Finally they arrive. Didn't take too long but the anxiety was rough! Anyway, these are Webcams grind 1002 248 dur @ .050 .374 lift. The perfect cam between a early carb cam and a P6 IMO. The nasty photo at the end is a early carb cam. Get what you can out of it, I know the pic is terrible, but hey it's the best I could do from that oil hole Visually, there does not look to be much difference, compared to say a P6 cam and a stock cam (huge visual difference there!). Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Dave might make a sudden trip to New England and have something to say about that, wait wait, maybe he'll show up to finish your engine! (then nab his cams)
Thanks John I appreciate your efforts . Here is a pic from left to right P6 inlet : Early carb cam inlet ; Ecc exhaust John do you know the spec for the matching exhaust cam for the #1002 ? Image Unavailable, Please Login
No, I have no idea. I suspect they would use the same exhaust cam they employ with grind 116, which I believe is grind 117 which is: .332 lift 239 dur @ .050. Still too much IMO
