News
Water pump rebuild
Discussion in 'Mondial' started by AndruL, Mar 8, 2020.
  1. To remove this ad click here.
  2. Meister
    Meister F1 Veteran
    5,448
    Duluth, MN
    The Meister
    where did you source your parts? A kit or individually? source and part numbers would be great.
  3. jkstevens2
    jkstevens2 Karting
    225
    Winter Park, FL
    JK Stevens
    Where the rest of just go out and buy a new part AndruL fabricates his own, rebuilds his own, re-engineers his own! Has the courage to jump right in and tackle the problem You inspire me!
    Thank you for sharing your knowledge and taking the time to take pictures documenting the process!
    Il Steeg and AndruL like this.
  4. AndruL
    AndruL Karting
    Apr 4, 2018
    205
    AndruL
    Sourced from the usual Vendors, Ferrari Parts Exchange, Super Performance, AW Italian... and eBay for the bearings.
    Use Table 24 as your reference, below are what you'll need:
    Item 3, gasket, 135121
    Item 17, bearing, SKF 6302-2RS1 C3
    Item 7 and 52, Seal Kit
    Item 25, O ring for engine block, 105196
    Item 13, locking tab, 100434
    Item 10, bearing washer, 116158
  5. To remove this ad click here.
  6. AndruL
    AndruL Karting
    Apr 4, 2018
    205
    AndruL
    I also replaced the hoses, 30, 32 as the "while your in there" stuff
