Water injection for a 355? | FerrariChat
Discussion in '348/355' started by Shootfighter65, Jul 30, 2015.
  1. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    The 355 is known for carbon buildup on the head and valves. Someone on here suggested adding a water injection kit and every stays squeaky clean. Has this been done before? I don't really know what a water injection kit is how it works or if it can be installed on a 355. Is this a real and practical solution?
  2. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    Water injection as far as i know is only used in short term, high boost applications ( like 1/4 miles runs0. meth is usually the preferred fluid, but it its sprayed in the intake usually well before the motor, in order to fully evaporate in order to cool the pressurized air.
    It would have zero benefit in our cars unless you slappin some turbos on.
    Look into fuel treatments or seafoam for internal engine cleaning (after some research)
  3. ShineKen
    ShineKen F1 World Champ
    19,983
    Southern California
    Nostradamus
    It will help with steam cleaning your motor if that's the question.
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,794
    Lake Villa IL
    No
  5. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    I have but there is so many opinions on what works and what doesn't. I try to run Shell 93 all the time and just ran a can bg44k through it. Not sure if it helps or not. Wondering how often or not to run it through. My motor runs strong. I believe if it keeps running this way the car will fall apart around it. Just want to keep it in the sweet spot curious what other owners are doing
  6. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    My personal opinion as a car nut and aviation mechanic is there is no benefit to a fuel additives/cleaners. Gas is already a solvent. only fix for a clogged injector is removal and professional cleaning.
    As for carbon build up, warm it up, drive it hard. it will burn it off.
    I've used seafoam on a few of my other cars with good success, but the risk outweigh any benefit to me on a ferrari. I would not recommend it.
    Stop worrying, just drive.
  7. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Fair enough. How many 355 owners don't worry? Lol
  8. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Anyone on here remember (Johnk possibly) the old '63 Oldsmobile F-85 Jetfire with the 215ci aluminum engine that had a turbo with FACTORY water injection? Nothing like some sixties GM engineering for our F cars. :)
  9. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    IMO there is no real use for WI on our cars ..... but I've working on a new heatshield system that will reduce intake temps enough to see some HP gains ............ before and after intake temp data will be shown along with dyno data .... we'll see how the numbers turn out ... :)
  10. fatbillybob
    Aug 10, 2002
    29,162
    socal
    #10 fatbillybob, Jul 30, 2015
    I will be the lone dissenter. I can guarantee you that if your naturally aspirated sport car or racecar was on track at Buttonwillow raceway today that water injection would increase your horsepower. And yes I have done this. WI works even better with compressors. There is a mild cleaning action of the fuel air water mixture to mildly improve the valve cleanliness. But the reason for WI is not to reduce carbon but increase performance. A much easier way to have cleaner valves is just to make valve cleaning part of your routine major service as done here on this Ferrari motor. It takes 10 seconds per valve with the proper equipment and experience and scares the begeezzers out of people who don't really understand. It ain't magic folks, it is just an engine and they all get dirty.
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,739
    But the way to keep them clean is to use good gas and drive the car all the time.
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Nice work .. :)
    +1 .......... driving the car often does a lot of good in this respect ... :)
  13. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    How is it done?
  14. ShineKen
    19,983
    Southern California
    Nostradamus
    There are expensive systems and inexpensive systems. There are systems that are completely mechanical, but i've only seen it demonstrated on boosted engines. Some systems run off boost levels, some systems run off what your fuel injectors are doing. If you just want to clean the motor, I suggest looking on youtube for some mechanical systems built cheap. Use distilled water.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    Hydrogen cleans really well and speed up flame travel speed heheheh
  16. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,267
    Worcester, England
    Phill J
    Quite a few issues in engines occur because they get driven too cautiously too often.
    Good quality petrol/gas is a must, regular use is ideal, and the occasional "Italian tune-up" works wonders on engines!
    Sometimes you've just got to blow the cobwebs out of them! - It's for their own good! :)
  17. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I had always thought the water and methanol injection were to lower the fuel charge temperature for greater density and, consequently, more power. I am not sure what the actual benefit would be but I wouldn't try it unless I was on a track and it meant something. For the street, bah, wasted.
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,901
    Richmond
    Pete
    Walnut shell blasting, bmw and others sell a tool that's basically a sand blaster hooked to a shop vac for this exact purpose. You could do it yourself if you had a decent wand for your sand blaster and got the right media. Just need to be very careful not to make a mess and be sure the valves are all the way closed on each cylinder when you do it.
  19. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Not sure how that will clean up the area where the valve seats and the face of valve and head where carbon builds up. I can see it cleaning up part of valve stem but that's it.
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,901
    Richmond
    Pete
