Weird Battery phenomena | FerrariChat
Discussion in 'Technical Q&A' started by Snapshift, Oct 31, 2022.
  1. Snapshift
    Snapshift Formula Junior
    934
    Centralia IL
    Lyle D. Pahnke
    I just bought a 458 that had a two-month-old wet cell battery in it, probably put in by the dealer to get it out of the showroom. It was a 30 month warranty Interstate group 48 battery which on the battery tender would charge fully, but using my Bluetooth battery monitor upon starting the car from a fully charged state, the starting voltage would drop to 8.5 V. It started normally however but the battery would rapidly discharge if not on the tender. Not sure what codes this low-voltage was throwing.
    I was uncomfortable with this pulled the battery and replaced it with a three year warranty group 48 AGM battery. It now charges up fully and starting voltage drops to 10.15 V which I think is a lot better. I have a granite battery load tester and tested each battery fully charged. The wet cell one showed hundred percent good condition and appropriate cold cranking amps commensurate with its size. The new AGM battery also showed hundred percent conditioning with about a 980 cold cranking amps on a fresh battery that is rated at 760 CCAs.
    My question is why would a two-month-old wet cell battery the tests normal with a load meter drop to 8.5 V from a fully charged state during starting, while the AGM with the same capacity drops to 10.15V upon cranking. It seems as though the wet cell is just not as efficient in delivering it starting voltage even though it tests normal. I hate to turn in two-month-old battery tests normal capacity even though it's a wet cell battery as a core. I really don't want to be using a wet cell in Ferrari as there does not appear to be any vent tubes.
    Any thoughts on this would be helpful to my understanding. Thank you for your thoughts. Of course I'm sticking with the AGM battery. This battery saga all started with what I thought might be knocking off my radio but I have been unable to resurrect it and I'm not sure why. I guess I'll have to take a dealer to get a diagnosis but I think I may just ignore it since I rarely listen to any radio anyway but thankfully, the streaming still works through the Bovee, and I can stream Sirius XM radio and Apple music so that's probably good enough for me. Just perplexed as to why there is such a voltage drop on the wet cell versus the AGM but it may internal resistance or a beginning of a shorted cell which is hasn't shown up yet. Thank you
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    To make a long story short, the AGM batteries are an evolution of lead acid batteries with multiple thinner plates of leads. This provides more surface for the chemical reaction, and hence more cranking power.
    The downside is that thinner plates means these batteries are more fragile and need more care to reach a similar lifespan.
    dodici likes this.
  3. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    As long as the battery can supply enough current (amps) to crank the engine, the voltage drop is not relevant. Useful life of a battery is based on the number of charge/discharge cycles. This assumes it it not allowed to either completely discharge or freeze. I have used Interstate batteries in several cars for years, and they have lasted 6 to 10 years with a Battery Tender attached,
    Snapshift likes this.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    This is true for our vintage cars but do not apply to the 458: there must be enough voltage so as to properly feed all the electronic modules and sensors of the car. Most sensors are using a 5v regulator so can cope with low voltage, but other sensors are not so tolerant and will throw tons of errors to the ECU.
    I am not a fan of fancy batteries (AGM, spiral wound,... ), but on a modern car these are the way to go.
    Juanpsi, Snapshift and wmuno like this.
  5. Flyingbrick242
    Flyingbrick242 Formula Junior
    690
    Northern AZ.
    Cranking voltage [+50] to CU's are critical for healthy communication on the can bus..as indicated if the CU works off a 5v reference it will have no problem communicating while cranking even with a marginal healthy battery however if that same CU is 12v dependant then with that same marginal battery you may get cranking voltage to momentary drop below 10v which in most cases CU's check out...this is when error indications' take place.
    In most cases but not all a restart clears all error displays since the battery has just received a charge from the alternator and voltage is slightly up..
    Battery's from my experience can be perfectly good one day and fail the next, some even start the vehicle just fine but have a marginal CCA.
    It is also my observation that F cars are a bit sensitive to these voltage variations...
    Just a additional technical suggestion which I don't see mentioned we must also be sensitive to B+ Battery cable and battery ground voltage drops while cranking.
    A excessive voltage drop in either cable could give a similar symptom.
    Qavion, flash32 and Snapshift like this.
  6. Qavion
    Qavion F1 World Champ
    14,533
    Ian Riddell
    Just to clarify... The ECUs are deriving 5 volts from 12 volts via some kind of regulator. It doesn't mean that the battery voltage can drop to, say, 5.5 volts and still allow the ECUs to function. Integrated circuit voltage regulators can generally handle a wide range of input voltages (e.g. some can handle 8 ~ 25 volts). Basic zener diode regulators may go lower, but there are current limitations.
  7. wmuno
    522
    Wilmette, Illinois
    Bill Muno
  8. wmuno
    522
    Wilmette, Illinois
    Bill Muno
    Agreed; my vintage V-12 doesn't contain a single ECU. I'm perplexed that Ferrari would design such a complex electrical system that a slight drop in battery voltage during starting would cause the whole electrical system to shut down. If the ECUs need a constant 5 volts to function, there are voltage regulators that can store energy to deal with a momentary drop below 5 volts.
  9. Snapshift
    934
    Centralia IL
    Lyle D. Pahnke
    I still don't understand why the voltage differences between the 2 different types of batteries of equal capacities, at least measured by my equipment. I know that these cars eat batteries and are very sensitive to a multitude of voltage variances for all the above stated reasons. The high parasitic draw doesn't help anything. I will run more tests on the new battery and try to get a static discharge rate off tender for the 458 as I did for my 430. It was eye opening.Thanks again for the help .
  10. raemin
    raemin Formula 3
    Jan 16, 2007
    2,388
    Lyon (FR)
    R. Emin
    A car battery is 6 x 2v lead acid batteries in serie. A good agm cell has an internal resistance of 2milli-ohms. So 12 mohms in total. If you need 200Amps to cranck the engine, you will experience a 2.4v voltage drop. A regulat battery has an higher internal resistance so higher voltage drop.
    Also in order to clear the dendrite buildup in the battery, AGM are overcharged (1v more), and spiral wound AGM (optima) even more.
    So an AGM has higher resting voltage and less voltage drop, which result in more voltage when cranking.
  11. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    Voltage is an expression of how much the electrons want to flow from point A to point B, sort of like the pressure in any water system.
    When you turn the starter, the electrons see an open path and want to flow based on the load demands of the starter. It's like turning on a faucet.
    However, if you have two different batteries - which each have different internal resistances of their own - that can be thought of like having two different size garden hoses. The larger hose (i.e. less restriction) can provide more pressure (higher voltage) when called upon, because the hose itself isn't as much of a limiting factor in the system - thus more flow will occur. When your battery has a better design and less internal resistance (kinda like having a better flowing garden hose), then by its very design there will be less internal restriction occurring when flow is needed.
    More electrons flowing means greater current, which - due to Ohm's law - means a higher voltage level will be present in the system (since V = I * R). More restriction (in the form of the battery not being able to flow as many electrons due to internal resistance) means fewer electrons (lower current) will occur; this lower "I" [current] value will manifest itself as a lower voltage in the system, aka a higher "voltage drop" when measured.
    Ray
