Weber/TWM throttle body manifolds for QV + 3.2 | FerrariChat
Discussion in '308/328' started by snj5, Feb 24, 2009.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Was talking to Frank Capo at Modena Engineering about some cams, and he asked if there would be any interest in re-tooling up for a run of cast manifolds for the 3.0 and 3.2 liter 4 valve cars that would fit either Weber DCNF carbs or the TWM throttle body Fuel Injection set up.
    There is a set on my car and they are terrific.
    Any interest?
  2. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    Russ,
    You need to post some pictures for the lazy amongst us who haven't time to wade through your previous posts to find the images.
    And, yes, I could be (the TWM & efi setup).
    Clive
  3. oliv928
    oliv928 Karting
    Aug 14, 2008
    171
    France, Toulouse
    what is a cast manifold Russ ?
  4. effer
    effer Formula Junior
    Jan 6, 2004
    814
    near Montréal
    François R.
    Humm, I would like to go with TWM eventually ...
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    He left out the word "intake".....it's a retro fit to ditch old injection and put (4) 2bbl carbs on the later 308/328 engine.....
    Hair grows on your chest ,and other obvious attributes...
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #6 snj5, Jul 24, 2009
    Here are the cast aluminum intake manifolds on a 3.2; These were beautifully cast by Frank Capo at Modena Engineering in Oz.
    First pic: just the manifolds on the heads; these will fit either Weber DCNFs or TWM throttle bodies
    Second pic: side view of the manifolds with 40 DCNF Webers mounted.
    Hope this helps!
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #7 snj5, Jul 25, 2009
  8. Speedmade
    Speedmade Formula Junior
    387
    Minneapolis, MN
    Reed H
    Russ,
    I would be interested in some of those. May I ask what the price per set was on the first batch?
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    PM sent
  10. Lew L
    Lew L Formula Junior
    Jan 27, 2006
    359
    I'd be interested in an entire Weber carb conversion kit for a QV. Carbs, manifolds, linkage, fuel delivery, airbox, cold air hoses, etc...
  11. effer
    Jan 6, 2004
    814
    near Montréal
    François R.
    Would be interested.
  12. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,315
    Germany
    Steven
    +1
  13. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Sorry for the thread drift here if this is off-topic...
    Just wondering if going from the CIS to Webers requires a cam change as well? I'm guessing that it'll run fine without changing cams, but to take full advantage of the Webers a cam change would be in order. Is that about right??
  14. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    I partially disagree. Required change? No.
    Desirable change, probably, even with the old CIS.
    Doug
  15. Piloto
    Piloto Karting
    Sep 13, 2009
    58
    Definitely interested. Please keep us posted, also on cam change. PMs welcome.
    TN
  16. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Just curious. I know you are currently looking for a Euro GTB QV. Why look so hard for a QV when you would want to switch to carbs?
  17. Lew L
    Jan 27, 2006
    359
    I like everything about the QB, except it's fuel injection. Webers would restore some of the beautiful intake sound and hopefully some of the torque.
    I'd be curious to hear from anyone who has put webers on a QV.
  18. Tokyo Drftr
    Tokyo Drftr Formula 3
    Jan 18, 2009
    2,461
    UA-USA-JP
    Ро&#1081
    Anyone know if there are manifolds to fit IDA's on a 2v motor?
  19. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Sounds very cool; read the article on Russ's car in Forza. Gotta love it!
  20. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,006
    Cape Town South Afri
    Dave
    Now we are talking !!! I think there is a engine lid clearance problem with IDA's
  21. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    id be interested if it priced reasonably.
    with a little boring, would 42's dcnf fit?
    thanks
  22. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Hi Doug,
    Sorry, not following you here. My question was simply: to really take full advantage of the Webers is a cam change necessary?
    Thanks.
  23. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hi Cliff,
    I'm not a professional and i don't know on the QV but i will say Yes, you need to change the cams to take full advantage of Webers.
    Chris
  24. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Hi Chris,
    Thanks, I'm no professional either but I'm guess you're exactly right here. I haven't mucked around with 308 cams before but I've plenty of experience with CIS and Webers on other cars (porsche 911 for example) and the Webers don't seem to like much overlap at all as the reverse pulse in the runners stalls the vacuum and flow - the Webers depend heavily upon the vacuum to supply the right A/F ratio, more so than the CIS which doesn't have the same dependence. My WAG on a cam for Webers would be very mild overlap but with more lift and more aggressive ramp. In other words, fairly extended durations but with more aggressive ramps such that the total overlap is less.
    The CIS is such a mild FI system that a really aggressive cam does nothing for it - so best just to stay mild rather than wild in the cam department with CIS.
    There are folks that have done a lot of cam work with CIS 911s going to Webers and I would think those lessons are equally applicable to the 308.
  25. Veleno
    Veleno Rookie
    Jan 10, 2010
    25
    What is the price for all the parts needed for this conversion?
    Are there any pictures (aside from what's posted) of a complete conversion with the Webers on a QV?
