weird electrical problem on a 550 | FerrariChat
Discussion in '456/550/575' started by mvgt2, Aug 29, 2017.
  1. mvgt2
    mvgt2 Karting
    Sep 18, 2012
    70
    Hi Guys
    I have a UK 550 that has developed an electrical problem, the left hand indicator turn signals constantly flash , even when the ignition has been switched off and the relevant fuse removed from the fuse board.
    i wonder if any owners have had the same problem and what the possible cause and remedy would be?
    many thanks in advance
    john
  2. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    I would look at checking the hazard and turn signal switches. For starters, remove fuse by fuse and by that see if you can find which fuse delivers the power that reaches the lights, that should give you a first clue.
  3. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    #3 DZ-96, Aug 29, 2017
    Hi
    I'm sure, that your inertia switch is bad.
    Had the same, a mouse ate the rubber on top of the inertia switch, and when washing the car, water came inside the switch.
    Got the tipp from an UK 550 owner from here.
    My rear light melted inside from the hot lamp.
    The inertia switch was used in many Italian cars from the 90's, Alfa and Fiat.
    So you can get them very cheap, for example ebay.
    Search for inertia switch from nearly all Fiat or Alfa 156 166 146 145 ....
    I bought some of these switches at an Italian junk yard in holiday 4 years ago
    Daniel
  4. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
  5. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
  6. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
  7. Simon1965
    Simon1965 Formula Junior
    Feb 8, 2011
    268
    HKSAR
    Simon
    As others have said inertia switch. Simply change and problem will stop.
    Swapping out is challenging as not much room to get at it and the bolts that hold it.
  8. DZ-96
    DZ-96 Formula 3
    1,907
    South Germany
    Daniel
    Take the cooling tank a little bit away, so you can reach the 2 screws better.
    Daniel
  9. mvgt2
    mvgt2 Karting
    Sep 18, 2012
    70
    Many Thanks to everyone that gave advice re the inhibiter switch, fitted a new one today and problem cured.
    Some great people on here
    Best regards
  10. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Congrats
