Water Pump Rebuild Bearings 3x8s | FerrariChat
Discussion in '308/328' started by 3px19, Aug 27, 2008.
  1. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    Working on rebuilding my water pump. Think the $140 rebuild kits are over priced so I remove the bearings and went to a bearing shop for prices
    This is for the larger 42mm bearings
    OEM SKF 6302 28S1/C3 $11.86
    6302 is the size, 28S1 means has 2 neoprene seals, C3 is the inside tolerance
    NSK 6302 VVC3 made in US $12.13
    VV means 2 neoprene seals rest the same
    So you can get 2 bearings for the price charged for one at f parts sellers.
    Just order the multi piece rear seal and whatever else you need, save some bucks
    The rebuild is very simple. Unless you destroy the snap ring or the bearing ring on removal there is no need to replace them as there is virtually no load on them.
  2. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Do you know if these bearings will fit a '89 water pump? Thanks.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Yes, those are the #116159 'large' wp bearings that started shipping sometime in '81 & were used thru the 328 series.
    If you do a search of Tech Q&A for water pump and bearing you'll find this and also the industry std p/ns for the earlier 'small' bearings & seals. Some of it may be in the old fchat.
  4. thecarreaper
    thecarreaper F1 World Champ
    18,066
    Savannah
    great find. i quoted you and added your post to the 308 cross reference thread. that way all the info like this is easier for people to find.
    great work!
