News
Webber float level
Discussion in 'Technical Q&A' started by Ferrari_tech, Jun 23, 2004.
  1. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Can anyone please confirm what the float level is for a 250SWB, the carbs fitted are a standard 40 DCL6, my thinking is 3mm - but not sure.
    MW
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    damn, I forgot to look it up at work today....it'll have to wait till monday now
  4. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Thanks Phil - I'm pretty sure it's 3mm with gasket, but just need confirmation, have a good weekend.
    What's this I here, sold the Boxer ?
    Cheers
    MW
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    ooh I hope so!! But not that I've heard....I better call dad to find out....
    Give Jeff a kick up the bum, where's my 308, 328 + 550 parts!!
    I'm coming over very soon now......tell him to look out.
  6. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Phil,
    You have mail
    MW
  8. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Ok, I went to work especially for you Malcolm.....nah not really, had to go in for something else, but I looked it up for you anyway.
    It's 3 - 3.25 mm, but no mention of gasket, so assume without.
    While you're in there, if engine is standard the other specs are.....
    Chokes 27mm
    Mains 150
    Idles 60
    Pumps 60
    Pump stroke 3mm
    Centres 250
    Air corrector 180
    Needle 175
    Starter 140
    Emulsion F8 (20 holes)
    The 40 DCL's are made from smelted ash trays, and are really susceptible to over tightening of the base...so check the base is flat and that the gaskets are good.......
    Also ignition is 10-12 deg static and 40-42 at 3300 max advance. Points 15-17 thou
    Valve clearances cold
    6 thou inlet (on valve not cam)
    8 thou ex
    Cam timing.....
    IO 27 BTDC
    IC 65 ABDC
    EO 74 BBDC
    EC 16 ATDC
    Regards
    Phil
  9. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Phil - Thanks
  10. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    No worries mate.
    What car is it anyway...I know a few from my years at DK....
  11. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Phil,
    I'ts on another site so I don't have the chassis number to hand - but you more than likely would know it, anyway thanks again
    Malcolm
