Weber carb needed!!! | FerrariChat
Discussion in '308/328' started by Hans, Mar 25, 2010.
  1. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Hi guys,
    I really don't have the time now to work on and finish my EFI project in time for our big Italy trip in 5 weeks. And so I've decided to try to fix my weber problem first.
    Some monkey has ruined one of my carbs, and some even bigger monkey thought he could fix that by drilling.
    And so I need a new carb, or more specific: carb body.
    I'm looking for a 40 DCNF 37. This is the lefthand rear unit on a twin-distributor euro 308 GT4 (talk about a long shot!!).
    Anyone have or know one? No matter what condition it is in. I've got all the jets, tubes, float, etc etc, so basically if just the body is in good nick, then I'm all set.
    THANKS!!!
    Hans
  2. Racing-Baker
    Racing-Baker Karting
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    i still have 3 carbs left of my set. wil look if i have the body you search.
    i'm sure we can work something out ;)
  3. Racing-Baker
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    i chekked; i have 45-46-48 numbers on the back of the body of the carb.
    so i can't help (i think)
  4. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    I have a spare set , only problem is I don't really want to split up the set !!!
    PM me and we can discuss it .
  5. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Strange numbers! Mine has 40 DCNF 37 stamped at the base, between the CO2 adjustment screws. Same location?
  6. dm_n_stuff
    Dec 10, 2003
    43,865
    26.806311,-81.755805
    Dave M.
  7. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    Racing-Baker has a US spec engine. Maybe there's a difference with European speced carbs?
  8. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,916
    Atlanta
    John!
    I think the progression holes are different somehow. Does it really make a difference if you just order a new DCNF from some dealer? Educate me!
  9. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Yes, the difference is in the progression holes. Changing one carb won't work well.. Different behavior of these two cylinders.
  10. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
  11. BigTex
    79,406
    Houston, Texas
    Bubba
    #11 BigTex, Mar 25, 2010
    Not sure ordering "one" is even possible they come in matched sets or four originally...how about the possiblity of rebuilding the damage and patching the old one up "to run"?????
    Note how Racing Baker has sold #47 from his set....
  12. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    Hans, seriously,
    After your Italy trip you will rebuild to EFi anyway and the progressionhole differences will only show (a little) for the first tiny part of the traject between idle and full throttle. As you will go full throttle for 95% of your trip :):) why bother? Just take the best available and make sure you're ready on time!
  13. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Hans
    My original set is
    40 DCNF 60 150 7L
    59 150 7L
    58 150 7L
    57 150 7N
    and the spare set is just 40 DCNF 99 250 3M on all of them
  14. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    #14 CliffBeer, Mar 26, 2010
    The various flavors of 40 DCNF's are indeed the configuration/size of the progression holes, and the particular jetting that comes installed.
    You can change and match up the jetting without too much trouble, just have a selection of jets/etube that match what you're running on the other three.
    The progression holes are a different matter - you have to have the same sizing and configuration as the other three, hence not all 40 DCNFs are interchangeable. That's not to say that a lot of owners haven't mixed and (not) matched DCNFs anyway. The typical drill is that one carb has gone bad (stripped threads in a jet hole for example), owner/mechanic gets any old 40 DCNF (non-matching progression holes), installs it and tries to tune it using either the same jetting, or a variation thereof to compensate for the different progression holes....you see where this is going on a 30 year old 308 that may have had this happen more than once over its lifespan. Pretty soon, none of the DCNFs match and they all have different jetting and New Owner is wondering why the car runs like crap. New Mechanic puts the same jetting in all four DCNFs and the thing still doesn't run right (of course it doesn't, different progression holes) and everyone is pretty frustrated. New Owner eventually lists the car for sale saying "carbs need a tune" in the advertisement. New Owner #2 buys, and runs the same drill with New Mechanic #2.....
  15. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    #15 duck.co.za, Mar 26, 2010
  16. Racing-Baker
    Jan 11, 2008
    217
    Beveren Leie
    Enzo Duquesnoy
    could you make a pic??
  17. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    I have two spare bodies if you strike out elsewhere. off an early 308GT4.
    Geno
  18. Steve Magnusson
    26,931
    #18 Steve Magnusson, Mar 26, 2010
    I'm fairly certain that you could also use the lefthand front carb body (out of the 35/36/37/38 set) as a replacement as this would have the same progression holes and the mixture screws pointing in the correct direction -- i.e., IIRC, the difference between the lefthand (or righthand) carbs is only the end effectors on the shaft which can be swapped over. Just a thought which might double your probabilty of finding a suitable replacement from near 0 to 2X near 0 ;)
  19. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    #19 Hans, Mar 26, 2010
  20. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    #20 Hans, Mar 26, 2010
    And here's a pic of the problem.
    Note how the hole on the right, where the CO adjustment screw ends, has been drilled out (and at an angle at that) by some yahoo mechanic. Not visible, but the hole where the CO screw ends is also a bit (but not a lot) larger.
    You wouldn't believe the difference this whole thing makes!! I needed to go one step up in idle jet to make it run in the first place.
    I REALLY don't want to horse around with patching patches and would MUCH prefer a new body.
    Which brings me to you, Geno: Which numbers do you have stamped on them? One in the 30's range by any chance???
  21. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Steven,
    I am not so sure that I will do the EFI swap after all. This after another ride in Onno's magnificent 330 GTC. As in my Dino, the character of the car is largely determined by the carbs. Swapping to EFI would make the whole thing much more driveable and easy to live with. And this is exactly what I DON'T want!!
    The whole difference between Ivonne's 328, which quite frankly I found rather boring to drive, and my Dino is in the roughness of the Dino-diamond. You need to progressively feed it with throttle rather than step on it, or it will choke. You need to drive "around" the 4200-4400 rpm hole in the power band, you feed it with the slightest tough of throttle on the overrun and it will start throwing flames.
    And yes, all of this I could program back in, but that would be somewhat like walking through Disneyland and admiring the old wild-west mining town. It looks the same as the real deal, but yet feels somewhat different. (And I really don't want some obnoxious mouse or duck under the hood of my Dino :D)
    Soooooo..... for the time being, I think I'll stick to my Webers....
  22. bigodino
    bigodino F1 World Champ
    13,194
    The Netherlands
    Peter den Biggelaar
    I don't recognize this at all with my carbed 308. Maybe these symptoms are related to your carb problem?
  23. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    #23 Sledge4.2, Mar 26, 2010
  24. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Err..... now THAT is an interesting one....
    I'm looking for a 37, obviously.
    Could you take another shot for me please? Of the progression holes? Like the ones that were posted by Dave on the previous page?
    I'll get my camera out too. Then let's compare holes and see how they compare.
    If those seem to match, then I could transfer the rest from my carb to this body...
    Thanks!!!
    Hans
  25. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    #25 Hans, Mar 26, 2010
