Water Temperature Question | FerrariChat
Discussion in '360/430' started by ecded, Apr 29, 2008.
  1. ecded
    ecded Rookie
    Apr 6, 2008
    9
    Hey guys, I just picked up my first Ferrari (2001 360 Spyder, Grigio Alloy, F1) and have a question on the water temperature gauge. I live in SoCal and have noticed that the needle goes to 280 degrees (to the red, sometimes a few degrees more) when I'm idling at a stop-light or just parked with the car on after normal driving. As soon as I get moving the needle drops back down to the middle (210 degrees or lower if I'm going faster). Is this considered normal? I've searched everywhere and can't find an answer. The manual says to stop the car once the red light turns on, but the light does not turn on. The car runs fine and has not caused any issues yet. Any thoughts?
    Thanks for the help, I'll post some pictures soon!
  2. bigme
    bigme Karting
    Nov 24, 2006
    98
    Illinois
    On mine, the Water Temp is usually at 196-210 F idle. The fans kick on at about 208F. Water Temp should not exceed 257F. I would check the coolant reservoir level.
  3. ONEOFEW
    ONEOFEW Formula Junior
    Jan 19, 2006
    835
    LA
    Steve
    I get it checked out, should not pass the mid way, even on a 100+F summer day
  4. Donie
    Donie Formula Junior
    Jan 14, 2006
    346
    Spain/Ireland
    Perhaps the fans are not kicking in because of a bad temp switch. I would imagine that anywhere approaching the red sector is bad news.
    Don't delay get it checked, or it could become extremely expensive, and even if you have a guarantee you could be without the car for some considerable time if she 'cooks' the motor.
  5. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Don't know the cooling setup that well and didn't take the time to look it up BUT
    This is a classic symptom of air in the cooling system. A bubble gathers at the sensor and the temp rises quickly. Then, when you start moving, there is circulation and the localized temp drops back to normal.
    As stated already, this can cause HUGE problems so get it fixed immediately. Don't drive it that way unless you really want to do some engine work.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    When the car is cold and the engine is off, check your coolant. It's not uncommon for people to sell a used Ferrari with almost no coolant (e.g. an auction car).
    The symptoms that you describe above are consistant with radiator fans not coming on. Check your cooling fan fuses.
    Whatever you do, don't let the water temp hit the red line...because that's a good way to warp aluminum heads (which will blow your head gasket). Once warped, engine heads will require machining or outright replacement if they can't be machined.
  7. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    360s are tougher to fill water systems than most, it could well be an issue with air pockets or possibly the fan issue (actually related since low circulation will not get a flow past the fan switch). Get it checked now, it will not fix itself. I always use a vacuum style filler and then still go through to bleed the system before running a systems check. HTH
    Brian
  8. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Quickly!
  9. toshiba
    toshiba Formula Junior
    Jan 14, 2008
    725
    Santa
    sometimes you need to open the cap and run it, did it and needed to on my bike , not sure on a ferrari but like someone said maybe there is air / low fluid in the system
  10. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    If it's an airlock issue, there is a great danger doing this. There could be a sudden surge of hot coolant out of the neck which at best will only make a mess, worst, take off some skin. Time for real help IMO.
  11. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    can someone tell me where the fuse for the radiator fans are on a 360
  12. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    You're running too hot.
  13. delta2210
    delta2210 Karting
    Aug 15, 2009
    128
    Las Vegas
    Jason
    Definitely get it fixed, as this could cost you thousands of dollars.
    Water pumps go out on 360s regularly, so that could be your issue. This is a few grand to fix. Or, it could be a bad sensor. Ferrari uses notoriously bad sensors and connectors throughout the car. The sensor could be bad or you could have a loose connection. This might only cost you hundreds of dollars to fix, if that.
    I live in Las Vegas and got my car (1999 360 F1) in July and the temp never got over 210/220, even when driving around town when it was 110 degrees.
  14. ferrari 512 tr
    Nov 16, 2008
    4,180
    Australia
    Paolo
    which and where is the fuse for the radiator fans
