Water pump/ alternator belt part# | FerrariChat
Discussion in '308/328' started by rocksoldier, Jan 27, 2007.
  1. rocksoldier
    rocksoldier Rookie
    Jan 27, 2004
    24
    Valencia
    Bryndon Newberry
    My waterpump /alternator belt burned up on my '84 QV.
    I have a spare in the tool kit that came with the car but the part# on the spare is Gates 7M 1000 and I think it's suposed to be a 7M 975.
    Anyone know what the differenc is?
  2. Dr Tommy Cosgrove
    36,275
    Birmingham, AL
    Tommy
  3. Steve Magnusson
    26,586
    7M975 is for the carbed 308 & 7M1000 is for the injected 308 (that use the early combination water pump + alternator v-belt arrangement as shown in the thread Tommy referenced).
    They are only different by 25 mm in length, but, if you have the early style 308QV belt layout with the combined wp + alt belt, I believe 7M1000 is the correct stock belt.
  4. rocksoldier
    rocksoldier Rookie
    Jan 27, 2004
    24
    Valencia
    Bryndon Newberry
    thanks much you guys. This helped. I was going to put the one included in the tool kit on and I wanted to replace it with the correct part.
  5. Steve Magnusson
    26,586
    No trouble, but v-belts don't "burn up" by themselves -- have you confirmed that the wp and alt shafts rotate smoothly and easily by hand?
  6. rocksoldier
    rocksoldier Rookie
    Jan 27, 2004
    24
    Valencia
    Bryndon Newberry
    yeah they move freely. Over the last couple months the belt would squeal when i first started the car , but eventualy it would go away.
    I decided to drive it to work the other day and, as it has been doing, it started to squeal. I revved the engine to make the squeal go away, and away it did......along with the belt.......
  7. Dr Tommy Cosgrove
    36,275
    Birmingham, AL
    Tommy
    That's how it happens. Now you will have to take a screwdriver and chisel away the melted/hardened rubber off the pullies. Ask me how I know...
  8. f360racer
    f360racer Karting
    Sep 14, 2004
    193
    Renton, WA
    PJ Z
    Below I have enclosed a copy of Gates Belts reply to my question concerning my 83 308QV belts. I wanted to find these belts locally no matter where I lost one. They have included the Standard sizes to help find these at your local, back alley auto parts store where if you give them a metric size they look at you funny. They can be purchased for around 30 dollars instead of 75.
    "Philip;
    Gates offers the part numbers you quoted in part on the Industrial side of the business. Gates Auto. Aftermarket does not catalog your application.
    However, you can purchase the products through an Industrial distributor in your area. The part numbers are as follows;
    7M975 - 9/32" top width X 38.39" effective length
    7M1000 - 9/32" top width X 39.37" effective length
    10M800 - non-standard top width - try a part number 11M800 - dimensions - 7/16" top width X 31.50" effective length
    Note: Effective length is the length of the belt under tension on the drive.
    You can purchase the products listed above at the following distributors;
    US BEARINGS & DRIVES
    6141 4TH AVENUE SOUTH
    SEATTLE, WA 98124-0543
    Phone: 206-762-3800
    Fax: 206-762-3826
    Distance from 98059:
    approximately 12.4 miles
    Belts
    GERRISH BEARING & SUPPLY
    5315 4TH AVENUE SOUTH
    SEATTLE, WA 98108
    Phone: 206-762-7070
    Fax: 206-769-8345
    approximately 9.5 miles
    Belts
    MOTION INDUSTRIES, INC.
    18900 DESMOINES MEM. DR.
    BLDG. #4
    SEATAC, WA 98148
    Phone: 206-248-4666
    Fax: 206-248-510
    Web Site: www.MotionIndustries.com
    approximately 9.7 miles
    Hoses
    Hydraulics
    Belts"
  9. f360racer
    f360racer Karting
    Sep 14, 2004
    193
    Renton, WA
    PJ Z
    An update on the 308 belt woes. I found the KR-2 Tensionometer at Napa. However to test the WP/Alt belt it needs to be 84-99 lbs at the "A" arrow photo in the owners manual. The guage starts at 100. Close enough probably but that doesn't solve getting the guage in the right position. Impossible, at least with this belt and location. I need a fish scale that is accurate at 6lbs that I can simply hook the belt and pull down.
    Anyone else have a better idea on the tension needed and how. I am almost at the end of adjustment with the alt and it seems if we measure distance from the end of adjustment to the nut will simplify for many. All we need is someone with an engine out to measure this distance when the belt is spec. Any takers?
    Philip
