We have an Ace | Page 19 | FerrariChat
We have an Ace
Discussion in 'Aviation Chat' started by ralfabco, Feb 25, 2022.
  1. jcurry
    24,071
    In the past
    Jim
    The most common perception of the Warthog by Americans is the 'highway of death' from GW1. I have been wondering why there was no 'highway of death' when there was a 30mi long stalled Russian convoy north of Kiev. Surely it wasn't due to lack of resources at the time. Sending them some A-10's will not solve anything.
  2. tazandjan
    39,163
    A-10's big advantage is the GAU-8. The A-10C can also carry a wide variety of PGMs, many more than the Su-25. Russian stocks of air to ground PGMs have always been lacking. Both have a hard time surviving in a high threat environment without SEAD support and even with it.
  3. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    The Russians took a beating in the north, that's why they pulled out. The open terrain in the east requires different tactics, and weapons.
  4. donv
    donv Two Time F1 World Champ
    26,105
    Portland, Oregon
    Don
    Does the Su-25 have a gun, or is it just missiles? And I'm assuming the Ukrainians aren't using PGMs most of the time?
  5. Jaguar36
    Jaguar36 Formula 3
    1,079
    Cherry Hill, NJ
    It's also got a 30mm gun, slightly lower rate of fire than the A-10 has though. Only holds 1/4 the rounds of an A-10 too.
  6. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    If my memory serves me, the GAU-8 system weighs 6700 pounds and the airplane was designed around it. They discovered early on that the muzzle gases choked and shut down the engines when the gun was fired at full rate so they had to design a shield to divert the flow.
  7. tazandjan
    39,163
    Much lower muzzle velocity (~2500 vs ~3500 fps), too, so not nearly as effective as the GAU-8 against armor using approximately the same weight projectiles (~400 grams for both). Higher velocity gives nearly twice the muzzle energy and also extends effective range.
  8. donv
    26,105
    Portland, Oregon
    Don
    So basically what I thought. The Su-25 is inferior to the A-10, except for the fact that the Ukrainians already have parts, maintainers, and pilots for the Su-25 and none of that infrastructure for the A-10. And if I were in a tank, I would still be just as nervous facing a couple of Su-25s as a couple of A-10s... especially if I were in a Russian tank with one of those turret loader systems.
    jcurry likes this.
  9. spicedriver
    Feb 1, 2011
    3,859
    Ukraine deploys German MARS II systems:
  10. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Earlier A-10s carried PGMs just fine and when accompanied by an F-16 would give us a lot to work with in employing those PGMs. It is much better now that the A-10s can employ on their own.
  11. tazandjan
    39,163
    Will- Affirmative, but buddy lasing and ground lasing require a lot of coordination and everybody has to get there and have the correct laser code (1688 if nothing was briefed). Have done a bit myself but using two aircraft that could both lase targets and trying to limit exposure for either one. About half the time, something went south.
  12. spicedriver
    Feb 1, 2011
    3,859
  13. spicedriver
    Feb 1, 2011
    3,859
    MiG-29 over Ukraine
  14. spicedriver
    Feb 1, 2011
    3,859
    US sending AGM-88 missiles to Ukraine
  15. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    We practiced all the time and our live hit rate approached self designation rates. The practice is what made it successful. Still, it complicated attacks by an order of magnitude.
  16. spicedriver
    Feb 1, 2011
    3,859
    Russian aircraft in Crimea destroyed.
    BJK likes this.
  17. donv
    26,105
    Portland, Oregon
    Don
    The fact that he is flying around in the middle of the day at a fairly high altitude, with his GoPro running, tells me that the Russian Air Force isn't much of a threat, at least wherever he is.
  18. tazandjan
    39,163
    Wherever he is, it is not far from his base because range sucks in a MiG-29.
  19. donv
    26,105
    Portland, Oregon
    Don
    True, but Ukraine isn't all that large of a country either.
  20. jcurry
    24,071
    In the past
    Jim
    I recall reading that they are only protecting the skies over Kiev and to the west, ie their supply lines. Little to no attempt at establishing any air superiority over the front lines. Lacking SEAD capability they are rather limited where they can operate.
  21. tazandjan
    39,163
    Don- Ukraine is almost as big as Texas, so lack of range is definitely a factor.
  22. spicedriver
    Feb 1, 2011
    3,859
    I believe the key point is that the Russians have not been able to establish air superiority. As an invading force, you would think they would do this first.
  23. tazandjan
    39,163
    Not the way they work. Airpower is an extension of the ground attack to them. Same way they fought in WW-II. If they ever heard of John Warden, they never believed what he said.
  24. jcurry
    24,071
    In the past
    Jim
    Why? Not as though the Ukes are attacking them from the air (other than drones).
    Both sides are too afraid of manpads.
