Weight Lifting techniques and tips | Page 18 | FerrariChat
Discussion in 'Health & Fitness' started by Skidkid, Nov 19, 2021.
  1. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,951
    Weston, FL
    Scott
    Just over two weeks out. Down to 1,790 calories a day (normal is 3,000) and doing 5 days a week of 30 minute LISS cardio sessions…..
    Skidkid and Thecadster like this.
  2. Skidkid
    Skidkid F1 Veteran
    9,650
    Campbell, CA
    John Zornes
    Good luck Scott. Looking forward to seeing the pics.
    Scott98 likes this.
  3. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,951
    Weston, FL
    Scott
    anunakki, Skidkid and Thecadster like this.
  4. MikeJF488
    MikeJF488 Karting
    Oct 6, 2018
    171
    London
    Mike joseph
    Looking good , nice work, worth all of the effort
    Scott98 likes this.
  5. Maximus1973
    Maximus1973 Formula 3
    Oct 29, 2016
    1,546
    congrats, well done!
  6. Hellenmarc
    Hellenmarc Rookie
    12
    Hellen Marc
    If I am hitting quads much in a deadlift I am definitely out of form. It is almost all glutes and hamstrings with some inner leg since I use sumo. When I use standard form, my knees are so far over the bar it just doesn't work well. I also try to extend uniformly, if the hips rise too fast it leaves my back very vulnerable. And of course get the upper back tight before launch so you don't slump.
    Skidkid likes this.
  7. Maximus1973
    Oct 29, 2016
    1,546
    I'm not sure what the question exactly is? Can you please explain a bit more?
    Deadlifts sure are not an exercise everyone can/should do. It's an amazing exercise that has a lot of real life overspill, but it can also be a double edged sword due to high risk of injury.
    if you feel like this exercise isn't 'doing it for you, by all means don't do it. '
    There are no Golden/Must Do exercises you need to do.
    Do the ones you feel good at and can do with picture perfect form.
  8. Skidkid
    Skidkid F1 Veteran
    9,650
    Campbell, CA
    John Zornes
    Agreed, form is everything on this lift. If my hips go up too fast/far, I bail out because the risk of back injury is much too high. I would rather drop the bar and try again than injure myself.
    I am very tall and, like you, I used to lift sumo. Then I switched to the traditional form, and my lifts improved. It definitely took a while to get the form dialed. The trick to clearing the legs is to lean far enough back, you would fall over backward if it weren't for the weight of the bar. You want the arms vertical, or very close to, when you lift off the ground. They can be in front during setup and when you start, leaning back and tightening lats will put you in a good place for the launch.
  9. HotShoe
    HotShoe F1 Veteran
    9,012
    Lake Worth, FL
    Anthony Lauro
    I love deadlifts! I don't do sumo though, not a fan. I'd rather use the trap bar if I couldn't do traditional safely.
