Water Pump Advice Needed | FerrariChat
Discussion in 'Boxers/TR/M' started by murphyrg1, Feb 13, 2013.
  1. murphyrg1
    murphyrg1 Karting
    97
    San Luis Obispo, CA
    Rory Murphy
    Since my buddy and I were planning to drive the '90 TR we bought last fall on the East Coast halfway back to California, we had a reputable shop perform a major service with cam belt replacement before picking it up. While they were at it, they replaced the water pump seals. Now that the car is 3000 miles away from that shop, we've just noticed a slight leak from the water pump weep hole that seems to have just started. If we thought that the leak would never get worse, we would probably just live with it until we had some other work that required dropping the motor. However, if the typical failure mode was a slight leak followed by a sudden large leak, we'll be dropping the motor soon.
    I know it's a bit hard to predict something like this without knowing more about what is causing the leak, but I was hoping for some related experience that might help us make this call.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,545
    romano schwabel
    soemtimes a rebuilt waterpump is leaking a little for some time and then it is ok again.
    so as long as it is only a very little cooling fluid comes out just fill up again a little, but when it should start draining then it says: engine out again
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Keep it under observation imo ... :)
  4. Rifledriver
    37,108
    Take it out.
    I reseal the pump on every single TR and BB motor I take out. They should leak zero and if they leak at all it can fail big time. It will not get better.
    I feel for your situation but it is why I advocate some shake down miles close to home after any large service or repair.
  5. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    My water pump seal first went at 46,000 miles then again at 88,000 miles and both times the water pump seal went,the water and oil mixed.So do not take a chance fix it.
  6. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Listen to Rifle.. stop ****ing around and tell them to re-seal the water pump.. Whatever has to be done should be done.. period..
    R
  7. portogts
    portogts Formula 3
    Owner Project Master
    Aug 31, 2008
    2,344
    Maia-Portugal
    Vitor Sousa
    Brian ,
    Do you pressure test the cooling circuit after working on the water pump and before the engine goes back its place?
  8. murphyrg1
    murphyrg1 Karting
    97
    San Luis Obispo, CA
    Rory Murphy
    Thanks for all the input.
    I agree with Brian about the value of a local shakedown run - the logistics this time just didn't permit that. And, we put 1500 miles on it within a couple of weeks of picking it up and didn't notice it leaking. It doesn't leave even a spot when parked and it was only when another shop had it on a lift that the weep hole drip was discovered. I haven't even seen the leak as the car is 200 miles away from me at the moment, but I trust the guy.
    So part of the debate is whether I could drive it home so that we could drop the motor and deal with it, or should I have the shop where it is do the work. If, as tr512 reported that the water could get into the oil, I'm more likely not to drive it - but I thought this leak could only allow water to pass through the weep hole and not into the oil system?
    Since I might be doing this repair, I would also like to know if you can test the seal installation before reassembly.
    Thanks again.
  9. Rifledriver
    37,108
    I didn't read the first time that you already had it home. A shake down that long sure doesnt make sense.
    Ferrari has several different waterpump seals that look almost exactly the same with just a couple of thousandths in OD between the biggest and smallest. I have had several deliverd to me mismarked and of course did not measure before I installed it. On a hand held pump like a 355 it is easy to know right away you F'd up but on a TR with the chain drive pump they might have done that and missed it. I am afraid that if that happened you will very suddenly have a pool of coolant under the car. No good if you are out on the road somewhere.
    Water should only get into the crankcase if and only if two seals fail together. Personally I have never seen it on a TR. Since it is only 200 miles I would try and get it home. The tow bill won't be huge if you want to go that way. If not, fill the trunk with water bottles and hope for the best. Just do not overheat it whatever you do.
  10. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,941
  11. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Trust me the oil and the water do mix..If i remember it was a few years back but there was only one seal and a o/ring or gasket on mine. it was the seal on the shaft that went both times ,the first time i even removed my heads and had them pressure tested.I did get good mileage between failures. My car was a 1985
  12. Rifledriver
    37,108
    I believe yours did but since the TR intro in September 1985 of all the leaking water pumps I have seen in TR's I have never seen one do that.
