Weber carb tools | FerrariChat
Weber carb tools
Discussion in '308/328' started by Scottc, Oct 15, 2020.
  1. Scottc
    Scottc Karting
    Jan 15, 2006
    81
    New York, NY
    Scott Coverley
    I ordered the 40 DCNF Carb Service kit from Alfa1750 on Ebay. I have been studying the Haynes Carburetor Manual and on page in section 6 "Special overhaul procedures" they refer to a "special tool available from Weber" to reform the main jet seatings. What kind of tool is it and do I need it?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    That is a VERY specialized tool used to re-cut the seats of the main jets. Highly unlikely you would ever need it and if you do your carb re-build is likely well beyond the basic cleaning and replacement of basic parts.
    Saabguy likes this.
  3. Scottc
    Scottc Karting
    Jan 15, 2006
    81
    New York, NY
    Scott Coverley
    so I really don't need any special tools for what I am doing, correct?
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    No special tools of any kind.
    Saabguy likes this.
  5. Scottc
    Scottc Karting
    Jan 15, 2006
    81
    New York, NY
    Scott Coverley
    Thank you!
  6. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    The only special tool i needed was a very, long, thin screwdriver i had to make out of some 1/8" diameter 4130 TIG welding rod rod, to reach the left front carb adjustment screw when equalizing the carbs on the car. It is about 16" long, IIRC, as it needs to get thru the rear carb linkage,and be long enuf so it extends back past the top of the rear cam cover.
    Doug
