    Does it smell of coolant?
  5. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    Thats what I was thinking (not hoping)
  6. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    I will check to see if I can work out what it is but it looks like the usual water in oil symptom
  7. ragtop1
    ragtop1 F1 Veteran
    5,242
    Ontario
    Larry Warren
    If it's really bad, the dipstick will have some mayo on it. Have you looked?
  8. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    No may on dipstick, just on cap and around the tank neck
  9. morcal
    morcal Formula Junior
    389
    Turin,Italy
    Cal
    #9 morcal, Mar 10, 2024
    Stop driving, have the oil out ( check mayonaise amount ) and if too relevant have the cylinder head out. Likely ( unfortunately ) one of the plugs which are needed to close the draining holes in the head casting process are corroded and leaking coolant in the oil circuit. If you have driven for too long/hard the car prior of noticing the problem, it will be a full maintenance job on the engine involving main bearings and reman of the cylinder head. An opportunity for a major ( cam seals, blearings a.s.o)
  10. Steve Magnusson
    26,826
    You need to update your Profile ;).
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Do you normally drive short distances and shut car off
    2dinos, PAP 348 and Basal Skull like this.
  12. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
    You could have water going into the oil system and no oil going into the water system or vise versa.
  13. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    How about we all calm down. Check the dipstick - if it's just got oil on it, take the car for a long drive and get it good and hot. Then have another look.
  14. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    Agree likely just condensation
    2dinos and PAP 348 like this.
  15. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Normal. Prevented by heating car up to running oil temp to burn off condensate. ;Then the oil used to prep bread
  16. Michael DB
    Michael DB Karting
    Dec 22, 2023
    233
    Michael D Beswick
    Or if you’re worried change the oil and filter , clean off the mayo and go for a long drive. Or just clean the mayo off and go for the same drive!
    If much of your testing for the previous issue needed short (cold) drives in the weather we’ve had lately….
  17. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    861
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Bit late to this party
    It’s just condensation .I had a Testarossa before current GT 4 , it had a dry sump .
    As said by others short ish runs in U.K. damp / cold , never really warmed it .
    That’s a tiny amount and totally normal .As others have said take it out and give it some beans , plenty of 4000 upwards up hill runs once all the T + P s are correct .
    This happens in modern cars it’s not been dialled out with tech ……just with modern cars you don’t notice it because they aren’t dry sump .I did notice it a bit on a 360 I had the dip stick was on the oil air separator high up on the engine …..so condensation would rise and sit under the cap just your pic as well as the Testarossa.
    That’s why informed opinion says change the oil annually regardless of the mileage, often low in F cars and AVOID short trips in the damp U.K. winters .
    Also if carb d as well as water condensation you get fuel dilution of the oil at cold starts .
    Ideally when you return from a looooong run you want to hear the fans running while parking up .Then you know it hot .
    Dominik B. likes this.
  18. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    huh?
  19. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    Completely the opposite - mostly do hour long hard drives.
  20. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    Dipstick only has oil, the mayo is just on cap and around the tank neck
    Ferraridoc likes this.
  21. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    Yep as said before I don't do short runs and always get to temp and the fans come on, so no issue with it getting warm enough
  22. Steve Magnusson
    26,826
    Just that a "1981 308GTB" is a rather unusual combination (but not inaccurate if first sold in 1981 and that's what your gov't paperwork is based on). Have had some "1980 308 GTB/S carb" euro versions show up here before, but can't recall a 1981. Would be better if you clarified the Profile description to be:
    "1981 308GTB carb dry sump GB/RHD version" or "1981 308GTB carb dry sump UK Car" IMO.
    Couple/few questions:
    Does it have a 17-digit VIN or just the 5-digit SN and some sort of made-up VIN on the gov't paperwork?
    What was the date of manufacture? Was there a long delay between manufacture and first sale?
  23. AndrewE
    AndrewE Karting
    Aug 29, 2008
    123
    Sevenoaks, England
    Ah OK - it was registered in the UK on 8th Jan 81 and is a full GB RHD carbed dry sump GTB with 14" wheels, deep spoiler and single exit exhaust. It was actually built in Oct 1979. Five digit SN - 29875
  24. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    I agree with most here, clean it up/wipe it off and drive the car and enjoy.
    That's just condensation man, nothing to worry about.
    2dinos likes this.
  25. eric lipper
    eric lipper Karting
    Nov 2, 2003
    172
    I own SN 19333 which is a dry sump 1976 vetroresina but my engine is very similar. The dry sump cars seem to show that when they are not run for long enough to boil all the water out of the oil. My 1976 308 GTB will show that if I do a few drives and they are less than 30 minutes or so. I think it is just condensation due to the volume of the oil and the relative humidity in your area. I live in Houston and this situation seems to show more often when it is super humid/foggy. I would not worry about it if there is no oil in the coolant.
