We need an easier way to describe 308 iterations. | Page 2 | FerrariChat
Discussion in '308/328' started by Birdman, Feb 4, 2007.
  1. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Woah! I have always thought the steel cars started in 76, but with what you just stated I ran off and looked at the GTB register. They say the same thing. That makes the steel non cat car a one year only car!
    Okay, this is off topic a bit, but another thing that interests me, is how many were really produced. GTB register claims 963 GTB, and 106 GTS cars produced in 77, of which 42 GTB's were glass. But is that number just the 77 model year cars, which I have been told ends in June, or is that ALL cars built in 1977, which would also include 78 model year cars? If the later, there could be far fewer steel 77 GTBs produced than the 912 proposed.
    21181, built in March, has the numbers 277 on all of its parts, as well as on the chassis, stamped in above the ignition coils. 21645 built in May is all stamped 311. I am of the understanding these are actual production numbers, ie, 277, and 311 cars built consecutively.
    Tex, Rick, anyone with 77's, can you see what number is stamped near your coils? its the bracket welded to the frame tube that the coil bolts to.
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Sure it can. We were only providing two versions for carb cars, early and Late, i.e. 76-77, and 78-80 (there were a few carb cars made in 80). The dividing line is the changeover in cams/emissions gear. We did not break out the fiberglass cars as their own initial. All ya gotta say is "glass" and there is only one car that fits the description!
    SO ya got:
    1. Glass
    2. CE (early carb)
    3. CL (late carb)
    4. 2Vi (2 valve injected)
    5. QV
    You could also break out QVE and QVL if you wanted to, to describe the change-over to lambda Kjet between '83 and '84, but I am not sure that is really necessary. Not too many people are in the market for ONLY one or the other. Most people either want a QV or a glass, or whatever.
    Now we can talk like this:
    "Hey guys, need a cheap 2Vi so I can put a SC in it!" And only about 20 people will know what the hell you said!
    Birdman
  3. thecarreaper
    thecarreaper F1 World Champ
    18,135
    Savannah
    E I E I ...." O "
    early GTBs rule :cool:
  4. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    2VEE (EURO)
    2VEU (WHAT ELSE - US)
    2VEEF (EURO FIBGLAS)
    2VEUF (US FIBGLAS)
    2VLE
    2VLU
    2VIE
    2VIU...
    Are we missing any other significan varriations?
    cm
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I think you just made it more complicated that typing out the whole thing!!
  6. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    This works for me!
  7. ClydeM
    ClydeM F1 World Champ
    12,123
    Wayne, NJ
    Clyde E. McMurdy
    and besides knowing the subtleties of each variation, you also need to know on which day of the week it was built for parts/repair procedures. It never ends.
    so how many of what kinds of 3x8 will be showing up at the East Coast/West Coast meets.....in their new designations of course ;)
  8. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Placing a "V" for "valves" is redundant. Use a format similar to VIN coding where placement determines feature.
    Example:
    99NVIC
    where
    99 = Two digits representing the model year
    N = Nationality, either "E" for Euro or "U" for USA
    V = Single digit representing # of valves
    I = Fuel atomization process, either "C" for carb'd or "I" for injected
    C = Single digit representing # of cats (including the number zero if none)
    Thus, 77U2I0 would be Big Tex's '77 non-cat car as given above (or to similar effect).
    Again, this is just an idea but does make for simple and consistent identification. I would suggest using a binary method but describing how to convert binary to decimal is a whole nuther thread :p LOL
    However, I think if a person was really interested in a particular model that they would have some documentation (book, web site, etc.) that broke down the various models. Giving a broad example, a model I want is the 328 with the concave rims (non-ABS) but as late as possible -- I could care less about number of valves or cats. How do you convey that cosmetic descriptor? Well, really, a knowledge of the car is better than learning a code and then deciphering it ;)
    Personally, I want a 308 GT4 w/sunroof. What more need I say? :D
  9. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    A very good example, and don’t forget the difference in GTB and GTS regarding dry sump vs. wet sump. I have a 1978 GTB euro with dry sump and 255hp, is that a late carb with early carb performance?
  10. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,448
    E ' ' '/ F
    Enzo Gorlomi
    Wouldn't that be 77U2C0?
  11. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    Well, then I have a 78E2C0
    and perhaps a 78E2C0BD with:
    Seven digit: B=GTB or S=GTS
    Eight digit: D=Dry sump or W=Wet sump
    Im used with this VIN stuff, me like
    /Patric
  12. BigTex
    79,408
    Houston, Texas
    Bubba
    Yes, all Euro cars kept the cams and were NON CAT thru '80..
    Ahem, yes, the 1977 steel NON CAT USA cars is a pretty narrow niche......;)
    I think your math is pretty close Paul, as baring any labor problems it should be similar to the published 'glass cars for the year, I'd think.....
  13. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    I might be mistaken.... but should the steering wheel placement be added?
    Like a
    2VLERHD
    2VLULHD
    Now see what you stirred up Birdman..LOL
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    You guys are insane, I love this!
    :D
    Birdman
  15. opus10583
    opus10583 Formula 3
    Dec 3, 2003
    1,779
    Westchester, NY
    Mark
    Following, sort of, Alfa 105 Spider convention...
    Glass dry sump: S1
    Glass wet: S1.5
    Early carb: S2
    Late carb: S2.5
    2Vi: S3
    Early QV: S4
    Later QV: S4.5
    Early 328: S5
    ABS 328: S5.5
    ...With Euro- or US- preffix as required.
  16. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Yup :eek:
  17. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Nice!
    Maybe insert RHD or LHD after the Nationality, to keep the deciphering fluid since a Euro car could be have the steering wheel on either side. But is this getting too picky? I don't know.
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    Aw, heck, this is too complicated to remember, why not just use the VIN or F* engine coding...
  19. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Yes. F106AB here.
  20. Air_Cooled_Nut
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Agreed. Post characters 4 thru 10 of your VIN. It will describe the car without giving away too much info:
    http://www.red-headed.com/articles/vin.html