    There is a seperate seal behind the water seal that seals off the crank case. The water seal and the oil seal would need to fail. Can't say it can't happen but out of the few hundred TR's I have serviced I haven't seen it yet
  13. Craig Reed
    Craig Reed Karting
    Oct 13, 2012
    150
    Columbus, Ohio
    Craig Reed
    I must agree. I believe the weep hole is between the two seals. This makes sure coolant doesn't push past the oil seal.
    I've only serviced 25 or 30 TRs but I can tell you the water pump never leaked on any of them. Must be an installation error or the wrong seal installed. The seals are some what fragile and it would easy to cause damage during installation.
  14. fmaderi
    fmaderi Formula Junior
    May 8, 2005
    258
    clearwater Fla/NY
    frank maderi
    There is a collar the small seal runs on and I've found on bb's ESP that is worn . There have been times when these are not avail and you ll have to decide to make a new one or continue shopping. This is how I've seen water get in engine and BTW ..check to see if the weep hole is clear.Change the coolant every couple of years . Got into an argument with a 35 year master (dearship worker only)that said no they never go bad and the bearing inside never went bad either... do it once do it correctly and don't get paralysis by analysis . Forza ! You got to love a guy that drives a flat twelve cross country.....
  15. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    +1...made a few of those through the years!
  16. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Bottom line:
    Never, ever install the motor without doing a pressure test on the seal first!
    Rgds,
    Vincenzo
  17. Rifledriver
    37,108
    I never have and so far so good.
  18. Rifledriver
    37,108
    Never.
    Do it right.
    Do it once.
  19. murphyrg1
    murphyrg1 Karting
    97
    San Luis Obispo, CA
    Rory Murphy
    Thanks again for all the responses. Here's the update:
    Drove down to check out the car and talk to the shop owner about the leak with the intention of either having him fix it or driving the 200+ miles back to my place to deal with it there at some later time. New piece of info - it only leaks (steady drip) with the engine running. Even with the enigine still hot and the system holding residual pressure, once the engine is off, the leak stops. So much for the value of a pressure test to validate the installation in this case.
    Since I was now even less certain about the failure mode (and how fast it might accelerate), I decided to let the shop replace the seal. Not the way I wanted this to go, but I didn't want to risk engine damage as I crawled through the LA freeway system on my way home.
  20. turbo-joe
    Apr 6, 2008
    9,545
    romano schwabel
    well done !
    because when it is leaking ( steady drip ) only when there is pressure on the sytem it will be a failure of repairing I`m sure.
  21. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Don't be too hasty on that conclusion. When the engine is running, so too is the pump. A running pump significantly changes the pressures within various areas of the system.
    Industry (but not necessarily the local mechanic) routinely carries out hydrostatic testing. The money would not be spent if there was no merit.
    Rgds,
    Vincenzo
  22. murphyrg1
    murphyrg1 Karting
    97
    San Luis Obispo, CA
    Rory Murphy
    Vincenzo,
    You're certainly right about the pressure differences when running which is why I said "...in this case". Had I put in the next seal, I would have still tried to pressure check it before putting the motor back in. I was just saying that even if a pressure test was done after this seal was installed, it doesn't look like it would have caught this particular leak.
    And yes, hydrostatic testing is a common practice in the automotive industry as it will catch many issues. But it is always an expedient proxy for the functional assembly tests that we would all prefer.
    Thanks,
    Rory
  23. LamboRider
    LamboRider Formula Junior
    Feb 9, 2011
    465
    Which shop did the work?
  24. murphyrg1
    murphyrg1 Karting
    97
    San Luis Obispo, CA
    Rory Murphy
    Sorry, I don't feel comfortable giving out their name until I see if they willing participate in fixing the items that failed right after their install. I want to give them the chance to make this right.
  25. turbo-joe
    Apr 6, 2008
    9,545
    romano schwabel
    I would do the same
