News
Water Pump Rebuilder
Discussion in 'Vintage (thru 365 GTC4)' started by italcarguy, Dec 5, 2007.
  1. italcarguy
    italcarguy Formula Junior
    Nov 3, 2003
    505
    Porter Ranch, CA
    Anthony Rimicci
    I have a 330 water pump that needs to be rebuilt. Anyone know of a good rebuilder in California or anywhere else in the US? Thanks.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,184
    Berkeley, CA
    Brian Brown
    The 330GT does not have a waterpump that you can remove and rebuild separtely from the engine. It is integrated into the front timing case of the motor. There is a waterpump seal, seal ride, an oil seal and seal tube that all can be replaced on the engine.
  4. slewman
    slewman Karting
    May 4, 2004
    155
    Do you have a 4 head light car with the belt driven water pump with the electro clutch for the radiator cooling fan ?
  5. 2NA
    2NA F1 World Champ
    Professional Ferrari Technician Consultant Owner
    Dec 29, 2006
    17,752
    Twin Cities
    Tim Keseluk
    #4 2NA, Dec 5, 2007
    Which picture is your car?
    Both are fairly straight forward jobs. I've done many.
    The first type is a separate part and can be removed for rebuilding.
    The second style is driven by the timing chain and frequently is done "in the car".
    You need a few special tools to get it right.
  6. Bryan
    Bryan Formula 3
    Prancing Horse #140 - TechNotes has a good description of water pump rebuild on a Daytona, but the principles are the same for other V-12s of the late 60s and early 70s. Unless the impeller itself is shot, this is not that tough, as kits are available.
