Weight of complete TR transmision | FerrariChat
Discussion in 'Technical Q&A' started by Yaninnya, Feb 10, 2006.
  1. Yaninnya
    Yaninnya Rookie
    Sep 15, 2005
    14
    Jersey, CI
    Jan Zaczeniuk
    Maybe someone know: what is the overall weight of 512 TR engine/transmision? I need to move it and I don't want to brake workshop crane.
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Approx 86 kgms - dry weight / no oil
  3. Steve Magnusson
    26,931
    Jan -- Can you clarify your question (what you've got in the title doesn't match the text of your post)? Do you mean just the gearbox or the whole powerplant? My guess would be that Malcolm's response is for just a "dry" gearbox (or a typo ;)) and that this thread:
    http://ferrarichat.com/forum/showthread.php?t=70671
    gives a better estimate for a "wet" complete powerplant (although no one responded to the question).
  4. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Hi Steve,
    Just to clarify - by dry I mean it has no oil in it, the weight includes all gears, shafts, casings etc.
  5. Steve Magnusson
    26,931
    I'm clear on the "dry" part Malcolm -- but the 86 Kgm weight that you quoted is literally only the gearbox, right?
  6. Yaninnya
    Yaninnya Rookie
    Sep 15, 2005
    14
    Jersey, CI
    Jan Zaczeniuk
    Yes, sorry, it wasn't clear at all. I mean the weight the complite engine (with manifolds, generator, AC compressor, belts, etc), clutch, trasfer gears, gearbox and diff. Everything in form which usually is remove from the car.
  7. Yaninnya
    Yaninnya Rookie
    Sep 15, 2005
    14
    Jersey, CI
    Jan Zaczeniuk
  8. tbakowsky
    Sep 18, 2002
    20,021
    The Cold North
    Tom
    A 2 ton engine crane will be more then enough to move it around. Just hoist it off the ground enough for clearance, and move it the the spot desiered. Most shop engine cranes have this capacity as the norm.
  9. fly
    fly Karting
    Nov 20, 2003
    124
    Sydney, Australia
    Steve
    Sorry, I looked through all my documentation and couldn’t find any information on these weights, but I would estimate in the range of 500kg, which most engine cranes would not have a problem with. Good luck with it.
  10. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    1200 lbs? Seems awfully heavy. Someone must know. I'd have guessed 600 - 700.
    For reference:
    - I believe a v8 Detroit iron block is about 700lbs.
    - I would guess the 308 block and trans is 500 - 600 lbs.
    - I believe the F1 v10 motor was about 200 lbs.
    Philip
    P.S., J Patterson will know.
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    if its a ford the block and heads are 700-725lb ish, the bare block no crank is 350lb. a complete pan to carb ford bb is 1000lbs throw in a C6 and you're pushing the 1500lb mark, getting as heavy as some super cars, now that is some heavy wheight in the front of a car, oddly the cleaveland used in the panteras were not that much lighter becouse they were bigger than the small block windsor.
  12. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Scott, thanks for the data. As a reference, the '62 Lotus Elan racer (Twin Cam 4-banger) weighs around 1300 lbs, wet. Lotus 23 was under 1000lbs dry.
    So, to the original poster's question, anyone know the weight of the TR engine c/w accessories.
    Philip
  13. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,509
    Canada
    Newman
    The 308 engine/gearbox assy is 500lbs, I would think the 12 might weigh in at 700lbs complete.
