Ways to tighten wing mirror ball and socket? | FerrariChat
Discussion in '308/328' started by vaccarella, May 6, 2017.
  1. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    If I travel over a roughly paved road, the side mirrors tend to drop a little. Not much, but just enough to make me see the road surface behind rather than the traffic behind.
    I took one off the car this morning and it's not obvious how you take the (Vitaloni flag) mirror apart to adjust the ball & socket.
    Any ideas?
  2. dflett
    dflett Formula 3
    1,632
    NY
    David
    It's been a while, but if it's one of the us type flag mirrors, I think there is a screw at one end of the base that tightens the ball joint. Both of mine were loose when I got mine, now they are tight.
  3. DGS
    DGS Seven Time F1 World Champ
    71,700
    MidTN
    DGS
    I had the same issue on my US model 328, on the pass side.
    On mine, there's a plastic cover on the elongated base.
    If you remove that (carefully prying it out along its flex length), there's a hex screw under that which tightens the mechanical ball joint between the base and the "L" shaped flag portion.
    (Separate from the electrical adjustment of the mirror within the flag shell.)
    Then the plastic cover pops back on.
  4. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    I used a little locktite on the hex screw and it seems to help it stay tight on my 89.
  5. vaccarella
    Apr 16, 2011
    2,291
    Paul
    The grub screw at the end of the base only tightens the mount onto the car's wing bracket. It doesn't affect the ball joint at all.
    Mine's a 78 & if you then take the mounting bracket off to reveal the ball (two screws), it seems to be a completely sealed unit. There are no screws to make any adjustment. The ball is formed from a single piece of aluminium incorporating a base through which the 2 mount screws run. Vitaloni flag, part number stamped 33298.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Did the same thing six years ago and it's still holding today.
  7. vaccarella
    Apr 16, 2011
    2,291
    Paul
    Thing is, mine doesn't have that ;) I guess the design of this item evolved over the years.
  8. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,254
    Worcester, England
    Phill J
    Probably due to the ball and sockets coming loose on the early ones and not being fixable! ;)
    (The saddest part of that statement is, it could well be true!)
    Hope you get it sorted one way or another :)
  9. vaccarella
    Apr 16, 2011
    2,291
    Paul
    I'm sure that's a fact. Design evolution happens. It looks the effort worked well for them, as if all else fails they are still produced. The flag mirrors are called Vitaloni Baby Tornado.
  10. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I roughed up the ball/socket with some 60 grit. Really helps.
  11. vaccarella
    Apr 16, 2011
    2,291
    Paul
    I can only access half the ball's sphere at best. The rest is hidden in the moulding. Does any of that half grip when the ball is turned?
  12. DGS
    71,700
    MidTN
    DGS
    #12 DGS, May 7, 2017
    I looked up the Baby Tornado. It's not the mirror on my 328.
    I think Ferrari used different side mirrors on different years and models.
    The Baby Tornado looks like the mirrors on my Alfa Spider.
    (Driver's side was OEM, the dealer added a passenger side duplicate at my request.)
    I've had those mirrors on the Alfa since '79, and haven't had a problem.
    But a web search turned up the following thread on Pelican Parts forum:
    Loose Vitaloni Baby Tornado Mirror - Pelican Parts Technical BBS
    According to that site, if you remove the two screws that mount the mirror to the plate, there's a screw underneath that will tighten the ball.
    I haven't tried this, myself, as my Alfa's mirrors are still tight after 38 years.
    But I suspect there may be a couple different "Baby Tornado" mirror types.
    Pegasus Auto has the ones with the two mounting screws for $92 each.
    Kaferhaus has the ones with an end screw for $32 each.
    So one may be a simpler model without adjustment.
    (Image lifted from the linked discussion)
  13. vaccarella
    Apr 16, 2011
    2,291
    Paul
    Thanks DGS, that's interesting. My 78 has two screws to mount onto the aluminium ball but these are mounting screws only. There is no central screw to adjust. It's a different design.
  14. Gatorrari
    Gatorrari F1 World Champ
    16,455
    Georgia
    Jim Pernikoff
    My passenger mirror tends to come loose, especially if a passenger slams the door. That's why I keep an appropriate hex key in my glovebox!
  15. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    #15 Falcon, May 7, 2017
    I had the same issue on my 328. I decided the solution was additional resistance. I found it in the form of the adhesive that is used on credit card offers that come in the mail with a false card attached. The card is attached with a clear pliable substance that has just the right properties. Remove the card from the letter and extract the strip of clear rubbery material. You can use multiple offers if you desire a larger quantity. You can place this material in the socket area of the mirror and tighten it up. It won't be necessary for excessive force just a firm set. My mirrors have held ever since. I now save my credit card offers in the garage in case I need some resistance for other applications.
  16. EP328
    EP328 Formula Junior
    622
    Northern California
    Ed
    That is a great idea! Will give it a try. Thanks for sharing.
  17. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    Ha I thought was the only guy using this stuff
    we use, what we call mail boogies, for lots of uses
  18. vaccarella
    Apr 16, 2011
    2,291
    Paul
    Thanks Falcon. That's the only tip so far that might actually work on my 78's moulded sealed-unit mirrors :) My mirrors hold position fine on any good road surface, so I'll also try better at avoiding rough unpaved roads. I guess these mirrors weren't designed for rallying :D
  19. DGS
    71,700
    MidTN
    DGS
    One of the first things I learned, in my 328, was to leave enough following distance to see the potholes emerge from the car ahead in time to avoid them.
    On one pothole, the Alpine threw a CD at me. ;)
    (I now have an MP3 player in the car.)
    But these are cars that are precise enough to drive *around* the potholes.
  20. vaccarella
    Apr 16, 2011
    2,291
    Paul
    Thanks for the advanced driving tips ;)
    It wasn't potholes, but a short stretch of shuddering rough surface that gradually dropped the wing mirrors a centimetre. No big deal :)
  21. vaccarella
    Apr 16, 2011
    2,291
    Paul
    I've just returned from a ~300 mile trip today & the mirrors didn't move a millimetre throughout. I guess I just have to accept that a rutted road can dip the mirrors a little. At least it's the sort of track I only travel on maybe once every couple of years in the 308..
