waxy substance in brake fluid master | FerrariChat
Discussion in 'Technical Q&A' started by flipdowt, Feb 24, 2009.
  1. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    #1 flipdowt, Feb 24, 2009
    i just changed my brake fluid and when i was done i noticed a waxy substance dried and flaking off the float for the master cyl. before i started the process i wrapped it up out of the way so i could easily fill with fluid (ate blue). when i was done i unwrapped the fill cap and float and the crud started to flake and fall off the float.i cleaned it off and installed back on. any ideas what it could be? i think the fluid was original from 2004
  2. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    #2 AnotherDunneDeal, Feb 24, 2009
    Over a period of time brake lines will accumulate condensation. This is one of the main reasons we want to change the fluid regularly. Too much condensation will cause undue wear on the internal parts of the brake system. Also if the brake fluid ever got very hot from heavy use it could cause thermal breakdown and again cause undue wear. Most people do not realize that condensation will build up on a closed system such as brakes. But it definitely does happen.
    If the brake fluid was original from 2004 it is very possible this flaky, waxy substance could be due to breakdown of the fluid and resulting wear. When you completed the fluid change and bled the lines did you notice any substance coming out with the old fluid? You might want to check the brake cylinders at each wheel to see if they are clear. Those four piston calipers need attention. Or are they two piston??? Gosh, I forget what they were in 2004. If have slept since then. If it is contained to the master cylinder possibly you got off light and can just clean the master cylinder float and be done with it.
  3. windsock
    windsock Formula 3
    1,151
    This is caused by moisture in the brake fluid. My suspicion is the fluid has not been changed at the intervals suggested by the manufacturer. This will be throughout the entire system and can be a concern particularly when it migrates into the ABS components.
  4. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    It is easy enough to change all the fluid in the master reservoir every year and then do the whole system every 4 years. It will stay as new. I do this to all cars every Jan or Feb. I also do the power steering fluid reservoir every 2 years.
    aehaas
  5. UroTrash
    Jan 20, 2004
    40,472
    Purgatory
    Clifford Gunboat
    Interesting idea.
    I suppose, theoretically, if you changed the master cylinder fluid at a specific interval, say, once a month, that after several months you would approach a total system change, assuming the fluid would gradually equilibrate through out the system.
