Water treatment system to eliminate hard water | FerrariChat
Discussion in 'Detailing & Showroom' started by c8spidey, Jul 20, 2021.
  1. c8spidey
    c8spidey Formula Junior
    Dec 10, 2018
    604
    westchester county ny
    lou g
    Have hard water and leaves stubborn water spots.Suggestions to eliminate them.
  2. jc1
    jc1 Formula Junior
    Feb 9, 2021
    282
    Greenville, SC
    Joey (2012 458 Spider)
    I will eventually make a full post with more details but our water in CA is awful (450-550ppm). I ran a line off of our RO faucet and fill up a few 5 gal Home Depot buckets with 0 ppm RO water. From there I use a worx hydroshot pressure washer to pull spotless water from the bucket.
    You could probably just use the bucket for the final rinse but I prefer to use it for my initial rinse and foam too.
  3. jc1
    jc1 Formula Junior
    Feb 9, 2021
    282
    Greenville, SC
    Check out the CR spotless system too.
    defiant likes this.
  4. c8spidey
    Dec 10, 2018
    604
    lou g
    Thanks-been looking at the CR system and it seems pretty good.
  5. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    I am on a well and it is really hard water. My outside faucet that I use for the car is plumbed from the house that runs through the water softener system (hot and cold water as well). No problems with water spots and very convenient.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    I use a portable power washer that has a self contained reservoir ..i fill with distilled water to rinse car
    jc1 likes this.
  7. c8spidey
    Dec 10, 2018
    604
    lou g
    Hmmmm? my well water also runs through softener but I still get bad water spotting.
    maybe has to do with what chemicals or dissolved solids are not totally getting filtered.
    Thus am looking to the CR Spotless system.
  8. jc1
    jc1 Formula Junior
    Feb 9, 2021
    282
    Greenville, SC
    Water softeners don't change your TDS. They only exchange ions.
    https://www.water-rightgroup.com/resources/spotting-with-water-softener/
    c8spidey and EastMemphis like this.
  9. Rdwaggie
    Rdwaggie Karting
    107
  10. c8spidey
    Dec 10, 2018
    604
    lou g
    THANKS and that's the consensus opinion.
  11. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,272
  12. Mirek
    Mirek Formula 3
    1,492
    Los Angeles, CA
    Mirek
    Watch out for the Aqua Crest ones that you attach directly to the end of your hose. I had my water turned up 1/2 way while using one and it failed. Those things are filled with thousands of tiny sandlike hard particles. I basically sanded my hood down because the inside came apart and spewed it’s innards onto my hood at 1/2 outdoor hose pressure.
    Good times.
