Weird acting check engine light !!?? | FerrariChat
Discussion in '360/430' started by Robby, Feb 16, 2018.
  1. Robby
    Robby Rookie
    Dec 17, 2017
    25
    Robby P
    I dont know if im imagining things but I took my 05 f430 out today and thinking back I feel like the check engine light was on untill I put the car in gear... once going in reverse turned it off and the second time going into 1st turned it off. Once I was driving it never came on westher in Neutural, driving or in gear stopped... was this just a conicidence both times or is this a thing? Ive cold started the car before and im pretture sure the light had gone off fairly quickly after startup... any ideas?
  2. RedNeck
    RedNeck F1 World Champ
    12,307
    The CSA
    Me
    Probably coincidental...have you scanned to see if there are any codes in memory? How old is your battery?
  3. Robby
    Robby Rookie
    Dec 17, 2017
    25
    Robby P
    I havent scanned it, I had planned to then it went off so I assumed no problem... I put that battery in about a month ago.
  4. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    The 430 takes much longer for the CEL to turn off at start-up than the 360. If you fire up the car and start driving then it will be on as you pull-out, whether backing up or going forward, and it will extinguish while you drive off as it finishes whatever checks it does. Same with the 612...
  5. Robby
    Robby Rookie
    Dec 17, 2017
    25
    Robby P
    Yep... no codes... must have been bad timing
