Weber 40 DFI 6 carburetor | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by wildegroot, May 2, 2017.
  1. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    #1 wildegroot, May 2, 2017
    Looking for a Weber 40 DFI 6 carburetor or even just the top cover. We have a 365 GT 2+2 (Queen Mary) in the shop with some abused carburetors on it. The front two top covers have their mounting screws and banjo-fittings over-tightened too many times in the past and they're basically junk. We tried many sources to find replacements without success but found one on E-bay. This model Weber was apparently also used on TVRs and other cars. Anyone here have any ideas, leads or even one of these loose carbs?
  2. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Have you tried Pierce Manifold? Top shelf. Mike
  3. wildegroot
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    Mike, thanks, but that is the very first place we started. No luck.
  4. 12659
    12659 Formula Junior
    Oct 6, 2005
    346
    Seattle WA. USA
    mark
    Bummer
    My 365 gt had similar issues 10? Years ago I think. Mike pierce made a world wide search
    And found a carb body in the U.K. Which served me well. It was not cheap or easy, unlike some past girl friends.
    For a temporary fix you can try to fit a modern dfi carb which are readily available.
    I almost resorted to that option.
    Cheers
    Mark
  5. afwrench
    Nov 24, 2004
    593
    NY
    I'll try again.Give a look at Tomyang.net .All vintage there. Mike
  6. wildegroot
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    Mike, thanks. Appreciated!
  7. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    288
    Scottsdale, AZ
    Jim
    Try GT Parts in Phoenix, Bill had quite a few used Webers and parts. Jim
  8. wildegroot
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    OK, thank you, we'll give them a call.
  9. shaughnessy
    shaughnessy Formula 3
    Apr 1, 2004
    1,844
    Wolfeboro NH
    Thomas E Shaughnessy
    I will have a used Weber dfi carburators
  10. wildegroot
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    Hi Tom,
    I tried calling you and left a voice-mail. Hopefully your phone number is unchanged. We haven't talked in a while. Anyway, I would like to talk to you about the DFI carb(s) you have.
    Regards,
    Wil
  11. thepinkumbrella
    thepinkumbrella F1 Veteran
    Feb 26, 2006
    6,047
    United Kingdom
    From Fast Road Cars Ltd - Weber Carburettors :
    "The 40 DFI was used by FMC for Group 1 Capri 3.1 racing so they do turn up on some Ford Essex V6 engines which may be the best source.
    Over the years I have had customers take them off as too big for standard engines. So probably sitting around in garages!
    Maybe worth enquiring on Ford forums as I do not have anything, only service kits."
    Paul
  12. wildegroot
    Nov 19, 2003
    1,513
    Frenchtown NJ
    Wil de Groot
    Thanks Paul,
    We did some research and found out that several British Fords and a few Euro "civilian" type cars came with the same Weber. We found a guy in the UK who has one available but won't ship to the US. We are now asking him to ship it to a UK (non car guy) friend who is happy to forward it to us. Thank you for your input. It's much appreciated.
    Wil
  13. Modena Motori
    Modena Motori Rookie
    Jan 16, 2011
    12
    Modena
    Modena Motori S.r.l.
    Hello,
    I have a lot of 40 DFI carbs.
    PM pls
  14. Peter Lipman
    Peter Lipman Rookie
    Nov 24, 2020
    21
    Peter Lipman
    I am also looking for the top piece for a 40 DFI carburetor.
